[geos-devel] Re: Computational Geometry Problem
Sanak Goe geosanak at gmail.com
Sun Jul 19 08:24:34 EDT 2009
Skipped content of type multipart/alternative-------------- next part --------------
#include <locale.h>
#include <iostream>
#include <vector>
#include <algorithm>
#include <stdexcept>
#include <map> // added by sanak 2009.07.19
#ifdef _MSC_VER
#include <io.h>
#endif // _MSC_VER
//Geos
#include <geos_c.h>
#include <geos/algorithm/CGAlgorithms.h>
#include <geos/algorithm/HCoordinate.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateArraySequence.h>
#include <geos/geom/LineString.h>
#include <geos/geom/MultiPoint.h>
#include <geos/geom/Point.h>
#include <geos/geom/Polygon.h>
#include <geos/io/WKTReader.h>
#include <geos/io/WKTWriter.h>
// <-- modified by sanak 2009.07.19
//const double epsilonArea = 100.0;
const double epsilonRadius = 0.1;
// --> modified by sanak 2009.07.19
// <-- Boost code
template < class BidirectionalIterator >
bool next_combination ( BidirectionalIterator first1 ,
  BidirectionalIterator last1 ,
  BidirectionalIterator first2 ,
  BidirectionalIterator last2 )
  if (( first1 == last1 ) || ( first2 == last2 )) {
    return false ;
  BidirectionalIterator m1 = last1 ;
  BidirectionalIterator m2 = last2 ; --m2;
  while (--m1 != first1 && !(* m1 < *m2 )){
  bool result = (m1 == first1 ) && !(* first1 < *m2 );
  if (! result ) {
    while ( first2 != m2 && !(* m1 < * first2 )) {
      ++ first2 ;
    first1 = m1;
    std :: iter_swap (first1 , first2 );
    ++ first1 ;
    ++ first2 ;
  if (( first1 != last1 ) && ( first2 != last2 )) {
    m1 = last1 ; m2 = first2 ;
    while (( m1 != first1 ) && (m2 != last2 )) {
      std :: iter_swap (--m1 , m2 );
      ++ m2;
    std :: reverse (first1 , m1 );
    std :: reverse (first1 , last1 );
    std :: reverse (m2 , last2 );
    std :: reverse (first2 , last2 );
  return ! result ;
bool next_combination ( BidirectionalIterator first ,
  BidirectionalIterator middle ,
  BidirectionalIterator last )
  return next_combination (first , middle , middle , last );
// Boost Code -->
bool computeIncircle(
					 const geos::geom::Polygon* poly,
					 const geos::geom::Polygon* negbuf,
					 geos::geom::Coordinate& center,
					 double& radius)
	radius = 0.0;
	if (negbuf == NULL)
		negbuf = poly;
	try
		if (!negbuf->isValid())
			throw std::runtime_error("Invalid polygon.");
		if (negbuf->getNumInteriorRing() > 0)
			throw std::runtime_error("This sample only supports non-holes polygon.");
		const geos::geom::LineString* shell = negbuf->getExteriorRing();
		geos::geom::CoordinateArraySequence* coords = static_cast<geos::geom::CoordinateArraySequence*>(shell->getCoordinates());
		// compute orientation of ring
		if (!geos::algorithm::CGAlgorithms::isCCW(coords))
			coords->reverse(coords);
		// compute angle bisector of every  continuous three points in polygon
		size_t cnt = coords->size() - 1;
		//std::vector<geos::algorithm::HCoordinate*> bisects;
		std::vector<size_t> bisectids;
		std::map<size_t, geos::algorithm::HCoordinate*> bisects;
		for (size_t i = 0; i < cnt; i++)
			size_t prev = (i == 0) ? cnt - 1 : i - 1;
			size_t curr = i;
			size_t next = (i == cnt - 1) ? 0 : i + 1;
			// <-- JTS 1.10 Code
			geos::geom::Coordinate a = coords->getAt(prev);
			geos::geom::Coordinate b = coords->getAt(curr);
			geos::geom::Coordinate c = coords->getAt(next);
			double len0 = b.distance(a);
			double len2 = b.distance(c);
			double frac = len0 / (len0 + len2);
			double dx = c.x - a.x;
			double dy = c.y - a.y;
			geos::geom::Coordinate splitPt = geos::geom::Coordinate(a.x + frac * dx, a.y + frac * dy);
			// --> JTS 1.10 Code
			//bisects.push_back(new geos::algorithm::HCoordinate(b, splitPt));
			bisectids.push_back(i);
			bisects.insert(std::pair<size_t, geos::algorithm::HCoordinate*>(i, new geos::algorithm::HCoordinate(b, splitPt)));
		// get intersection points of angle bisectors
		geos::geom::CoordinateArraySequence intsects;
		do
			//geos::algorithm::HCoordinate* hc0 = bisects[0];
			//geos::algorithm::HCoordinate* hc1 = bisects[1];
			geos::algorithm::HCoordinate* hc0 = bisects[bisectids[0]];
			geos::algorithm::HCoordinate* hc1 = bisects[bisectids[1]];
			geos::algorithm::HCoordinate* hcoord = new geos::algorithm::HCoordinate(*hc0, *hc1);
			try
				// get intersection
				geos::geom::Coordinate coord = geos::geom::Coordinate(hcoord->getX(), hcoord->getY());
				// TODO:remove duplicate point
				intsects.add(coord);
			catch (std::exception& ex)
				// no intersection
			if (hcoord)
				delete hcoord;
		//while (next_combination(bisects.begin(), bisects.begin() + 2, bisects.end()));
		while (next_combination(bisectids.begin(), bisectids.begin() + 2, bisectids.end()));
		// clean up
		if (bisects.size() > 0)
			std::cout << "bissects ok." << std::endl;
			//std::vector<geos::algorithm::HCoordinate*>::iterator it;
			//for (it = bisects.begin(); it != bisects.end(); it++)
			//	delete *it;
			std::map<size_t, geos::algorithm::HCoordinate*>::iterator it;
				delete it->second;
		else
		std::cout << "No bissects." << std::endl;
		std::cout << "intsects.size()" << intsects.size() <<  std::endl;
		if (intsects.size() > 0)
			std::cout << "intsects ok." << std::endl;
			geos::geom::Point* incenter = NULL;
			geos::geom::GeometryFactory factory;
			const geos::geom::LineString* line = poly->getExteriorRing();
			//geos::geom::MultiPoint* rcpoints = factory.createMultiPoint(intsects); // for debug
			std::vector<geos::geom::Coordinate*>::iterator it;
			for (size_t i = 0; i < intsects.size(); i++)
				geos::geom::Coordinate coord = intsects[i];
				// exclude points that are outer of polygon
				if (geos::algorithm::CGAlgorithms::isPointInRing(coord, coords))
					geos::geom::Point* point = factory.createPoint(coord);
					// compute distance from every candidates of centres to polygon, and choose largest one
					double distance = line->distance(point);
					if (radius < distance)
						radius = distance;
						incenter = point;
				//else std::cout << "Point not in Ring." << std::endl;
			if (incenter != NULL && radius != 0.0)
					geos::io::WKTWriter writer;
					std::cout << "wkt : " << writer.write(incenter) << std::endl;
					std::cout << "radius : " << radius << std::endl;
				center.x = incenter->getX();
				center.y = incenter->getY();
				//return true; // deleted by sanak 2009.07.19
			// <-- added by sanak 2009.07.19
			else
				geos::geom::Point* intPt = negbuf->getInteriorPoint();
				center.x = intPt->getX();
				center.y = intPt->getY();
				radius = line->distance(intPt);
			return true;
			// --> added by sanak 2009.07.19
		else
			std::cout << "No intsects." << std::endl;
			throw std::runtime_error("Couldn't get incenter.");
		std::cerr << "Exception : " << ex.what() << std::endl;
		throw ex;
		return false;
	return false;
int main(int argc, char* argv[])
	// check stdin
#ifdef _MSC_VER
	if (::_isatty(fileno(stdin)))
#else
	if (::isatty(fileno(stdin)))
#endif // _MSC_VER
		std::cerr << "Usage: %s < [wktfile(polygon)]" << std::endl;
		return -1;
	std::string line;
	geos::io::WKTReader reader;
        std::vector<geos::geom::Polygon*> g;
	while (getline(std::cin, line, '\n'))
		//std::cout << line << std::endl;
		geos::geom::Polygon* geom =
		static_cast<geos::geom::Polygon*>(reader.read(line));
		if (geom == NULL && geom->getGeometryType() != "Polygon")
			throw std::runtime_error("This sample only supports polygon geometry");
		geos::geom::Polygon* poly = static_cast<geos::geom::Polygon*>(geom);
		if (!poly->isValid())
		if (poly->getNumInteriorRing() > 0)
		g.push_back(poly);
	try
		for (int i=0 ; i < g.size(); ++i)
			geos::geom::Polygon* negbuf = NULL;
			double prevRadius = 0.0; // added by sanak 2009.07.19
			while (true)
				geos::geom::Coordinate center;
				double radius = 0.0;
				if (computeIncircle(g[i], negbuf, center, radius))
					//negbuf = static_cast<geos::geom::Polygon*>(g[i]->buffer(-radius));
					//if (negbuf == NULL && negbuf->getGeometryType() != "Polygon")
					//	// TODO:
					//	throw std::runtime_error("Intercepted!!!!!!!");
					//double area = negbuf->getArea();
					//if (area < epsilonArea)
					geos::geom::Geometry* buf = g[i]->buffer(-(radius));
					std::string buftype = buf->getGeometryType();
					if (buftype == "Polygon")
						negbuf = static_cast<geos::geom::Polygon*>(buf);
					else if (buftype == "MultiPolygon")
						size_t cnt = buf->getNumGeometries();
						double maxradius = 0.0;
						double tmpradius = 0.0;
						geos::geom::Coordinate tmpcenter;
						for (size_t j = 0; j < cnt; j++)
							const geos::geom::Polygon* item = static_cast<const geos::geom::Polygon*>(buf->getGeometryN(j));
							if (computeIncircle(g[i], item, tmpcenter, tmpradius))
								if (tmpradius > maxradius)
									negbuf = static_cast<geos::geom::Polygon*>(item->clone());
									center = tmpcenter;
									radius = tmpradius;
									maxradius = tmpradius;
					if ((radius - prevRadius) < epsilonRadius)
						std::cout << "center : " << center.toString() << std::endl;
						geos::geom::Point* centerPt = factory.createPoint(center);
						geos::geom::Geometry* incircle = centerPt->buffer(radius);
						std::cout << "wkt : " << writer.write(incircle) << std::endl;
						//return 0;
						break;
					prevRadius = radius; // added by sanak 2009.07.19
				else
					std::cout << "Could not compute!" << std::endl;
					return -2;
		return -3;
	return 0;
