[geos-devel] RE: [postgis-devel] Geos Capi OverlayOp,	overlayOp
	question
    Mateusz Loskot
    mateusz at loskot.net
    Wed Sep 17 12:19:43 EDT 2008
Obe, Regina wrote:
> Mateusz,
>> Are you asking about the redundant "using" directive or about use of
>> "using" directive in general?
> Mostly the redundant using.
Regina,
I have to correct my response.
There is no redundant use of using directive in geos_c.cpp file.
The first using (line 89) "imports" OverlayOp class defined in line 57
of OverlayOp.h file.
The second using (line 90) does the same but for distinct
type - a functor named overlayOp and defined in OverlayOp.h line 326.
The former is starts with big "O" the latter with lower-case "o".
OverlayOp file:
http://trac.osgeo.org/geos/browser/trunk/source/headers/geos/operation/overlay/OverlayOp.h?rev=1820
So, both lines 89 and 90 are needed in file geos_c.cpp.
Sorry for confusions, I didn't notice the case of O letter at first.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
