[geos-devel] Crash when buffering a geometry
Stephen Wong swongu at gmail.com
Thu Sep 11 13:50:47 EDT 2008
Paul, Any update to this bug? It sounded like you were working on a patch...
Stephen
On Mon, Aug 11, 2008 at 3:53 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> In retrospect, the problem was (surprise!) between my ears. The unit
> test harness runs in the context of a directory one lower than your
> test case directory. When I copied the test data down into the
> expected location, it ran, and failed.
> So, consider your test case confirmed on OS/X. It be broken. Now I'll
> try the patch.
> P.
> On Mon, Aug 11, 2008 at 1:41 PM, Stephen Wong <swongu at gmail.com> wrote:
> > Hi Paul,
> > Thanks for the quick response. I just ran the test again (Windows Vista,
> > 32-bit) and it doesn't get stuck on reading the WKB, so maybe it has to
> do
> > with cross-platform compatibility.  I took the WKB and converted it to
> hex,
> > so hopefully, it will work this time. I've attached it to the ticket
> > (http://trac.osgeo.org/geos/ticket/188). The file I/O operations in the
> .cpp
> > file now look like this:
> > std::ifstream fin ;
> > fin.open( "hex.ogc" ) ;
> > GeometryAPtr geom( reader_.readHEX( fin ) ) ;
> > Thanks,
> > Stephen
> > On Mon, Aug 11, 2008 at 11:42 AM, Paul Ramsey <pramsey at cleverelephant.ca
> > wrote:
> >> Stephen,
> >> When I integrate your code into my OS/X build and run the unit tests,
> >> I don't get as far as buffering...
> >> ---> group: geos::operation::BufferOp, test: test<1>
> >>     problem: unexpected exception
> >>     exception typeid: N4geos2io14ParseExceptionE
> >>     message: "ParseException: Unknown WKB type 0"
> >> Are you certain that WKB fragment is good?
> >> Paul
> >> On Fri, Aug 8, 2008 at 11:48 AM, Stephen Wong <swongu at gmail.com> wrote:
> >> > Hello,
> >> > I have found that when using BufferOp on a specific polygon, GEOS
> >> > crashes
> >> > with an assertion failure.  This failure appears to be within
> >> > RightmostEdgeFinder, and I have documented it on a ticket
> >> > (http://trac.osgeo.org/geos/ticket/188). On that ticket, I have also
> >> > provided a .zip file that reproduces the error. The surprising this is
> >> > that
> >> > the geometry is not complicated at all!
> >> > I have posted this problem in March
> >> > (see
> >> > http://lists.osgeo.org/pipermail/geos-devel/2008-March/003324.html),
> >> > but didn't get a response thus far; hopefully posting here will help.
> >> >  Thanks in advance.
> >> > Regards,
> >> > Stephen
> >> > _______________________________________________
> >> > geos-devel mailing list
> >> > geos-devel at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080911/30f65e14/attachment.html
