[geos-devel] Unclear objects lifetime and ownership issues in Monotone Chain components
Martin Davis mbdavis at refractions.net
Thu Sep 25 11:43:29 EDT 2008
Why not just use GCJ?  It compiles Java to object code.  That gives the
best of both worlds.
There may well be languages which allow expression of algorithms at a
higher level than Java (Ruby or Haskell come to mind).  Developing such
a language from scratch is a *huge* undertaking.  And don't forget,
development is about more than just the language - it's about an entire
ecosystem of IDEs, Profilers, external libs, linkers, runtime engines,
etc.  It takes years to get a language to this level of maturity, and
it's also not possible to do in isolation from the rest of the
community, IMO - to get true maturing and refinement you need input from
probably thousands of developers.
Obe, Regina wrote:
>  Mark,
>> If I had a choice then it would be to spend the time re-engineering
>> Martin's JTS concepts/ideas into an algorithmic form which is friendly
>> to the language it is being written in, rather than trying to hack in
>> pointer reference counting. Work with the language, not against it.
> Sounds almost like you are asking for a domain-language for spatial to
> write a meta-program which would
> write JTS and GEOS.  Does such a domain-language exist already? Sounds
> intriguing.  I love code generators.
> I wonder if this is as difficult as it sounds on the surface.
> I would much more trust a computer to do bean counting than a human if
> we could codify what constructs require bean counting and which don't.
> I imagine such a language would look more like JTS, but with fewer
> constructs to prevent
> people from swaying off the beaten path without enhancing the
> domain-language.
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
