[geos-devel] Something wrong with GEOSEnvelope function in 3.1.0?
Obe, Regina
robe.dnd at cityofboston.gov
Tue Apr 14 23:40:16 EDT 2009
LiN,
Actually I looked at the bug tracker, and this appears to be an already reported bug so you are right I think.
http://trac.osgeo.org/geos/ticket/160
In a mythical world the bounding box of a horizontal line would be a polygon where the top and bottom are the same line, but evidentally not the world we live in :)
Though the test example in bug tracker was using PostGIS so not sure what that version was since PostGIS doesn't even use GEOS for that function (or at least not anymore and that particular bug example works correctly in PostGIS 1.3.5+)
Thanks,
Regina
-----Original Message-----
From: geos-devel-bounces at lists.osgeo.org on behalf of Obe, Regina
Sent: Tue 4/14/2009 11:05 PM
To: GEOS Development List
Subject: [geos-devel] Something wrong with GEOSEnvelope function in 3.1.0?
LiN ,
I'm using GEOS 3.1.0 as well. However on further inspection it looks like PostGIS uses its own implementation of Envelope and not the GEOS one, so you could very well be right that there is something wrong with that GEOS function.
Unfortunately I don't know enough about GEOS to test it apart from PostGIS.
Maybe Mateusz or Sandro or Paul can confirm the issue.
Thanks,
Regina
From: geos-devel-bounces at lists.osgeo.org on behalf of LiN YongHeng
Sent: Tue 4/14/2009 10:35 PM
To: geos-devel at lists.osgeo.org
Subject: [geos-devel] Re: geos-devel Digest, Vol 78, Issue 11
Hi Regina,
The GEOS' Version I used is "3.1.0". Today, I use
GEOSEnvelop("LINESTRING(1 3,1 6)") again, what a pity, it don't return the
result like what you said. In my program, the result is "POLYGON ((1 3, 1
3, 1 6, 1 6, 1 3))". So I want to ask you which version of GEOS are you
using?
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090414/073043c6/attachment.html
