[geos-devel] Missing files in geos-3.1.1.tar.bz2
Obe, Regina robe.dnd at cityofboston.gov
Thu Dec 10 09:57:50 EST 2009
Paul,
Can't answer your other questions, but IsValidReason is definitely in 3.2 (I think it was in 3.1 as well) since PostGIS has been leveraging it since PostGIS 1.4 which shipped with 3.1
Hope that helps,
Regina
From: geos-devel-bounces at lists.osgeo.org [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Meems
Sent: Thursday, December 10, 2009 6:45 AM
To: GEOS Development List
Subject: Re: [geos-devel] Missing files in geos-3.1.1.tar.bz2
As suggested I've moved over to geos-3.2.0rc4.
And it is compiling fine.
I did notice the resulting geos_c.dll does not have any version numbers in Windows.
Will that be fixed in the Stable Release?
Or can I fix that myself in the VS2008 files?
We used to have two folders with GEOS source code. One for 32Bit and the other for 64Bit.
With GDAL 1.6.2 we've managed to merge those folders and have a more extended makefile which handles the build of 32/64Bit.
Will that also be possible with the GEOS library?
I'm no expert on makefiles but I could use the gdal makefile as an example.
I have one last question (for now ;)).
We use the IsValid() method to check shapes in a shapefile. Currently it only return false if invalid but not the reason. Is that been added in 3.2.0rc4 or is that for a future version?
Thank you all for your hard work.
With regards,
Paul Meems
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org<http://www.mapwindow.org/>
2009/12/8 Mateusz Loskot <mateusz at loskot.net<mailto:mateusz at loskot.net>>
Obe, Regina wrote:
> Paul,
> Geos 3.1.1 had missing files for VS.  I believe if you pull from SVN
> you get all the missing files.
Yes, it should be fixed in the trunk:
http://trac.osgeo.org/geos/ticket/303
So, we have 3 solutions [1] in the trunk available for Visual C++ 2005,
2008 and 2010. In future, I believe it would be reasonable to move
completely to CMake, so we no longer need to manually maintain
Visual C++ projects manually.
[1] http://trac.osgeo.org/geos/browser/trunk/build/README?rev=2800
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
geos-devel mailing list
geos-devel at lists.osgeo.org<mailto:geos-devel at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geos-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20091210/9742763a/attachment.html
