[geos-devel] [GEOS] #275: Topology Exception on valid geometries
strk
strk at keybit.net
Mon Jul 6 13:32:00 EDT 2009
On Mon, Jul 06, 2009 at 09:44:40AM -0700, Martin Davis wrote:
> This works in JTS.
It works in trunk too when converted to an XML testcase.
I'll update the trac issue ASAP. Martin: I'd appreciate if
you could follow up there. TIA.
--strk;
> > Reporter: yabo | Owner: geos-devel at lists.osgeo.org
> > Type: defect | Status: new
> > Priority: major | Milestone: 3.1.1
> >Component: Default | Version: svn-trunk
> > Severity: Unassigned | Keywords:
> > Hi,
> > I've encoutered a situation where two valid geometries (as stated by
> > IsValidOp) throw a Topology Exception when being unioned. The first
> > geometry is a MultiPolygon and the second a Polygon. Unfortunately I
> > couldn't shrink the geometries down to a human-parsable size.
> > I have this problem with both geos-3.1.0 and geos-svn-trunk.
> > The reported error is :
> > TopologyException: found non-noded intersection between -3138.99 39.9929,
> > -3195.93 131.777 and -3145.05 62.5969, -3138.99 39.9929 -3138.99 39.9929
> > I've attached the test program source to the ticket.
> > Thanks,
