[geos-devel] Computational Geometry Problem
Jo doublebyte at gmail.com
Sun Jul 19 17:56:53 EDT 2009
Hi Sanak,
Thanks a lot for the modified code: it worked on perfection!
Here is a screenshot of a run with my shapefile:
http://ladybug.no-ip.org/files/inCircleFinal.png
        Have a good rest of the weekend!
                                                             Jo
2009/7/19 <geos-devel-request at lists.osgeo.org>
> Send geos-devel mailing list submissions to
>        geos-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/geos-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        geos-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geos-devel digest..."
> Today's Topics:
>   1. Re: Re: Computational Geometry Problem (Sanak Goe)
> Message: 1
> Date: Sun, 19 Jul 2009 21:24:34 +0900
> From: Sanak Goe <geosanak at gmail.com>
> Subject: Re: [geos-devel] Re: Computational Geometry Problem
> To: GEOS Development List <geos-devel at lists.osgeo.org>
> Message-ID:
>        <5f9be0a0907190524n5a8de434y38731cf04e7770d0 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Skipped content of type multipart/alternative-------------- next part
> #include <locale.h>
> #include <iostream>
> #include <vector>
> #include <algorithm>
> #include <stdexcept>
> #include <map> // added by sanak 2009.07.19
> #ifdef _MSC_VER
> #include <io.h>
> #endif // _MSC_VER
> //Geos
> #include <geos_c.h>
> #include <geos/algorithm/CGAlgorithms.h>
> #include <geos/algorithm/HCoordinate.h>
> #include <geos/geom/Coordinate.h>
> #include <geos/geom/CoordinateArraySequence.h>
> #include <geos/geom/LineString.h>
> #include <geos/geom/MultiPoint.h>
> #include <geos/geom/Point.h>
> #include <geos/geom/Polygon.h>
> #include <geos/io/WKTReader.h>
> #include <geos/io/WKTWriter.h>
> // <-- modified by sanak 2009.07.19
> //const double epsilonArea = 100.0;
> const double epsilonRadius = 0.1;
> // --> modified by sanak 2009.07.19
> // <-- Boost code
> template < class BidirectionalIterator >
> bool next_combination ( BidirectionalIterator first1 ,
>  BidirectionalIterator last1 ,
>  BidirectionalIterator first2 ,
>  BidirectionalIterator last2 )
>  if (( first1 == last1 ) || ( first2 == last2 )) {
>    return false ;
>  BidirectionalIterator m1 = last1 ;
>  BidirectionalIterator m2 = last2 ; --m2;
>  while (--m1 != first1 && !(* m1 < *m2 )){
>  bool result = (m1 == first1 ) && !(* first1 < *m2 );
>  if (! result ) {
>    while ( first2 != m2 && !(* m1 < * first2 )) {
>      ++ first2 ;
>    first1 = m1;
>    std :: iter_swap (first1 , first2 );
>    ++ first1 ;
>    ++ first2 ;
>  if (( first1 != last1 ) && ( first2 != last2 )) {
>    m1 = last1 ; m2 = first2 ;
>    while (( m1 != first1 ) && (m2 != last2 )) {
>      std :: iter_swap (--m1 , m2 );
>      ++ m2;
>    std :: reverse (first1 , m1 );
>    std :: reverse (first1 , last1 );
>    std :: reverse (m2 , last2 );
>    std :: reverse (first2 , last2 );
>  return ! result ;
> bool next_combination ( BidirectionalIterator first ,
>  BidirectionalIterator middle ,
>  BidirectionalIterator last )
>  return next_combination (first , middle , middle , last );
> // Boost Code -->
> bool computeIncircle(
>                                         const geos::geom::Polygon* poly,
>                                         const geos::geom::Polygon* negbuf,
>                                         geos::geom::Coordinate& center,
>                                         double& radius)
>        radius = 0.0;
>        if (negbuf == NULL)
>                negbuf = poly;
>        try
>                if (!negbuf->isValid())
>                        throw std::runtime_error("Invalid polygon.");
>                if (negbuf->getNumInteriorRing() > 0)
>                        throw std::runtime_error("This sample only supports
> non-holes polygon.");
>                const geos::geom::LineString* shell =
> negbuf->getExteriorRing();
>                geos::geom::CoordinateArraySequence* coords =
> static_cast<geos::geom::CoordinateArraySequence*>(shell->getCoordinates());
>                // compute orientation of ring
>                if (!geos::algorithm::CGAlgorithms::isCCW(coords))
>                        coords->reverse(coords);
>                // compute angle bisector of every  continuous three points
> in polygon
>                size_t cnt = coords->size() - 1;
>                //std::vector<geos::algorithm::HCoordinate*> bisects;
>                std::vector<size_t> bisectids;
>                std::map<size_t, geos::algorithm::HCoordinate*> bisects;
>                for (size_t i = 0; i < cnt; i++)
>                        size_t prev = (i == 0) ? cnt - 1 : i - 1;
>                        size_t curr = i;
>                        size_t next = (i == cnt - 1) ? 0 : i + 1;
>                        // <-- JTS 1.10 Code
>                        geos::geom::Coordinate a = coords->getAt(prev);
>                        geos::geom::Coordinate b = coords->getAt(curr);
>                        geos::geom::Coordinate c = coords->getAt(next);
>                        double len0 = b.distance(a);
>                        double len2 = b.distance(c);
>                        double frac = len0 / (len0 + len2);
>                        double dx = c.x - a.x;
>                        double dy = c.y - a.y;
>                        geos::geom::Coordinate splitPt =
> geos::geom::Coordinate(a.x + frac * dx, a.y + frac * dy);
>                        // --> JTS 1.10 Code
>                        //bisects.push_back(new
> geos::algorithm::HCoordinate(b, splitPt));
>                        bisectids.push_back(i);
>                        bisects.insert(std::pair<size_t,
> geos::algorithm::HCoordinate*>(i, new geos::algorithm::HCoordinate(b,
> splitPt)));
>                // get intersection points of angle bisectors
>                geos::geom::CoordinateArraySequence intsects;
>                do
>                        //geos::algorithm::HCoordinate* hc0 = bisects[0];
>                        //geos::algorithm::HCoordinate* hc1 = bisects[1];
> bisects[bisectids[0]];
> bisects[bisectids[1]];
>                        geos::algorithm::HCoordinate* hcoord = new
> geos::algorithm::HCoordinate(*hc0, *hc1);
>                        try
>                                // get intersection
>                                geos::geom::Coordinate coord =
> geos::geom::Coordinate(hcoord->getX(), hcoord->getY());
>                                // TODO:remove duplicate point
>                                intsects.add(coord);
>                        catch (std::exception& ex)
>                                // no intersection
>                        if (hcoord)
>                                delete hcoord;
>                //while (next_combination(bisects.begin(), bisects.begin() +
> 2, bisects.end()));
>                while (next_combination(bisectids.begin(), bisectids.begin()
> + 2, bisectids.end()));
>                // clean up
>                if (bisects.size() > 0)
>                        std::cout << "bissects ok." << std::endl;
>  //std::vector<geos::algorithm::HCoordinate*>::iterator it;
>                        //for (it = bisects.begin(); it != bisects.end();
> it++)
>                        //      delete *it;
>                        std::map<size_t,
> it++)
>                                delete it->second;
>                else
>                std::cout << "No bissects." << std::endl;
>                std::cout << "intsects.size()" << intsects.size() <<
>  std::endl;
>                if (intsects.size() > 0)
>                        std::cout << "intsects ok." << std::endl;
>                        geos::geom::Point* incenter = NULL;
>                        geos::geom::GeometryFactory factory;
>                        const geos::geom::LineString* line =
> poly->getExteriorRing();
>                        //geos::geom::MultiPoint* rcpoints =
> factory.createMultiPoint(intsects); // for debug
>                        std::vector<geos::geom::Coordinate*>::iterator it;
>                        for (size_t i = 0; i < intsects.size(); i++)
>                                geos::geom::Coordinate coord = intsects[i];
>                                // exclude points that are outer of polygon
>                                if
> (geos::algorithm::CGAlgorithms::isPointInRing(coord, coords))
>                                        geos::geom::Point* point =
> factory.createPoint(coord);
>                                        // compute distance from every
> candidates of centres to polygon, and choose largest one
>                                        double distance =
> line->distance(point);
>                                        if (radius < distance)
>                                                radius = distance;
>                                                incenter = point;
>                                //else std::cout << "Point not in Ring." <<
> std::endl;
>                        if (incenter != NULL && radius != 0.0)
>                                        geos::io::WKTWriter writer;
>                                        std::cout << "wkt : " <<
> writer.write(incenter) << std::endl;
>                                        std::cout << "radius : " << radius
> << std::endl;
>                                center.x = incenter->getX();
>                                center.y = incenter->getY();
>                                //return true; // deleted by sanak
> 2009.07.19
>                        // <-- added by sanak 2009.07.19
>                        else
>                                geos::geom::Point* intPt =
> negbuf->getInteriorPoint();
>                                center.x = intPt->getX();
>                                center.y = intPt->getY();
>                                radius = line->distance(intPt);
>                        return true;
>                        // --> added by sanak 2009.07.19
>                else
>                        std::cout << "No intsects." << std::endl;
>                        throw std::runtime_error("Couldn't get incenter.");
>                std::cerr << "Exception : " << ex.what() << std::endl;
>                throw ex;
>                return false;
>        return false;
> int main(int argc, char* argv[])
>        // check stdin
> #ifdef _MSC_VER
>        if (::_isatty(fileno(stdin)))
> #else
>        if (::isatty(fileno(stdin)))
> #endif // _MSC_VER
>                std::cerr << "Usage: %s < [wktfile(polygon)]" << std::endl;
>                return -1;
>        std::string line;
>        geos::io::WKTReader reader;
>        std::vector<geos::geom::Polygon*> g;
>        while (getline(std::cin, line, '\n'))
>                //std::cout << line << std::endl;
>                geos::geom::Polygon* geom =
>                static_cast<geos::geom::Polygon*>(reader.read(line));
>                if (geom == NULL && geom->getGeometryType() != "Polygon")
> polygon geometry");
>                geos::geom::Polygon* poly =
> static_cast<geos::geom::Polygon*>(geom);
>                if (!poly->isValid())
>                if (poly->getNumInteriorRing() > 0)
>                g.push_back(poly);
>        try
>                for (int i=0 ; i < g.size(); ++i)
>                        geos::geom::Polygon* negbuf = NULL;
>                        double prevRadius = 0.0; // added by sanak
> 2009.07.19
>                        while (true)
>                                geos::geom::Coordinate center;
>                                double radius = 0.0;
>                                if (computeIncircle(g[i], negbuf, center,
> radius))
>                                        //negbuf =
> static_cast<geos::geom::Polygon*>(g[i]->buffer(-radius));
>                                        //if (negbuf == NULL &&
> negbuf->getGeometryType() != "Polygon")
>                                        //      // TODO:
>                                        //      throw
> std::runtime_error("Intercepted!!!!!!!");
>                                        //double area = negbuf->getArea();
>                                        //if (area < epsilonArea)
>                                        geos::geom::Geometry* buf =
> g[i]->buffer(-(radius));
>                                        std::string buftype =
> buf->getGeometryType();
>                                        if (buftype == "Polygon")
>                                                negbuf =
> static_cast<geos::geom::Polygon*>(buf);
>                                        else if (buftype == "MultiPolygon")
>                                                size_t cnt =
> buf->getNumGeometries();
>                                                double maxradius = 0.0;
>                                                double tmpradius = 0.0;
> tmpcenter;
>                                                for (size_t j = 0; j < cnt;
> j++)
>                                                        const
> geos::geom::Polygon* item = static_cast<const
> geos::geom::Polygon*>(buf->getGeometryN(j));
>                                                        if
> (computeIncircle(g[i], item, tmpcenter, tmpradius))
>        if
> (tmpradius > maxradius)
>  negbuf = static_cast<geos::geom::Polygon*>(item->clone());
>  center = tmpcenter;
>  radius = tmpradius;
>  maxradius = tmpradius;
>                                        if ((radius - prevRadius) <
> epsilonRadius)
>                                                std::cout << "center : " <<
> center.toString() << std::endl;
> radius << std::endl;
> factory;
>                                                geos::geom::Point* centerPt
> = factory.createPoint(center);
> incircle = centerPt->buffer(radius);
> writer.write(incircle) << std::endl;
> 2009.07.19
>                                                //return 0;
>                                                break;
> 2009.07.19
>                                        prevRadius = radius; // added by
> sanak 2009.07.19
>                                else
>                                        std::cout << "Could not compute!" <<
> std::endl;
>                                        return -2;
>                return -3;
>        return 0;
> End of geos-devel Digest, Vol 81, Issue 13
"#define QUESTION ((bb) || !(bb))"  (Shakespeare)
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090719/f83b16e1/attachment-0001.html
