[geos-devel] [GEOS] #275: Topology Exception on valid geometries
Martin Davis mbdavis at refractions.net
Mon Jul 6 12:44:40 EDT 2009
This works in JTS.
>  Reporter:  yabo        |       Owner:  geos-devel at lists.osgeo.org
>      Type:  defect      |      Status:  new
>  Priority:  major       |   Milestone:  3.1.1
> Component:  Default     |     Version:  svn-trunk
>  Severity:  Unassigned  |    Keywords:
>  Hi,
>  I've encoutered a situation where two valid geometries (as stated by
>  IsValidOp) throw a Topology Exception when being unioned. The first
>  geometry is a MultiPolygon and the second a Polygon. Unfortunately I
>  couldn't shrink the geometries down to a human-parsable size.
>  I have this problem with both geos-3.1.0 and geos-svn-trunk.
>  The reported error is :
>  TopologyException: found non-noded intersection between -3138.99 39.9929,
>  -3195.93 131.777 and -3145.05 62.5969, -3138.99 39.9929 -3138.99 39.9929
>  I've attached the test program source to the ticket.
>  Thanks,
> geos-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
