[geos-devel] Re: [postgis-devel] st_intersect crasher
David Fuhry
dfuhry at acm.org
Tue Jul 14 19:27:05 EDT 2009
Mark,
Thanks for the coverage. After checking, I'm pretty sure now that
the GEOS 3.1.1 used below is the release version (not from svn).
I'm willing to try geos svn then bisect, but automake is failing on
my Debian system:
~/geos$ ./autogen.sh
* Running /usr/bin/libtoolize (1.5.22)
\tOPTIONS = --force --copy
You should add the contents of `/usr/share/aclocal/libtool.m4' to
`aclocal.m4'.
* Running /usr/bin/aclocal (1.4-p6)
* Running /usr/bin/autoheader (2.61)
* Running /usr/bin/automake (1.4-p6)
\tOPTIONS = --add-missing --copy
automake: configure.in: installing `./install-sh'
automake: configure.in: installing `./mkinstalldirs'
automake: configure.in: installing `./missing'
configure.in: 40: required file `./[source/headers/config.h].in' not found
configure.in: 40: required file `./[source/headers/stamp-h1.in' not found
configure.in: 40: required file `./[source/headers/geos/platform.h].in'
not found
configure.in: 40: required file `./[source/headers/geos/stamp-h2.in' not
found
capi/Makefile.am:10: invalid variable `nodist_capi_HEADERS'
source/operation/buffer/Makefile.am:7: variable `NULL' not defined
automake: source/operation/overlay/Makefile.am: not supported: source
file `snap/GeometrySnapper.cpp' is in subdirectory
automake: tests/xmltester/Makefile.am: not supported: source file
`markup/MarkupSTL.h' is in subdirectory
Something went wrong, giving up!
-Dave
Mark Cave-Ayland wrote:
> David Fuhry wrote:
>> The attached SELECT ST_Intersect(..., ...); query crashes
>> POSTGIS="1.3.5" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
>> 2008" USE_STATS, on Linux. That GEOS build might be from svn.
>> It does not crash POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel.
>> 4.6.0, 21 Dec 2007" USE_STATS. (Or POSTGIS="1.3.3"
>> GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.1, 21 August 2008" USE_STATS).
>> It's between two POLYGONs. They both pass isvalid(). If the order of
>> the two arguments is reversed (putting small geom before large geom),
>> it succeeds.
>> -Dave
> Hmmm works for me on 1.3.7SVN and 1.4 with both GEOS 3.0.0 and GEOS 3.1.1:
> postgis13=# select
> st_astext(st_intersection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
16
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
34
> 1FD01643F225061C11C4723C35B6753416CA84637EC4F61C1550393935B6753418648346FA74F61C1A1DE77BA5C67534165E77368654F61C19F5864815C6753411A82E18C494F61C1BF95DA645C6753414044714D434F61C190C51CB05B675341313FAD80374F61C17C09ADDF5B675341FC0EBD5B1E4F61C17C09ADDF5B67534131A4214F1A4F61C17C09ADDF5B6753414CB4FDE6014F61C17C09ADDF5B675341183E2699DD4E61C17C09ADDF5B675341183E2699DD4E61C1936100EF40675341911027E1E64E61C1B6DC31FA42675341117550E2E14E61C1E28739081B675341DE000DF9D54E61C1630E5355FA6653415C3A9928E04E61C1DA16716EDF6653414B807AE8DF4E61C115180E88D0665341'::geometry,
> '0103000020C90E00000100000005000000BA3EBFC9C15061C13B0DA5F73665534143ABD512C45061C156150CF836655341FF580514C45061C1AABB0D094A655341D183E9CAC15061C10768A3084A655341BA3EBFC9C15061C13B0DA5F736655341'::geometry));
> st_astext
> GEOMETRYCOLLECTION EMPTY
> (1 row)
> You might like to try updating your GEOS SVN snapshot and trying again.
> If it still fails, it would be handy if you could do a bisection on GEOS
> SVN to find out where the failure was introduced.
> ATB,
> Mark.
