[geos-devel] 3.0.3 To Do
Obe, Regina robe.dnd at cityofboston.gov
Fri Oct 24 11:46:02 EDT 2008
Paul,
The earlier one doesn't add any new files so may be more appropriate.
This one adds a new geostest folder to the msvc80 and geostest to the
solution to add the test that Frank was running using make.vc (that does
the test.wkt compare thing).
Note:  this geostest isn't even in trunk so I'm questioning if we really
want to include it in the geos 3.0 branch. If we do we should include it
in trunk to be consistent.
Since we already have a unit test for VC and the unit test is much
easier to use than the geostest, I question the value of adding this
extra project to the solution.
Thanks,
Regina
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Friday, October 24, 2008 11:39 AM
To: GEOS Development List
Subject: Re: [geos-devel] 3.0.3 To Do
On Thu, Oct 23, 2008 at 9:48 PM, Obe, Regina <robe.dnd at cityofboston.gov>
wrote:
> Actually which patch are you referring to.  The version one or the big
> patch.  I just redownloaded the msvc80 folder from svn that has your
version
> patch and then reapplied Sanak's patch and didn't run into any
conflicts.
this one
geos-branches-3.0-build-msvc80_add_geostest.patch
should I be doing the earlier one?
P
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
