[geos-devel] C API coordinate sequence dimensions
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jan 12 13:40:09 EST 2009
Not all operations are 2D, just 99% of them. Some of the overlay ops
try to compute "correct" derived Z-values.
P
On Jan 12, 2009, at 10:04 AM, Sean Gillies wrote:
> So, the dimension argument in GEOSCoordSeq_create is ignored unless
> the active sequence implementation takes dimensions other than 3?
> Why is GEOS's default sequence 3D when all operations are 2D?
> Sean
> On Jan 12, 2009, at 10:56 AM, Martin Davis wrote:
>> Actually JTS implements this correctly. The return value from
>> getDimension is computed by the implementation of
>> CoordinateSequence. In the case of DefaultCoordinateSequence
>> (which by the way is deprecated and replaced by
>> CoordinateArraySequence) the value is alway 3, since the Coordinate
>> representation used by these sequences always allows for 3 ordinates.
>> In the case of PackedCoordinateSequence the dimension can be
>> selected on creation, and this is the value that is returned by
>> getDimension.
>> Sanak wrote:
>>> Hi list,
>>> I don't know that this is a known bug, but
>>> CoordinateArraySequence.getDimension() method always return 3.
>>> [trunk/source/headers/geos/geom/CoordinateArraySequence.h - line 88]
>>> size_t getDimension() const { return 3; }
>>> JTS(JTS Topology Suite) seems to be also the same.
>>> [jts/src/com/vividsolutions/jts/geom/
>>> DefaultCoordinateSequence.java - line 95]
>>> public int getDimension() { return 3; }
>>> I don't know that this is a specification or not...
>>> Regards,
>>> Sanak.
>>> 2009/1/12 Sean Gillies <sgillies at frii.com
>>> <mailto:sgillies at frii.com>>
>>> I'm finding that GEOSCoordSeq_getDimensions returns 3 no matter
>>> what
>>> # Accessing libgeos_c via Python ctypes
>>> >>> s = lgeos.GEOSCoordSeq_create(2, 2)
>>> >>> ndim = c_int()
>>> >>> lgeos.GEOSCoordSeq_getDimensions(s, byref(ndim))
>>> 1
>>> >>> ndim
>>> c_long(3)
>>> Is this a known bug? Looks like we're only testing creation of 3D
>>> coordinate sequences in
>>> http://trac.osgeo.org/geos/browser/trunk/tests/unit/capi/GEOSCoordSeqTest.cpp
>>> Sean Gillies
>>> http://sgillies.net
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
> Sean Gillies
> sean.gillies at gmail.com
> http://sgillies.net
Paul Ramsey
+1 250 885 0632
