[geos-devel] [GEOS] #205: Build problem on Solaris
GEOS geos-trac at osgeo.org
Thu Sep 4 08:16:57 EDT 2008
 Reporter:  magne       |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:
 Severity:  Unassigned  |    Keywords:
 The current svn version does not build on Solaris.
 There are a couple of small issues (missing std:: , not including clocale,
 etc.)
 I've attached a patch that seems to do the trick (I've also tested on
 Linux)
Ticket URL: <http://trac.osgeo.org/geos/ticket/205>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
