[geos-devel] Creating an invalid geometry
Mon Oct 27 09:49:11 EDT 2008
Denise MacLeod wrote:
> Hi all -
> I am trying to work on issue #170, a memory leak when performing the
> intersection of a valid and an invalid polygon. My question is: how do I
> get an invalid polygon?  I have one in a file in WKT format, but when
> reading it in, GEOSGeomFromWKT detects that's invalid and returns a NULL
> pointer. Likewise, the WKB function has similar logic. It's too robust  :-)
> Is there anyway quick way around this, without changing the source to
> skip the validation step in GEOSGeomFromWKT?
Denise,
Presumably you can create the invalid geometries the direct geometry
creation methods:
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint(GEOSCoordSequence* s);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString(GEOSCoordSequence* s);
  * Second argument is an array of GEOSGeometry* objects.
  * The caller remains owner of the array, but pointed-to
  * objects become ownership of the returned GEOSGeometry.
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(GEOSGeometry* shell,
	GEOSGeometry** holes, unsigned int nholes);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(int type,
	GEOSGeometry* *geoms, unsigned int ngeoms);
extern GEOSGeometry GEOS_DLL *GEOSGeom_clone(const GEOSGeometry* g);
Best regards,
