[geos-devel] Fw: 3.0?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 28 00:20:37 EDT 2008
Stephen,
Can you confirm the patch helps? This is the last item pre-3.0.3 I
have to close off.
Thanks,
P.
On Sun, Oct 26, 2008 at 2:25 PM, Mark Cave-Ayland
<mark.cave-ayland at ilande.co.uk> wrote:
> On Thu, 2008-10-23 at 08:53 +0000, S Knox wrote:
>> I seem to have the issue below when building Geos 3.0.2 with Cygwin.
>> Is there a solution to this problem of double inclusion, or do I need
>> to install an older version
>> of Geos (I am reluctant to do this as I have a recent version of GCC,
>> which requires a
>> recent version of the source code to build).
>> Many thanks for your help - sorry I can't work this out for myself but
>> only just starting to build
>> things myself!
>> Regards
>> Stephen
> Hi Stephen,
> This is exactly the same problem experienced on MingW with the
> DLL_EXPORT stubs causing the inlines to be defined twice at link time.
> There is already a fix for this in the current source code for MingW, so
> in theory all we have to do is expand the check to suppress the
> duplicates when compiling with cygwin GCC as well as MingW.
> Please try the attached patch to see if will allow you to compile on
> cygwin - I've confirmed that the changes still allow GEOS to compile on
> MingW without any problems.
> HTH,
> Mark.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
