[geos-devel] GEOS, Shapely, DLLs, and memory
Charlie Savage
cfis at savagexi.com
Mon Apr 27 15:44:02 EDT 2009
Hi Aron,
> From what we can tell our application was crashing
> because memory that was being allocated in the GEOS dll was being
> released inside of our application. When converting a GEOS geometry
> object to a string, Shapely calls GEOSGeomToWKT_r which creates a char
> buffer using std::malloc. After the call Shapely releases the memory
> using the standard free function. According to a "Potential Errors
> Passing CRT Objects Across DLL Boundaries" [1]:
Yup, you can't do that. The GEOS api has to provide a way of freeing
the buffer (just like your patch adds).
> I have attached a patch for both GEOS and Shapely that we have been
> testing with for a few weeks without any problems. Does anyone have a
> better way to address this issue?
If you build Shapely (and Geos) using VC++ in Debug mode with assertions
on (-RTC1 off the top of my head), then VC will raise assertions errors
on problems like this. Its a lot easier to find them that way.
Charlie
Charlie Savage
http://cfis.savagexi.com
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20090427/8a98f6d6/smime.bin
