[geos-devel] C API coordinate sequence dimensions
Sean Gillies
sgillies at frii.com
Mon Jan 12 13:04:22 EST 2009
So, the dimension argument in GEOSCoordSeq_create is ignored unless
the active sequence implementation takes dimensions other than 3?
Why is GEOS's default sequence 3D when all operations are 2D?
Sean
On Jan 12, 2009, at 10:56 AM, Martin Davis wrote:
> Actually JTS implements this correctly. The return value from
> getDimension is computed by the implementation of
> CoordinateSequence. In the case of DefaultCoordinateSequence (which
> by the way is deprecated and replaced by CoordinateArraySequence)
> the value is alway 3, since the Coordinate representation used by
> these sequences always allows for 3 ordinates.
> In the case of PackedCoordinateSequence the dimension can be
> selected on creation, and this is the value that is returned by
> getDimension.
> Sanak wrote:
>> Hi list,
>> I don't know that this is a known bug, but
>> CoordinateArraySequence.getDimension() method always return 3.
>> [trunk/source/headers/geos/geom/CoordinateArraySequence.h - line 88]
>> size_t getDimension() const { return 3; }
>> JTS(JTS Topology Suite) seems to be also the same.
>> [jts/src/com/vividsolutions/jts/geom/DefaultCoordinateSequence.java
>> - line 95]
>> public int getDimension() { return 3; }
>> I don't know that this is a specification or not...
>> Regards,
>> Sanak.
>> 2009/1/12 Sean Gillies <sgillies at frii.com <mailto:sgillies at frii.com>>
>> I'm finding that GEOSCoordSeq_getDimensions returns 3 no matter
>> what
>> # Accessing libgeos_c via Python ctypes
>> >>> s = lgeos.GEOSCoordSeq_create(2, 2)
>> >>> ndim = c_int()
>> >>> lgeos.GEOSCoordSeq_getDimensions(s, byref(ndim))
>> 1
>> >>> ndim
>> c_long(3)
>> Is this a known bug? Looks like we're only testing creation of 3D
>> coordinate sequences in
>> http://trac.osgeo.org/geos/browser/trunk/tests/unit/capi/GEOSCoordSeqTest.cpp
>> Sean Gillies
>> http://sgillies.net
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
Sean Gillies
sean.gillies at gmail.com
http://sgillies.net
