[geos-devel] geos svn
Jo
doublebyte at gmail.com
Sun Jul 19 18:10:01 EDT 2009
Latest SVN version of geos seems to be incomplete: no libtool and
lt-main.sh.
Also, the nightly release appears to be a broken tar file (at least I cannot
open it in my pc)...
cheers,
Jo
2009/7/19 <geos-devel-request at lists.osgeo.org>
> Send geos-devel mailing list submissions to
> geos-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geos-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geos-devel digest..."
> Today's Topics:
> 1. Computational Geometry Problem (Jo)
> Message: 1
> Date: Sun, 19 Jul 2009 22:56:53 +0100
> From: Jo <doublebyte at gmail.com>
> Subject: [geos-devel] Computational Geometry Problem
> To: geos-devel at lists.osgeo.org
> Message-ID:
> <23ab5f0a0907191456l5f8d648i4dce9666abf3dcf8 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi Sanak,
> Thanks a lot for the modified code: it worked on perfection!
> Here is a screenshot of a run with my shapefile:
> http://ladybug.no-ip.org/files/inCircleFinal.png
> Have a good rest of the weekend!
> Jo
> > Today's Topics:
> > 1. Re: Re: Computational Geometry Problem (Sanak Goe)
> > Message: 1
> > Date: Sun, 19 Jul 2009 21:24:34 +0900
> > From: Sanak Goe <geosanak at gmail.com>
> > Subject: Re: [geos-devel] Re: Computational Geometry Problem
> > To: GEOS Development List <geos-devel at lists.osgeo.org>
> > Message-ID:
> > <5f9be0a0907190524n5a8de434y38731cf04e7770d0 at mail.gmail.com>
> > Skipped content of type multipart/alternative-------------- next part
> > #include <locale.h>
> > #include <iostream>
> > #include <vector>
> > #include <algorithm>
> > #include <stdexcept>
> > #include <map> // added by sanak 2009.07.19
> > #ifdef _MSC_VER
> > #include <io.h>
> > #endif // _MSC_VER
> > //Geos
> > #include <geos_c.h>
> > #include <geos/algorithm/CGAlgorithms.h>
> > #include <geos/algorithm/HCoordinate.h>
> > #include <geos/geom/Coordinate.h>
> > #include <geos/geom/CoordinateArraySequence.h>
> > #include <geos/geom/LineString.h>
> > #include <geos/geom/MultiPoint.h>
> > #include <geos/geom/Point.h>
> > #include <geos/geom/Polygon.h>
> > #include <geos/io/WKTReader.h>
> > #include <geos/io/WKTWriter.h>
> > // <-- modified by sanak 2009.07.19
> > //const double epsilonArea = 100.0;
> > const double epsilonRadius = 0.1;
> > // --> modified by sanak 2009.07.19
> > // <-- Boost code
> > template < class BidirectionalIterator >
> > bool next_combination ( BidirectionalIterator first1 ,
> > BidirectionalIterator last1 ,
> > BidirectionalIterator first2 ,
> > BidirectionalIterator last2 )
> > if (( first1 == last1 ) || ( first2 == last2 )) {
> > return false ;
> > BidirectionalIterator m1 = last1 ;
> > BidirectionalIterator m2 = last2 ; --m2;
> > while (--m1 != first1 && !(* m1 < *m2 )){
> > bool result = (m1 == first1 ) && !(* first1 < *m2 );
> > if (! result ) {
> > while ( first2 != m2 && !(* m1 < * first2 )) {
> > ++ first2 ;
> > first1 = m1;
> > std :: iter_swap (first1 , first2 );
> > ++ first1 ;
> > ++ first2 ;
> > if (( first1 != last1 ) && ( first2 != last2 )) {
> > m1 = last1 ; m2 = first2 ;
> > while (( m1 != first1 ) && (m2 != last2 )) {
> > std :: iter_swap (--m1 , m2 );
> > ++ m2;
> > std :: reverse (first1 , m1 );
> > std :: reverse (first1 , last1 );
> > std :: reverse (m2 , last2 );
> > std :: reverse (first2 , last2 );
> > return ! result ;
> > bool next_combination ( BidirectionalIterator first ,
> > BidirectionalIterator middle ,
> > BidirectionalIterator last )
> > return next_combination (first , middle , middle , last );
> > // Boost Code -->
> > bool computeIncircle(
> > const geos::geom::Polygon* poly,
> negbuf,
> > geos::geom::Coordinate& center,
> > double& radius)
> > radius = 0.0;
> > if (negbuf == NULL)
> > negbuf = poly;
> > try
> > if (!negbuf->isValid())
> > throw std::runtime_error("Invalid polygon.");
> > if (negbuf->getNumInteriorRing() > 0)
> > throw std::runtime_error("This sample only
> supports
> > non-holes polygon.");
> > const geos::geom::LineString* shell =
> > negbuf->getExteriorRing();
> > geos::geom::CoordinateArraySequence* coords =
> static_cast<geos::geom::CoordinateArraySequence*>(shell->getCoordinates());
> > // compute orientation of ring
> > if (!geos::algorithm::CGAlgorithms::isCCW(coords))
> > coords->reverse(coords);
> > // compute angle bisector of every continuous three
> points
> > in polygon
> > size_t cnt = coords->size() - 1;
> > //std::vector<geos::algorithm::HCoordinate*> bisects;
> > std::vector<size_t> bisectids;
> > std::map<size_t, geos::algorithm::HCoordinate*> bisects;
> > for (size_t i = 0; i < cnt; i++)
> > size_t prev = (i == 0) ? cnt - 1 : i - 1;
> > size_t curr = i;
> > size_t next = (i == cnt - 1) ? 0 : i + 1;
> > // <-- JTS 1.10 Code
> > geos::geom::Coordinate a = coords->getAt(prev);
> > geos::geom::Coordinate b = coords->getAt(curr);
> > geos::geom::Coordinate c = coords->getAt(next);
> > double len0 = b.distance(a);
> > double len2 = b.distance(c);
> > double frac = len0 / (len0 + len2);
> > double dx = c.x - a.x;
> > double dy = c.y - a.y;
> > geos::geom::Coordinate splitPt =
> > geos::geom::Coordinate(a.x + frac * dx, a.y + frac * dy);
> > // --> JTS 1.10 Code
> > //bisects.push_back(new
> > geos::algorithm::HCoordinate(b, splitPt));
> > bisectids.push_back(i);
> > bisects.insert(std::pair<size_t,
> > geos::algorithm::HCoordinate*>(i, new geos::algorithm::HCoordinate(b,
> > splitPt)));
> > // get intersection points of angle bisectors
> > geos::geom::CoordinateArraySequence intsects;
> > do
> > //geos::algorithm::HCoordinate* hc0 = bisects[0];
> > //geos::algorithm::HCoordinate* hc1 = bisects[1];
> > bisects[bisectids[0]];
> > bisects[bisectids[1]];
> > geos::algorithm::HCoordinate* hcoord = new
> > geos::algorithm::HCoordinate(*hc0, *hc1);
> > try
> > // get intersection
> > geos::geom::Coordinate coord =
> > geos::geom::Coordinate(hcoord->getX(), hcoord->getY());
> > // TODO:remove duplicate point
> > intsects.add(coord);
> > catch (std::exception& ex)
> > // no intersection
> > if (hcoord)
> > delete hcoord;
> > //while (next_combination(bisects.begin(), bisects.begin()
> > 2, bisects.end()));
> > while (next_combination(bisectids.begin(),
> bisectids.begin()
> > + 2, bisectids.end()));
> > // clean up
> > if (bisects.size() > 0)
> > std::cout << "bissects ok." << std::endl;
> > //std::vector<geos::algorithm::HCoordinate*>::iterator it;
> > //for (it = bisects.begin(); it != bisects.end();
> > it++)
> > // delete *it;
> > std::map<size_t,
> > it++)
> > delete it->second;
> > else
> > std::cout << "No bissects." << std::endl;
> > std::cout << "intsects.size()" << intsects.size() <<
> > std::endl;
> > if (intsects.size() > 0)
> > std::cout << "intsects ok." << std::endl;
> > geos::geom::Point* incenter = NULL;
> > geos::geom::GeometryFactory factory;
> > const geos::geom::LineString* line =
> > poly->getExteriorRing();
> > //geos::geom::MultiPoint* rcpoints =
> > factory.createMultiPoint(intsects); // for debug
> > std::vector<geos::geom::Coordinate*>::iterator it;
> > for (size_t i = 0; i < intsects.size(); i++)
> intsects[i];
> > // exclude points that are outer of
> polygon
> > if
> > (geos::algorithm::CGAlgorithms::isPointInRing(coord, coords))
> > geos::geom::Point* point =
> > factory.createPoint(coord);
> > // compute distance from every
> > candidates of centres to polygon, and choose largest one
> > double distance =
> > line->distance(point);
> > if (radius < distance)
> > radius = distance;
> > incenter = point;
> > //else std::cout << "Point not in Ring."
> > std::endl;
> > if (incenter != NULL && radius != 0.0)
> > geos::io::WKTWriter writer;
> > std::cout << "wkt : " <<
> > writer.write(incenter) << std::endl;
> > std::cout << "radius : " << radius
> > << std::endl;
> > center.x = incenter->getX();
> > center.y = incenter->getY();
> > //return true; // deleted by sanak
> > 2009.07.19
> > // <-- added by sanak 2009.07.19
> > else
> > geos::geom::Point* intPt =
> > negbuf->getInteriorPoint();
> > center.x = intPt->getX();
> > center.y = intPt->getY();
> > radius = line->distance(intPt);
> > return true;
> > // --> added by sanak 2009.07.19
> > else
> > std::cout << "No intsects." << std::endl;
> > throw std::runtime_error("Couldn't get
> incenter.");
> > std::cerr << "Exception : " << ex.what() << std::endl;
> > throw ex;
> > return false;
> > return false;
> > int main(int argc, char* argv[])
> > // check stdin
> > #ifdef _MSC_VER
> > if (::_isatty(fileno(stdin)))
> > #else
> > if (::isatty(fileno(stdin)))
> > #endif // _MSC_VER
> > std::cerr << "Usage: %s < [wktfile(polygon)]" <<
> std::endl;
> > return -1;
> > std::string line;
> > geos::io::WKTReader reader;
> > std::vector<geos::geom::Polygon*> g;
> > while (getline(std::cin, line, '\n'))
> > //std::cout << line << std::endl;
> > geos::geom::Polygon* geom =
> > static_cast<geos::geom::Polygon*>(reader.read(line));
> > if (geom == NULL && geom->getGeometryType() != "Polygon")
> supports
> > polygon geometry");
> > geos::geom::Polygon* poly =
> > static_cast<geos::geom::Polygon*>(geom);
> > if (!poly->isValid())
> > if (poly->getNumInteriorRing() > 0)
> supports
> > g.push_back(poly);
> > try
> > for (int i=0 ; i < g.size(); ++i)
> > geos::geom::Polygon* negbuf = NULL;
> > double prevRadius = 0.0; // added by sanak
> > 2009.07.19
> > while (true)
> > geos::geom::Coordinate center;
> > double radius = 0.0;
> > if (computeIncircle(g[i], negbuf, center,
> > radius))
> 2009.07.19
> > //negbuf =
> > static_cast<geos::geom::Polygon*>(g[i]->buffer(-radius));
> > //if (negbuf == NULL &&
> > negbuf->getGeometryType() != "Polygon")
> > // // TODO:
> > // throw
> > std::runtime_error("Intercepted!!!!!!!");
> > //double area = negbuf->getArea();
> > //if (area < epsilonArea)
> > geos::geom::Geometry* buf =
> > g[i]->buffer(-(radius));
> > std::string buftype =
> > buf->getGeometryType();
> > if (buftype == "Polygon")
> > negbuf =
> > static_cast<geos::geom::Polygon*>(buf);
> > else if (buftype ==
> "MultiPolygon")
> > size_t cnt =
> > buf->getNumGeometries();
> > double maxradius = 0.0;
> > double tmpradius = 0.0;
> > tmpcenter;
> > for (size_t j = 0; j <
> cnt;
> > j++)
> > const
> > geos::geom::Polygon* item = static_cast<const
> > geos::geom::Polygon*>(buf->getGeometryN(j));
> > if
> > (computeIncircle(g[i], item, tmpcenter, tmpradius))
> > if
> > (tmpradius > maxradius)
> > negbuf = static_cast<geos::geom::Polygon*>(item->clone());
> > center = tmpcenter;
> > radius = tmpradius;
> > maxradius = tmpradius;
> > if ((radius - prevRadius) <
> > epsilonRadius)
> 2009.07.19
> > std::cout << "center : "
> > center.toString() << std::endl;
> > radius << std::endl;
> > factory;
> > geos::geom::Point*
> centerPt
> > = factory.createPoint(center);
> > incircle = centerPt->buffer(radius);
> > geos::io::WKTWriter
> writer;
> > writer.write(incircle) << std::endl;
> > 2009.07.19
> > //return 0;
> > break;
> > 2009.07.19
> > prevRadius = radius; // added by
> > sanak 2009.07.19
> > else
> > std::cout << "Could not compute!"
> > std::endl;
> > return -2;
> > return -3;
> > return 0;
> > End of geos-devel Digest, Vol 81, Issue 13
> "#define QUESTION ((bb) || !(bb))" (Shakespeare)
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/geos-devel/attachments/20090719/f83b16e1/attachment.html
> End of geos-devel Digest, Vol 81, Issue 14
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090719/d602a171/attachment-0001.html
