[geos-devel] 3.2.0 Final
Barend Gehrels Barend.Gehrels at geodan.nl
Sat Dec 12 06:47:47 EST 2009
> The C Api wraps a small portion of the C++ API.
> The thing is that in C++ there are *a lot* of interfaces
> exposed which should not be.
> You might have noticed that many of the headers were not
> installed up to 3.1.x. This was an attempt to reduce the
> set of exposed interface.
> Remember that GEOS is a direct port of JTS, where (in Java)
> there are visibility levels that are not supported in C++
> (default visibility == only classes in same package can use
> those interfaces). In GEOS those all became public instead.
Thanks, this explanation is much more clear than the "prefer troubles"
statement. I think Frank's suggested wording is perfect.
On the friend discussion: you can probably put those not-to-be-exposed
interfaces in a namespace like "detail", or "impl", or "not_exposed".
That will prevent normal C++ programmers from using it, without the
drawbacks of friends. The interfaces are technically not hidden then,
but it is clear they are not recommended.
Regards, Barend
