[geos-devel] Unclear objects lifetime and ownership issues in
Monotone Chain components
Obe, Regina
robe.dnd at cityofboston.gov
Thu Sep 25 07:10:48 EDT 2008
Mark,
> If I had a choice then it would be to spend the time re-engineering
> Martin's JTS concepts/ideas into an algorithmic form which is friendly
> to the language it is being written in, rather than trying to hack in
> pointer reference counting. Work with the language, not against it.
Sounds almost like you are asking for a domain-language for spatial to
write a meta-program which would
write JTS and GEOS. Does such a domain-language exist already? Sounds
intriguing. I love code generators.
I wonder if this is as difficult as it sounds on the surface.
I would much more trust a computer to do bean counting than a human if
we could codify what constructs require bean counting and which don't.
I imagine such a language would look more like JTS, but with fewer
constructs to prevent
people from swaying off the beaten path without enhancing the
domain-language.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
