[geos-devel] Fw: 3.0?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Wed Oct 29 06:20:04 EDT 2008
> Mark,
> Sorry for the late reply, but a personal issue came up, so haven't had a
lot of time recently. After some searching, I found the following post,
and followed the instructions within to see if it would compile:
http://lists.refractions.net/pipermail/geos-devel/2007-January/002766.html
> After changing the headers as suggested in the patch, it seemed to
compile
> OK. Unfortunately I can't test the new patch right now, but should be
able
> to in about 10 hours or so when I get home.
> Many thanks for your help & I'll report back later
> Regards
> Stephen Knox
Hi Stephen,
Yeah that's exactly how the previously attached patch works, by expanding
the #if to include cygwin as well as MingW. I see that Paul has applied
the patch to 3.0 branch SVN, so you could try that or download 3.0.3RC1
and apply the patch there. If it works, I think it's minimally invasive
enough to make the 3.0.3 final release.
ATB,
Mark.
