[geos-devel] OverlayOp JTS port
Mateusz Loskot
mateusz at loskot.net
Wed Sep 17 14:14:40 EDT 2008
Obe, Regina wrote:
> I apologize for the barrage of questions. As far as I can tell the
> OverlayOp.cpp is vintage JTS 1.7 (which I think is same as the JTS
> 1.9 for this class)
> except it has the additional calls of
> checkObviouslyWrongResult() - which most of that code looks like it
> would never be called because of the #ifdefs
I'd not be that sure it is never called.
However, I'm not familiar with design of this part and I'm not sure in
what conditions ENABLE_OTHER_OVERLAY_RESULT_VALIDATORS is defined.
> except for the
> assert(resultGeom);
Regina,
It's a simple pre-condition test.
> UNREFERENCED_PARAMETER(opCode); (have no clue what this does)
Simple hack to prevent compiler from throwing warnings about unused
variables, etc.
It is only activated if ENABLE_OTHER_OVERLAY_RESULT_VALIDATORS is *not*
defined.
You can safely ignore these two lines.
> and also a elevationMatrix->elevate(resultGeom);
> which looks like will get called since USE_ELEVATION_MATRIX 1.
> Is the elevationMatrix designed to deal with 3d geometries? Didn't
> realize Union actually works with those, but then I never tried it
> with 3d.
> So I'm a little puzzled why these 2 extra function calls since I
> always thought GEOS was at best on par with JTS?
Unfortunately, I'm unable to answer these questions.
Probably Sandro Santilli knows. Anybody else?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
