[geos-devel] Fw: 3.0?
S Knox
roxyknox at yahoo.co.uk
Wed Oct 29 21:29:46 EDT 2008
Dear all,
I tried running compiling using the latest geos-svn.tar.gz (yesterday evening) which contained the modification mentioned below. Unfortunately it gave the same errors as before i.e:
....... multiple definition of`geos::operation::overlay
::MinimalEdgeRing::~MinimalEdgeRing()'
.libs/inlines.o:/home/Stevo/geos-3.1.0/source/../source/headers/geos/operation/overlay/MinimalEdgeRing.inl:43: first defined here
Creating library file: .libs/libgeos.dll.a
collect2: ld returned 1 exit status
make[2]: *** [libgeos.la] Error 1
make[2]: Leaving directory `/home/Stevo/geos-3.1.0/source'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/Stevo/geos-3.1.0/source'
So not sure how I got it to work on my system, looks like I've got beginners luck!
Sorry I can't help
Regards
Stephen
From: Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk>
To: S Knox <roxyknox at yahoo.co.uk>
Cc: GEOS Development List <geos-devel at lists.osgeo.org>
Sent: Wednesday, 29 October, 2008 10:20:04
Subject: Re: [geos-devel] Fw: 3.0?
> Mark,
> Sorry for the late reply, but a personal issue came up, so haven't had a
lot of time recently. After some searching, I found the following post,
and followed the instructions within to see if it would compile:
http://lists.refractions.net/pipermail/geos-devel/2007-January/002766.html
> After changing the headers as suggested in the patch, it seemed to
compile
> OK. Unfortunately I can't test the new patch right now, but should be
able
> to in about 10 hours or so when I get home.
> Many thanks for your help & I'll report back later
> Regards
> Stephen Knox
Hi Stephen,
Yeah that's exactly how the previously attached patch works, by expanding
the #if to include cygwin as well as MingW. I see that Paul has applied
the patch to 3.0 branch SVN, so you could try that or download 3.0.3RC1
and apply the patch there. If it works, I think it's minimally invasive
enough to make the 3.0.3 final release.
ATB,
Mark.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20081030/979dca8c/attachment.html
