[geos-devel] OverlayOp JTS port
Obe, Regina robe.dnd at cityofboston.gov
Wed Sep 17 09:26:57 EDT 2008
I'm looking at the operation.overlay.OverlayOp in geos trunk
In the header it says
Last port: operation/overlay/OverlayOp.java rev. 1.23
But I don't believe this to be right since when I compare the
computeOverlay methods
against 1.2 and 1.3 versions of JTS codebase, it has an additional
EdgeNodingValidator check which wasn't introduced until later versions
of JTS.
So I'm wondering is the OverlayOp.cpp a mix of JTS versions or is the
comment above just plain wrong.
It also has a checkObviouslyWrongResult() check at the end of
computerOverlay which I haven't figured out which version that was
introduced in JTS (its not in 1.2,1.3, or 1.9).  Is this a GEOS specific
check that has no JTS equivalent?
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
