[geos-devel] GEOS, Shapely, DLLs, and memory
Aron Bierbaum
aronbierbaum at gmail.com
Mon Apr 27 16:39:23 EDT 2009
I have added a ticket for the issue. I was not sure exactly you wanted
for the version or milestone fields, but I gave it a shot.
http://trac.osgeo.org/geos/ticket/249
Thanks,
Aron
On Mon, Apr 27, 2009 at 3:17 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> In that case, Aron, can you put your GEOS patch into a Trac issue
> (http://trac.osgeo.org/geos) for us to put into the next release.
> Thanks,
> P.
> On Mon, Apr 27, 2009 at 12:46 PM, Charlie Savage <cfis at savagexi.com> wrote:
>> Paul Ramsey wrote:
>>> On Mon, Apr 27, 2009 at 11:47 AM, Aron Bierbaum <aronbierbaum at gmail.com>
>>> wrote:
>>>> I have attached a patch for both GEOS and Shapely that we have been
>>>> testing with for a few weeks without any problems. Does anyone have a
>>>> better way to address this issue?
>>> Pretty simple patch... more C-API changes. Hmm. Perhaps GEOS 3.2 will
>>> be out sooner than one might expect.
>>> I don't have the smarts to know if there's a better way.
>> There isn't. For every piece of memory GEOS allocates and returns via the
>> capi (or C++ api), it must provide a function to free it.
>> If you are using C++ you can get around it by providing a memory deallocator
>> for objects returned from GEOS (say for std::string in this case) but for C
>> you obviously can't do that.
>> Charlie
>> Charlie Savage
>> http://cfis.savagexi.com
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
