[geos-devel] OverlayOp JTS port
Martin Davis mbdavis at refractions.net
Wed Sep 17 14:24:24 EDT 2008
The original plan for GEOS was that it would track JTS 100%.  This was
to simplify porting new functionality as it is added to JTS.  However,
at one point I think Sandro did some extra work on trying to improve
GEOS robustness.  This is probably where the checkObviouslyWrongResult
came from.  After this was done, JTS caught up - so this method may not
be needed any more.
Obe, Regina wrote:
> I apologize for the barrage of questions.  As far as I can tell the
> OverlayOp.cpp is vintage JTS 1.7 (which I think is same as the JTS 1.9
> for this class)
> except it has the additional calls of
> checkObviouslyWrongResult() - which most of that code looks like it
> would never
> be called because of the #ifdefs except for the
> assert(resultGeom);
> UNREFERENCED_PARAMETER(opCode); (have no clue what this does)
> and also a
> elevationMatrix->elevate(resultGeom);
> which looks like will get called since USE_ELEVATION_MATRIX 1.
> Is the elevationMatrix designed to deal with 3d geometries?  Didn't
> realize
> Union actually works with those, but then I never tried it with 3d.
> So I'm a little puzzled why these 2 extra function calls since I
> always thought
> GEOS was at best on par with JTS?
> Thanks,
> Regina
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org on behalf of Obe, Regina
> Sent: Wed 9/17/2008 9:26 AM
> To: GEOS Development List
> Subject: [geos-devel] OverlayOp JTS port
> I'm looking at the operation.overlay.OverlayOp in geos trunk
> In the header it says
> Last port: operation/overlay/OverlayOp.java rev. 1.23
> But I don't believe this to be right since when I compare the
> computeOverlay methods
> against 1.2 and 1.3 versions of JTS codebase, it has an additional
> EdgeNodingValidator check which wasn't introduced until later versions
> of JTS.
> So I'm wondering is the OverlayOp.cpp a mix of JTS versions or is the
> comment above just plain wrong.
> It also has a checkObviouslyWrongResult() check at the end of
> computerOverlay which I haven't figured out which version that was
> introduced in JTS (its not in 1.2,1.3, or 1.9).  Is this a GEOS specific
> check that has no JTS equivalent?
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
