[geos-devel] [GEOS] #276: "make check" failed at geos_unit on mingw
geos-trac at osgeo.org
Wed Jul 8 13:45:34 EDT 2009
Reporter: sanak | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.2.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords: mingw
"make check" failed(crushed) at geos_unit on mingw as following
versions.[[BR]]
- svn-trunk(r2610)[[BR]]
- 3.1.1(tar.bz2)[[BR]]
- 3.0.4(tar.bz2)[[BR]]
After remove "-O2" option from CXXFLAGS in tests/unit/Makefile,
and remove all object files(*.o) in tests/unit folder, then execute "make
check" again, geos_unit can execute normally, and all tests passed.
Regards,
Ticket URL: <http://trac.osgeo.org/geos/ticket/276>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
