[geos-devel] [GEOS] #275: Topology Exception on valid geometries
Martin Davis
mbdavis at refractions.net
Mon Jul 6 14:04:32 EDT 2009
strk,
I'm unable to login to the GEOS trac right now, so I'm following up on
the list.
I didn't build an actual test case, I just tried it in the TestBuilder.
But adding this as a test case is a good idea!
strk wrote:
> On Mon, Jul 06, 2009 at 09:44:40AM -0700, Martin Davis wrote:
>> This works in JTS.
> It works in trunk too when converted to an XML testcase.
> I'll update the trac issue ASAP. Martin: I'd appreciate if
> you could follow up there. TIA.
> --strk;
>>> Reporter: yabo | Owner: geos-devel at lists.osgeo.org
>>> Type: defect | Status: new
>>> Priority: major | Milestone: 3.1.1
>>> Component: Default | Version: svn-trunk
>>> Severity: Unassigned | Keywords:
>>> Hi,
>>> I've encoutered a situation where two valid geometries (as stated by
>>> IsValidOp) throw a Topology Exception when being unioned. The first
>>> geometry is a MultiPolygon and the second a Polygon. Unfortunately I
>>> couldn't shrink the geometries down to a human-parsable size.
>>> I have this problem with both geos-3.1.0 and geos-svn-trunk.
>>> The reported error is :
>>> TopologyException: found non-noded intersection between -3138.99 39.9929,
>>> -3195.93 131.777 and -3145.05 62.5969, -3138.99 39.9929 -3138.99 39.9929
>>> I've attached the test program source to the ticket.
>>> Thanks,
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
