[geos-devel] Re: [GEOS] #276: "make check" failed at geos_unit on mingw
GEOS geos-trac at osgeo.org
Mon Jul 13 11:25:50 EDT 2009
 Reporter:  sanak       |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.2.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:  mingw       |
Comment (by pramsey):
 I'm not sure how to address this, the flags are inherited from the lower
 level Makefile. You could compile the whole suite w/o optimization or just
 not compile w/ 'check'. Do you have a patch?
Ticket URL: <http://trac.osgeo.org/geos/ticket/276#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
