[geos-devel] Fwd: Prepared Geometry
Martin Davis mbdavis at refractions.net
Thu Oct 9 18:31:07 EDT 2008
Harmut, I'm not trying to be inflammatory.  You're right, the Java-vs-C
thing is my personal opinion.  It was a small attempt at humour, but
this probably isn't the right forum for that kind of joke.
I was the person who made the decision about the semantics of
SegmentString, and I (with others) made the decision to try and track
the JTS codebase as closely as possible with GEOS.  I still think that
was the right decision, given the limited resources to maintain the two
codebases.  It's easy to skeet-shoot from the sidelines, but unless
you're willing to contribute the time to rewrite the entire library the
question is moot.
Hartmut Kaiser wrote:
> Martin,
>> I have to disagree with Hartmut's complaint.  The SegmentString class
>> is
>> intended to be an adapter class, which wraps a data structure
>> (Coordinate sequence) owned by some client to allow it to be processed
>> by the noding logic.  Under this pattern, the SegmentString class
>> definitely should  *not* be freeing the memory for the wrapped sequence
>> - that is the responsibility of the client.
> Well, that's a decision of the people around the GEOS project, not mine. I
> just fixed some nasty memleaks which wouldn't have been there if some more
> coherent memory (and encapsulation) strategy had been used. I'm sure there
> was a reason for that. But please don't jump on me, I'm only saying that I
> would have done it differently.
>> I can't comment on "writing C++ like Java", but obviously C++ requires
>> more knowledge of the usage patterns of memory resources than Java
>> does.  That's why Java is easier to write  8^)
> Come on, this is your personal opinion. And please, there is no need to
> start a religious war here.
> I was intentionally very cautious while writing my remark in the first
> place.
> Regards Hartmut
>> Paul Ramsey wrote:
>>> Another quarter heard from. I have applied this "ugly" patch
>>> nonetheless, since it removes my leak in PostGIS.
>>> P
>>> ---------- Forwarded message ----------
>>> From: Hartmut Kaiser <hartmut.kaiser at gmail.com>
>>> Date: Thu, Oct 9, 2008 at 6:55 AM
>>> Subject: RE: Prepared Geometry
>>> To: Paul Ramsey <pramsey at cleverelephant.ca>
>>> Paul,
>>>> Could you try big against small1 and small2?
>>> Patch attached. But frankly, I don't like the solution (even if it
>> adopted
>>> the way it's currently handled all over the place in GEOS).
>>> The way the SegmentString class is written and used requires the user
>> of the
>>> an instance of SegmentString to take care of the deletion of the
>> embedded
>>> point array, for instance:
>>>    for ( size_t i = 0, ni = lineSegStr.size(); i < ni; i++ )
>>>        delete lineSegStr[ i ]->getCoordinates();    // <-- here
>>>        delete lineSegStr[ i ];
>>> Which is just wrong, because this could be done in a better way if
>>> SegmentString was taking care of this in the destructor. I tried to
>> fix GEOS
>>> (and the tests) in this direction, but apparently the buffers stored
>> in the
>>> SegmentString are shared in between different higher level structures
>> in
>>> addition, which makes it impossible (at least currently for me) to
>> fix that
>>> without introducing some kind of smart pointers (or investing a
>> really large
>>> amount of time, which I don't have) ...
>>> For this reason I fixed this memory leak the straightforward (and
>> ugly) way.
>>> I'm sure there are more similar bugs to recover, though :-P
>>> Regards Hartmut
>>> PS: As impressive GEOS is it convinces me once more that it's not a
>> good
>>> idea to write C++ in a way similar to Java, especially if no special
>> means
>>> of memory management (i.e. smart ptrs) are introduced.
>>>> Thanks!
>>>> Paul
>>>> On Wed, Oct 8, 2008 at 1:54 PM, Hartmut Kaiser
>>>> <hartmut.kaiser at gmail.com> wrote:
>>>>> Paul,
>>>>>> The reason I ask is because while contains and covers appear leak
>>>>>> free, intersects seems to be leaking. I'm pretty sure it's not on
>>>> the
>>>>>> PostGIS side (I think).
>>>>>> P.
>>>>>> On Wed, Oct 8, 2008 at 12:25 PM, Paul Ramsey
>>>>>> <pramsey at cleverelephant.ca> wrote:
>>>>>>> Hartmut,
>>>>>>> When you tested for leaks, did you test prepared contains,
>>>>>> intersects,
>>>>>>> covers, coversproperly? Or just one of them?
>>>>> I was using the test program as attached to the ticket (which AFAIR
>>>>> calls all of the topological attribute functions). This test
>> program
>>>>> was leak free for me. But I tried the geometries as attached to the
>>>>> ticket only either, so your leaks might show themselves with
>> certain
>>>> geometries only.
>>>>> Regards Hartmut
>>>>> _______________________________________________
>>>>> geos-devel mailing list
>>>>> geos-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
Martin Davis
(250) 383-3022
