[geos-devel] Re: Computational Geometry Problem
Jo
doublebyte at gmail.com
Sat Jul 18 20:49:01 EDT 2009
I just realized that I spammed my post with the geometry text files... 8-/
Here is what I wanted to say:
Hi Sanak!
First of all, thanks a lot for the great help: the code you wrote was really
helpful for me!
I modified it a little bit, because I wanted to be able to read an array of
polygons and changed the epsilonArea constant to a greater value, since the
scale I'm working is slightly different (actually, I am unsure what should
be the size of this variable, but the value you had was hanging the program
with my geometries...)
I am using the text files with geometry that I attached to this mail: one
with one polygon and another one with a list of polygons; in both cases, I
am getting an exception inside the "computeIncircle" function, when it is
calculating the number of interior rings of the buffer. Here is the output
from gdb:
Starting program: /home/joana/cvs/testInCircle/test < geometry1.txt
bissects ok.
intsects.size()5589
intsects ok.
wkt : POINT (109225.1841292473545764 203255.7488541874336079)
radius : 448.544
Program received signal SIGSEGV, Segmentation fault.
0xb7efb0c9 in geos::geom::Polygon::getNumInteriorRing (this=0x80ccfd0) at
Polygon.cpp:181
181 Polygon::getNumInteriorRing() const
(gdb) backtrace
#0 0xb7efb0c9 in geos::geom::Polygon::getNumInteriorRing (this=0x80ccfd0)
at Polygon.cpp:181
#1 0x08049aa0 in computeIncircle (poly=0x8050ba8, negbuf=0x80ccfd0,
center=@0xbfa09f98, radius=@0xbfa09fd8) at InCircle.cpp:94
#2 0x0804a888 in main () at InCircle.cpp:283
(gdb)
This seems to me like a memory allocation problem with the variable negbuf,
but I am not sure why... it may also be that I am having a (somehow)
complicated geometry here.
I would like to ask you if you run this code with a test file (I imagine
so), and if yes if you could be so kind and give me this file, so that I can
trace the problem?
Apart from my test files, I also attach the code that I used, if you wanna
have a look!
Any comments and suggestions from you or anyone else would be kindly
appreciated...!
Thanks again for
your help,
Jo
2009/7/19 <geos-devel-request at lists.osgeo.org>
> Send geos-devel mailing list submissions to geos-devel at lists.osgeo.org To
> subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/geos-devel or, via email, send a
> message with subject or body 'help' to geos-devel-request at lists.osgeo.orgYou can reach the person managing the list at
> geos-devel-owner at lists.osgeo.org When replying, please edit your Subject
> line so it is more specific than "Re: Contents of geos-devel digest..."
> Today's Topics: 1. Re: Computational Geometry Problem (Jo)
> Message: 1 Date: Sun, 19 Jul 2009 01:33:22 +0100 From: Jo Subject:
> [geos-devel] Re: Computational Geometry Problem To:
> geos-devel at lists.osgeo.org Message-ID: <
> 23ab5f0a0907181733x4f1bd457x57cec7a550e7ce5f at mail.gmail.com> Content-Type:
> text/plain; charset="iso-8859-1" Skipped content of type
> multipart/alternative-------------- next part -------------- POLYGON
> ((109593.173002519004513 204057.986181512009352,109602.716397355005029
> 204065.541369090002263,109653.272232817005715
> 204087.522167116985656,109687.10867234399484
> 204058.519504666008288,109726.63273517700145
> 203984.411886854009936,109741.45425874000648
> 203910.304269042011583,109741.45425874000648
> 203855.958682646014495,109751.335274448007112
> 203806.553604104992701,109780.978321572998539
> 203722.564970584993716,109805.680860843000119
> 203663.278876335010864,109840.264415822006413
> 203623.754813501989702,109886.606630552007118
> 203604.873887491005007,109881.330832341001951
> 203492.066371975000948,109884.56599162099883
> 203450.009301332000177,109881.330832341001951
> 203398.24675284899422,109884.56599162099883
> 203352.954522926011123,109897.506628742004978
> 203314.132611564011313,109910.447265862996574
> 203288.251337321999017,109928.74214260300505
> 203265.382741397013888,109802.816679091993137
> 203098.82380868200562,109772.893545970000559
> 203053.939108999009477,109675.643363323004451
> 203009.0544093149947,109585.873963956997613
> 202956.688926352013368,109361.450465540998266
> 202754.707777778006857,109279.161849455995252
> 202657.457595131010748,109256.719499614002416
> 202627.534462009003619,109211.834799931006273
> 202582.649762326007476,109159.469316967006307
> 202560.207412483985536,109092.142267443006858
> 202537.765062641992699,109009.853651356999762
> 202507.84192951998557,108942.526601831996231
> 202485.399579679011367,108912.603468710003654
> 202470.43801311799325,108785.430152941000415
> 202470.43801311799325,108710.622320135997143
> 202462.957229836989427,108658.256837171997176
> 202447.995663276000414,108628.333704050004599
> 202403.110963593004271,108628.333704050004599
> 202358.226263910008129,108598.410570927997469
> 202238.53373142099008,108561.006654525001068
> 202171.206681896990631,108516.121954842004925
> 202148.764332054997794,108426.352555475998088
> 202133.802765494008781,108407.712379735996365
> 202135.873896131990477,108316.953292947000591 202124.063327988988021,108295
> .732071400998393 202148.316152613988379,108264.764998971004388
> 202183.70709253300447,108190.210293291005655
> 202265.717268781008897,108082.105970054995851
> 202358.910650881007314,108003.823529090994271
> 202366.366121449013008,107921.813352843004395
> 202306.722356904996559,107828.619970743005979
> 202306.722356904996559,107791.342617903006612
> 202340.27197446100763,107780.159412050998071
> 202396.18800372100668,107806.253559039003449
> 202470.742709401005413,107847.1953125 202514.5625,107865.196725301997503
> 202554.94723263499327,107878.639516151000862
> 202585.10506081598578,107893.978032472994528
> 202591.240467344992794,107932.663719869000488
> 202591.240467344992794,107975.217976004001684
> 202591.240467344992794,108002.297957180999219
> 202587.371898604993476,108033.246507097996073
> 202583.503329864994157,108079.669331972007058
> 202571.897623647004366,108114.486450627999147
> 202568.029054907005047,108191.857825419006986
> 202568.029054907005047,108230.543512814998394 202571.897623647004366,108273.
> 09776894999959 202571.897623647004366,108307.914887606006232
> 202575.766192386014154,108340.066992242005654
> 202575.766192386014154,108391.025421566999285
> 202549.101897971995641,108423.971949793005479
> 202556.423348688986152,108462.657637188996887
> 202564.160486167995259,108493.60618710500421
> 202564.160486167995259,108524.554737022001063
> 202579.634761126013473,108532.291874500995618
> 202622.189017261000117,108524.554737022001063
> 202653.137567177996971,108505.211893323998083
> 202680.217548354004975,108489.737618365994422
> 202699.560392051993404,108470.394774668005994
> 202726.640373228990939,108451.051930970003013
> 202749.851785667007789,108427.840518533004797
> 202792.406041801994434,108408.497674835001817
> 202823.354591718001757,108393.023399876998155
> 202862.040279114007717,108396.891968615993392
> 202892.988829029985936,108416.234812313996372
> 202916.200241468002787,108431.709087272000033
> 202935.543085165001685,108474.26334340700123
> 202954.885928862990113,108512.390782667003805 202957.062
> 040857010288,108554.5 202938.25,108566.518587382000987
> 202938.232427131006261,108626.355321519004065
> 202910.615472914010752,108671.088144926994573
> 202903.160002346005058,108700.910027199002798
> 202925.526414049993036,108719.548703619002481
> 202962.803766889992403,108730.73190947099647
> 203011.264325581985759,108756.826056459001848
> 203029.903002002014546,108786.64793873099552
> 203052.269413706002524,108786.64793873099552
> 203108.185442966001574,108764.28152702699299
> 203171.556942794006318,108747.906016626002383
> 203198.849460127996281,108719.548703619002481
> 203246.111648474005051,108696.303623333005817
> 203266.622013432002859,108691.307749129002332
> 203280.283291792002274,108637.538527370998054
> 203354.215971709985752,108567.631948555994313
> 203414.903538062004372,108590.929787646993645
> 203465.382189427007688,108605.89135420799721
> 203502.786105829989538,108665.737620453001
> 203600.036288476985646,108695.660753574993578
> 203629.959421598992776,108740.545453258004272 203652.401771439996082
> ,108800.39171950200398 203659.882554720999906,108879.012228894003783
> 203666.434263836999889,108981.112235374006559
> 203660.519654395990074,109031.915796554007102
> 203660.519654395990074,109061.551207241995144
> 203677.454174788988894,109078.485727634993964
> 203711.323215576005168,109091.186617929997738
> 203770.594036952010356,109082.719357733003562
> 203804.463077738997526,109044.616686848996324
> 203838.332118524995167,108996.900754520000191
> 203878.707138188008685,108987.411301515006926
> 203899.267619697988266,108994.892084795996197
> 203974.075452502991538,108994.892084795996197
> 204048.883285307994811,108957.488168392999796
> 204108.72955155200907,108927.565035271007218
> 204168.57581779701286,108897.641902149000089
> 204235.902867321012309,108875.199552307007252
> 204303.229916846001288,108875.199552307007252
> 204333.153049968008418,108920.084251990003395
> 204407.96088277301169,108969.842976801999612
> 204443.502829067991115,109006.0625 204386.28125,109061.914096309003071
> 204327.03974935298902,10 9106.336315720996936
> 204238.19531052801176,109126.733874751997064
> 204182.102023193991045,109149.892129052997916
> 204182.102023193991045,109170.951968380002654
> 204182.102023193991045,109199.031754149997141
> 204184.442005341988988,109236.471468510004343
> 204182.102023193991045,109276.251165017994936
> 204175.082076752005378,109346.450629443002981
> 204156.362219572009053,109379.210379508003825
> 204135.302380243985681,109409.630147425006726
> 204093.182701588986674,109442.389897489993018
> 204041.703094344004057,109475.149647554993862
> 203987.883504952013027,109483.853992221993394
> 203971.44196502599516,109593.173002519004513 204057.986181512009352))
> -------------- next part -------------- POLYGON ((124329.47971483800211
> 218856.725472835008986,124359.682529993995558
> 218849.755592414992861,124382.915464728997904
> 218835.815831573010655,124399.178519043998676
> 218821.876070731988875,124417.764866832003463
> 218796.319842522992985,124420.088160305997008
> 218775.410201260994654,124413.118279885005904
> 218759.147146947012516,124401.501812518006773
> 218740.560799158003647,124392.208638622993021
> 218726.621038317010971,124382.915464728997904
> 218710.357984002010198,124371.29899736099469
> 218691.77163621399086,124366.652410413997131
> 218682.478462319995742,124362.005823466999573
> 218659.245527583989315,124364.329116940993117
> 218612.779658112995094,124364.329116940993117
> 218591.870016850996763,124359.682529993995558
> 218570.960375589987962,124345.742769153002882
> 218550.05073432798963,124329.47971483800211
> 218526.817799592012307,124320.186540944006993
> 218512.878038750990527,124313.216660523001337
> 218503.584864856995409,124303.92348662900622
> 218489.645104016002733,124299.2768996819941 09
> 218478.028636647999519,124294.630312734996551
> 218461.765582332998747,124287.660432314005448
> 218450.149114964995533,124285.337138839997351
> 218438.532647598010954,124285.337138839997351
> 218422.269593283010181,124313.216660523001337
> 218394.390071600006195,124364.329116940993117
> 218368.833843391010305,124418.898040443993523
> 218347.037283882003976,124377.776448178003193
> 218161.990118685993366,124352.752074297997751
> 218049.380436225997983,124360.296478003001539
> 217978.450431853998452,124350.928915530006634
> 217880.091025878005894,124343.280103968005278
> 217799.778504476009402,124304.61254471000575
> 217708.73458039801335,124261.821880426999996
> 217715.584448768000584,124206.387937619001605
> 217736.372177320008632,124175.206344790000003
> 217771.018391574994894,124164.812480513995979
> 217788.341498702997342,124144.024751960998401
> 217798.735362979001366,124116.307780557006481
> 217795.270741554006236,124088.590809153000009
> 217784.876877277012682,124064.338459174992749 217777.947634426003788
> ,124033.156866345001617 217771.018391574994894,124012.36913779200404
> 217764.089148723986,123956.935194984995178
> 217767.553770149999764,123942.651022008998552
> 217775.724600883986568,123894.229094577996875
> 217781.104815043014241,123856.567595464002807
> 217797.24545752000995,123797.385239715003991
> 217824.146528315002797,123788.131066151006962
> 217829.699032453994732,123766.381016582992743
> 217899.209384318004595,123734.802779669000302
> 217946.821614368003793,123722.744253580996883
> 218045.31888588500442,123693.283657494001091
> 218100.031421474996023,123688.122904942996684
> 218138.737065610999707,123684.866344326001126
> 218163.16127023199806,123686.970672618001117
> 218228.39544728200417,123678.500085317005869
> 218282.302211595000699,123681.586770876005176
> 218323.972466639999766,123692.564456684995093
> 218380.752811176993418,123727.84375 218445.3125,123777.875
> 218528.5,123827.7890625 218553.421875,123877.973184556001797
> 218553.355284690012923,123969.09375 218553.234375,124043.71461759200610 7
> 218552.374027801008197,124073.917432747999555
> 218573.283669063006528,124159.879291268996894
> 218661.568821057997411,124329.47971483800211 218856.725472835008986))
> POLYGON ((109593.173002519004513
> POLYGON ((96443.465480935905362 204259.395140887994785,96426.545287432803889
> 204237.058901240990963,96417.76189763880393
> 204213.708207260991912,96410.883484735197271
> 204162.469445427006576,96471.296875 204136.453125,96545.9375
> 204044.78125,96537.4140625 203936.546875,96462.5078125
> 203878.375,96287.9140625 203861.9375,96246.296875 203828.703125,96221.265625
> 203778.78125,96221.078125 203678.875,96303.890625
> 203520.578125,96295.3515625 203395.71875,96233.907490693003638
> 203254.843048443988664,96211.875 203204.328125,96219.953125
> 203079.4375,96165.947331923001911
> 202887.380786088004243,96165.947331923001911
> 202790.063111322990153,96152.676739909496973
> 202723.710151255014353,96143.898142071499024
> 202692.935093067993876,96130.623180501104798
> 202670.805309407005552,96126.186086226793122
> 202635.379182306001894,96108.570200062502408
> 202609.05449775600573,96062.418070327694295
> 202550.839960337005323,96050.759537695004838
> 202539.346150219003903,96046.254488297694479 202524.2202423560083
> 84,96049.731935860298108 202506.382947103003971,96062.570799682594952
> 202497.844803965010215,96083.33047549870389
> 202490.867669277999084,96126.42313187540276
> 202481.870037541986676,96146.911175044297124
> 202471.888738092995482,96192.235914233897347
> 202454.194615407992387,96210.728450672002509
> 202423.229900709993672,96215.151981343195075
> 202387.841655341006117,96215.151981343195075
> 202352.453409970999928,96215.151981343195075
> 202317.065164602012374,96205.057803825693554
> 202279.363005980005255,96195.942328641700442
> 202229.963030139013426,96182.885491699402337
> 202190.74764625300304,96143.264493198599666
> 202151.390099687007023,96107.958127683406929
> 202151.597916049009655,96028.53735927620437
> 202147.688808867998887,95918.149526071894797
> 202148.265954681992298,95878.633922831504606
> 202155.715720195992617,95868.686149292698246
> 202157.5859765149944,95848.308170628704829
> 202178.614995763986371,95744.65252365739434
> 202207.061072006006725,95677.036219207104295 202234.534203110990347,956
> 85.112401829406735 202270.877024912013439,95689.403390229796059
> 202305.204932115011616,95689.403390229796059
> 202343.823827718006214,95689.403390229796059
> 202369.569758119992912,95702.276355430905824
> 202421.061618925014045,95719.440309032404912
> 202468.262491328991018,95728.022285833198112
> 202524.045340534008574,95723.731297432794236
> 202566.955224537989125,95685.112401829406735
> 202601.283131740987301,95646.493506226106547
> 202614.156096941995202,95649.467969551202259
> 202630.079142834001686,95655.319560517105856
> 202706.149825391010381,95672.874333414903958
> 202776.368916981999064,95725.538652108298265
> 202852.439599539997289,95778.202970801707124
> 202887.549145335011417,95825.015698529197834
> 202910.955509199004155,95901.086381086293841
> 202928.510282097005984,95971.305472677500802
> 202951.916645960009191,96000.56342750719341
> 202981.174600789992837,96012.266609439102467
> 203051.393692381010624,96006.415018473097007
> 203209.386648460989818,96012.266609439102467 203279.605740052997135,960
> 06.415018473097007 203338.121649712004,95983.008654609395307
> 203402.489150337001774,95912.789563018202898
> 203501.966196758003207,95779.610210982296849
> 203741.815228894003667,95705.8359375 203729.5,95589.4765625
> 203729.65625,95539.5546875 203704.75,95489.59375 203654.875,95447.8515625
> 203563.34375,95389.578125 203505.140625,95323.0078125
> 203471.921875,95214.953125 203472.0625,95074.03125 203672.0625,95007.640625
> 203730.4375,94949.5078125 203755.484375,94816.5078125
> 203747.34375,94616.689889489600318 203660.946143169014249,94566.9453125
> 203639.4375,94442.2578125 203631.28125,94432.736031159001868
> 203533.343670622009085,94413.139512295107124
> 203445.159335734002525,94379.825430226293975
> 203396.168038573989179,94304.010185215403908
> 203321.730370631994447,94297.70598820289888
> 203315.005893817986362,94242.723160113295307
> 203256.357543855992844,94222.712221728696022
> 203266.359167435992276,94201.31082012229308
> 203283.482938984001521,94192.791905874095391 203304.881578805012396,94171.
> 534343852297752 203330.543729883997003,94150.335206147006829
> 203351.914814676012611,94133.417230534003465
> 203369.004768624989083,94116.603059938002843
> 203394.63984835500014,94112.612696682394017
> 203420.278642482997384,94117.308840403406066
> 203458.740630429994781,94125.312299908502609
> 203468.01953837700421,94143.091101625395822
> 203488.69402376699145,94189.831735428902903
> 203510.160012123989873,94223.789104490802856
> 203535.896782916999655,94244.999716236401582
> 203561.617148232006002,94253.407812374003697
> 203600.174227584007895,94244.676348249500734
> 203672.983866366004804,94210.653134009393398
> 203715.758562264993088,94150.914631136096432
> 203754.256337889994029,94090.66795423309668
> 203767.151082121010404,94064.771884632093133
> 203767.175351165002212,94047.612676399905467
> 203767.191432277002605,94017.420230220493977
> 203771.510140252008568,93978.59794975949626
> 203784.402975142991636,93935.581193947204156
> 203805.844146560004447,93897.023933854405186
> 203822.974060906009981,93850.0127 2424790659
> 203827.241655685997102,93803.041988751196186
> 203831.502485781995347,93740.436038965504849
> 203842.887527696992038,93711.194055846804986
> 203959.855460171995219,93711.194055846804986
> 204087.024510368995834,93711.194055846804986
> 204144.828624095011037,93711.194055846804986
> 204214.193560565996449,93711.194055846804986
> 204223.172272557014367,93711.194055846804986
> 204271.997674292011652,93716.319587731093634
> 204273.784646877000341,93738.315331435893313
> 204314.161254583013942,93753.795304933693842
> 204339.547449653007789,93766.104611254297197
> 204341.654946069989819,93789.256560823705513
> 204341.658034768013749,93795.963046725897584
> 204341.048952276003547,93812.408206958003575
> 204339.555404190992704,93833.453767775194137
> 204331.133731359994272,93842.857693808997283
> 204328.445111554989126,93896.520306266000262
> 204298.730474001000402,93956.593616989994189
> 204265.46796342000016,94085.092419949796749
> 204202.635610844998155,94235.033447475507273
> 204153.848473746009404,94256.80098 231699958
> 204147.62763271300355,94268.515625 204064.4375,94301.6328125
> 203997.78125,94426.265625 203972.65625,94517.703125
> 203972.53125,94584.2421875 203997.40625,94800.3125
> 203980.46875,94941.6953125 204021.90625,95058.0625
> 204021.765625,95124.5234375 204005.03125,95265.671875
> 203921.578125,95340.4609375 203913.15625,95498.6015625
> 204029.5,95541.178813741105841 204108.517810871009715,95570.682549807694159
> 204206.863597760006087,95585.43441784089373
> 204300.292095304001123,95611.81973745340656
> 204420.585241786990082,95685.831716868793592
> 204419.388115942012519,95725.713275454996619
> 204419.388115942012519,95776.989565065901843
> 204396.598653892986476,95816.87112365210487
> 204368.111826331005432,95851.05531672599318
> 204311.138171208003769,95868.147413262995542
> 204276.953978133999044,95913.726337361600599
> 204208.585591985989595,95942.213164923101431
> 204180.09876442499808,95965.002626972403959
> 204157.309302376001142,95987.792089021706488
> 204145.914571350993356,96084.647302731100353
> 204134.51984032598557,96124.528861317405244
> 204140.21720583899878,96147.31832336660591
> 204174.401398913003504,96215.686709514498943
> 204231.375054036005167,96289.744543380205869
> 204276.956000073987525,96357.775156774005154
> 204294.150782276992686,96403.54823514999589
> 204282.698341543989955,96443.465480935905362 204259.395140887994785))
> POLYGON ((97379.69609377119923 202979.630588474014075,97379.69609377119923
> 202939.763166871009162,97370.816763643902959
> 202891.107467108988203,97366.367063687604968
> 202842.453155708004488,97384.049490547695314
> 202811.487339457002236,97432.616724323495873
> 202793.8076792290085,97472.160665581395733
> 202767.31036199699156,97533.253110045698122
> 202727.646648283000104,97606.384051342305611
> 202661.681929507991299,97631.7369292768999
> 202626.52463997900486,97635.657394362802734
> 202573.670482674002415,97622.386802349996287
> 202498.59961463601212,97578.306151571305236
> 202427.624426269991091,97563.982906141201966
> 202384.228687461989466,97502.839807516298606
> 202401.36737195198657,97450.602510650700424
> 202405.248863521002932,97406.253823669394478
> 202413.294693619012833,97369.856472116196528
> 202421.39302839100128,97341.461777199394419
> 202445.916436797007918,97329.268617145702592
> 202470.475953287008451,97304.86639949590608
> 202486.829125215997919,97280.422709768798086 202490.902257289999397,97
> 227.322537159401691 202515.457330181001453,97190.480924897594377
> 202548.2272318819887,97169.190794828304206
> 202573.076554891013075,97145.24896819969581
> 202594.727774520986713,97105.43719215929741
> 202638.963081232010154,97078.896008132302086
> 202674.351326600997709,97061.201885447706445
> 202687.621918615011964,97043.507762763096252
> 202687.621918615011964,97008.119517393803108
> 202687.621918615011964,96994.848925380298169
> 202683.198387943994021,96968.307741353302845
> 202656.657203917013248,96968.307741353302845
> 202630.116019890003372,96968.307741353302845
> 202599.151305192004656,96968.307741353302845
> 202572.61012116499478,96968.307741353302845
> 202541.645406466996064,96963.88421068219759
> 202462.021854385995539,96959.460680011005024
> 202435.480670358985662,96955.03714933989977
> 202408.93948633200489,96946.190087997500086
> 202391.245363647001795,96925.552543818906997
> 202360.976965517998906,96887.118953676806996
> 202369.06824765400961,96862.319734010205138
> 202383.947779453999829,96825.1209 04510200489
> 202393.867467320000287,96795.361840910205501
> 202398.827311253990047,96768.082699276797939
> 202398.827311253990047,96745.76340157679806
> 202391.387545353994938,96725.924025843502022
> 202366.588325686985627,96693.710606482592993
> 202320.441324142011581,96678.200441605193191
> 202293.298535606998485,96651.057653069699882
> 202266.155747070995858,96627.792405753498315
> 202235.135417315992527,96600.649617218005005
> 202204.11508756200783,96573.506828682497144
> 202165.339675368013559,96519.625359105193638
> 202196.929849209991517,96464.571056878601667
> 202241.165155920985853,96438.029872851606342
> 202272.129870619013673,96411.488688824698329
> 202298.671054645994445,96389.37103546889557
> 202325.212238673004322,96380.523974126495887
> 202342.906361358007416,96367.253382113092812
> 202365.02401471399935,96362.829851441900246
> 202395.988729411998065,96362.829851441900246
> 202422.529913439007942,96371.676912784198066
> 202462.341689479013439,96375.916032883294974
> 202497.729934848000994,96388.2050114 99201646
> 202533.118180218007183,96405.120090032505686
> 202564.082894916005898,96426.7908017742011
> 202586.200548271997832,96453.119579642705503
> 202595.047609614004614,96490.566428868100047
> 202603.574835862993496,96543.648796922003385
> 202621.26895854799659,96579.03704229129653
> 202634.539550560992211,96605.578226318306406
> 202647.810142573987832,96618.848818331694929
> 202669.92779593000887,96623.272349002902047
> 202705.316041299985955,96632.119410345199867
> 202736.280755998013774,96632.119410345199867
> 202758.398409352987073,96694.048839741401025
> 202864.563145460997475,96729.43708511069417
> 202908.798452173010446,96804.637106520400266
> 202935.339636199991219,96947.960314555093646
> 202997.15845879499102,96992.828125 203011.8125,97059.3515625
> 203028.375,97273.306340628405451 202984.637165093008662,97379.69609377119923
> 202979.630588474014075)) POLYGON ((110369.727208244003123
> 202109.096987663011532,110415.99249505699845
> 202131.338588604005054,110452.049460088004707
> 202152.213673621998169,110511.102669172993046
> 202199.744305325002642,110555.940425306005636
> 202226.646959003992379,110591.810630211999523
> 202232.027489739994053,110620.506794137007091
> 202221.266428269009339,110654.583488798001781
> 202197.950795079988893,110686.866673212993192
> 202167.461120908992598,110697.76748490499449
> 202134.31779342298978,110695.834224439997342
> 202115.44932379500824,110688.660183458996471
> 202052.676465210010065,110672.045895691000624
> 201923.910900841001421,110646.510379936997197
> 201880.642388036008924,110612.432682764992933
> 201822.899623383011203,110597.777173782000318
> 201798.066677607013844,110559.905365714002983
> 201695.812795823992928,110559.905365714002983
> 201585.98455242800992,110605.351535395995597
> 201483.730670643999474,110630.033506861000205
> 201450.821375358005753,110647.010524269993766
> 201411.774235315999249,110664.997949170996 435
> 201385.792399347992614,110715.17977879299724
> 201313.307534338993719,110809.646276861996739
> 201241.214680550008779,110807.609080444002757
> 201229.61090067398618,110865.728651569996146
> 201026.240190756012453,110866.998232223995728
> 200997.886222798988456,110854.951059397004428
> 200943.947773880005116,110844.241217468006653
> 200897.538458852999611,110840.671270157996332
> 200854.699091135989875,110840.671270157996332
> 200797.579934181005228,110847.811164778002421
> 200747.600671844993485,110862.090954016995966
> 200704.761304128012853,110879.940690564995748
> 200672.631778340000892,110951.339636760007124
> 200636.932305243011797,110994.179004477002309
> 200633.362357932986924,111109.948292257002322
> 200641.863893230998656,111123.339528140000766
> 200633.829151701997034,111166.941672500004643
> 200590.22700734200771,111191.857183562999126
> 200565.311496278998675,111204.850082824006677
> 200560.586805638013175,111260.374838985997485
> 200540.39598521500011,111322.663616644000285 200527.938229683990357,
> 111366.265761004004162 200509.251596387010068,111441.012294193002163
> 200478.107207558001392,111490.84331631900568
> 200471.87832979200175,111584.276482804998523
> 200446.962818728992715,111615.420871634007199
> 200459.420574260991998,111618.754750174004585
> 200397.995547950995388,111632.780269737995695
> 200306.829670781997265,111640.725540886996896
> 200230.776272207993316,111654.006048176001059
> 200124.532213894010056,111662.584498812997481
> 200042.097989002999384,111666.090878703995259
> 199970.217201235005632,111667.844068649996188
> 199921.127882759989006,111660.831308866996551
> 199884.310893902991666,111634.533459683996625
> 199849.247094991995255,111611.741990391994477
> 199829.962005590990884,111585.444141208005021
> 199821.196055862994399,111543.987511389001156
> 199827.293809841998154,111496.031453984993277
> 199847.493905045994325,111470.80239930699463
> 199873.490289578010561,111388.89734465899528
> 199853.879220155999064,111356.20782830400276
> 199844.344777885009535,111308.53561695299868 199833
> .448272434005048,111266.311658327002078
> 199828.00001970800804,111232.094262402999448
> 199829.267330667993519,111214.553257431995007
> 199852.517156974005047,111213.19119425000099
> 199878.396357421996072,111220.001510157002485
> 199896.103178780991584,111233.622141971995006
> 199927.430631955008721,111251.32896333100507
> 199958.758085128996754,111281.294353322999086
> 199996.895854209986283,111297.639111501004663
> 200022.775054658006411,111309.897680134003167
> 200047.292191924003419,111313.983869678995688
> 200074.53345555299893,111315.345932860000175
> 200100.412656000989955,111310.230381108995061
> 200131.56333892600378,111302.611683005001396
> 200140.705776649992913,111295.901875112002017
> 200148.757546122011263,111272.071038003006834
> 200158.289880966010969,111248.240200893997098
> 200158.289880966010969,111210.110861520006438
> 200153.523713544011116,111191.046191832996556
> 200153.523713544011116,111124.319847927996307
> 200124.926709013991058,111032.070346679000068
> 200070.00996090398985,110988.27920 7629995653
> 200094.338371487014228,110939.622386464994634
> 200099.204053603985813,110876.368518949995632
> 200094.338371487014228,110887.179114473998197
> 200112.815516183007276,110920.899024181999266
> 200191.495305501011899,110932.138994084001752
> 200236.455185111990431,110926.519009133000509
> 200264.555109868000727,110909.65905427900725
> 200303.895004527992569,110887.179114473998197
> 200320.754959382000379,110819.73929505799606
> 200354.474869089986896,110746.679490691007231
> 200365.714838991989382,110690.479641177997109
> 200376.954808895010501,110651.139746518005268
> 200410.674718602997018,110623.039821761994972
> 200461.254583164991345,110617.419836810004199
> 200523.074417628988158,110623.039821761994972
> 200568.034297239995794,110673.619686324003851
> 200652.334071508987108,110677.821292916007224
> 200662.312887167005101,110680.023641220002901
> 200726.180987986008404,110676.453693910996662
> 200758.310513773991261,110651.026699641006417
> 200812.155913402995793,110640.381197891998454 200823.6885402
> 97996951,110604.890299189006328
> 200865.632329674990615,110572.625845821996336
> 200894.670337704999838,110517.77627509899321
> 200949.519908427988412,110495.191157741995994
> 200985.010807131009642,110479.058931059000315
> 201026.954596508003306,110466.153149712001323
> 201136.653737954009557,110438.0859375 201229.015625,110446.6015625
> 201337.234375,110344.314421453003888
> 201602.105833000008715,110287.013674981993972
> 201633.079209471005015,110265.860575208993396
> 201654.23230924399104,110258.809541951995925
> 201701.239197627990507,110247.057819855996058
> 201759.997808109008474,110195.350242632994195
> 201835.208829523005988,110167.146109602006618
> 201875.164684649993433,110167.146109602006618
> 201926.872261873009847,110192.999898213995039
> 201959.777083741995739,110216.954095802997472
> 201977.918410626007244,110222.731091177993221
> 201988.233513631013921,110233.0099750340014
> 201995.575573528010864,110245.597153832000913
> 202004.566415526991477,110291.329279141995357 202007.832995906006545,110343
> .594565210005385 202027.432478181988699,110363.194047484998009
> 202086.23092500801431,110369.727208244003123 202109.096987663011532))
> POLYGON ((115970.776603916005115
> 201219.568979436997324,115948.415507140001864
> 201211.437671518011484,115877.876667327000177
> 201215.113361513998825,115770.861078696994809
> 201234.570741264993558,115673.504226935998304
> 201252.271987040003296,115605.38008013900253
> 201252.271987040003296,115568.221454612998059
> 201264.658195547992364,115555.83524610499444
> 201369.940967870992608,115580.607663122005761
> 201679.596180583990645,115580.607663122005761
> 201784.878952906990889,115586.919505661993753
> 201831.379849018994719,115648.731809919001535
> 201840.616891195997596,115884.069771580994711
> 201828.230682686989894,116001.422393611006555
> 201782.310091457999079,116026.511169429999427
> 201772.492744399001822,116038.897377938003046
> 201691.982389092998346,116026.511169429999427
> 201462.837531685014255,116010.073922094001318
> 201342.297717889014166,116007.931856666997191
> 201326.589238090993604,115985.006392772993422
> 201243.962903192004887,115970.776603916005115 201219.568979436997324))
> POLYGON ((98517.229711620195303 201597.843524243013235,98500.590508182605845
> 201528.303423192002811,98478.448680703804712
> 201488.448133730009431,98468.337419422197854
> 201471.596031594002852,98516.251840334502049
> 201474.406492373993387,98557.015183074705419
> 201461.84359671198763,98610.332209236396011
> 201443.009478722990025,98695.018452723903465
> 201443.011445915006334,98729.520536303592962
> 201455.562406898010522,98754.607470718794502
> 201477.524293372989632,98767.144678276294144
> 201502.624739994993433,98770.27906639680441
> 201530.864273893996142,98779.685264336803812
> 201565.380953930987744,98785.955167396095931
> 201593.622960754000815,98792.208737969893264
> 201625.063442117010709,98798.48112619240419
> 201647.06419227400329,98807.865833855903475
> 201681.591490964987315,98814.079151654601446
> 201706.722715504001826,98823.394519565306837
> 201735.010467757005244,98832.720899762105546
> 201757.017490892991191,98841.9955039366032
> 201785.326495837012772,98854.454088786806096 201807.334191939007
> 724,98870.110594349302119 201823.030862001993228,98895.293073446606286
> 201829.245918158005225,98942.534181592505774
> 201832.254326708993176,98999.191873311501695
> 201825.851877206005156,99033.766218002405367
> 201825.80423142699874,99104.144210250597098
> 201814.518008176004514,99124.319636261396226
> 201736.747885538003175,99122.505474449804751
> 201711.941592315997696,99141.3037583444966
> 201620.635641970991855,99165.801258116000099
> 201559.391892541985726,99190.298757887401734
> 201506.31397637000191,99231.127924173299107
> 201471.609185026987689,99247.459590687605669
> 201455.277518513001269,99280.122923716204241
> 201449.153143570001703,99314.827715059203911
> 201453.236060199007625,99361.781256287795259
> 201459.360435142007191,99412.81771414510149
> 201459.360435142007191,99472.020005259502796
> 201463.443351769994479,99531.986711309000384
> 201469.049295456003165,99558.680212357605342
> 201474.769331394985784,99581.560356113506714
> 201467.142616809986066,99617.787250393696013 201442.355794408009388,
> 99663.547537905498757 201387.06211366399657,99683.891798950600787
> 201354.696907219011337,99696.696507354907226
> 201297.682870413991623,99702.091943024803186
> 201238.333078044001013,99719.239123384293634
> 201205.061434551986167,99837.651282128703315
> 201210.617192092002369,99856.793144177296199
> 201133.5349045789917,99882.275247354496969
> 201044.347543459007284,99882.275247354496969
> 200980.917275145009626,99824.486152769197361
> 200927.583312781003769,99745.811495629997808
> 200895.688181509001879,99696.905627678701421
> 200889.309155254013604,99647.999759727303172
> 200889.309155254013604,99603.346575945601217
> 200865.919392320996849,99577.830470927496208
> 200825.518892708991189,99573.357162895204965
> 200799.411616111989133,99565.265625 200752.1875,99480.932122314494336
> 200662.115995802014368,99385.374235400202451
> 200566.558108888013521,99302.5574000744964
> 200528.334954121994087,99206.999513160204515
> 200477.370747768,99124.182677834498463
> 200445.518118795996998,99041.365842508806963 200413.6
> 65489825012628,98964.919532977393828
> 200407.294964030006668,98913.955326623094152
> 200413.665489825012628,98831.138491297402652
> 200420.036015618999954,98780.174284943102975
> 200407.294964030006668,98741.951130177403684
> 200400.924438235990237,98703.727975411704392
> 200400.924438235990237,98684.616398028796539
> 200420.036015618999954,98652.763769057404716
> 200458.259170384990284,98627.281665880203946
> 200509.223376739013474,98614.540614291705424
> 200553.817057298991131,98594.275308945696452
> 200604.480320664006285,98571.626018197406665
> 200622.935298311000224,98552.068272292599431
> 200630.86704303798615,98539.96058198279934
> 200635.777379292994738,98529.926012361902394
> 200633.773593049001647,98474.484423382295063
> 200617.259077183000045,98427.222740973404143
> 200585.119586117012659,98419.274888489802834
> 200571.873165311000776,98411.327036006099661
> 200555.977460344001884,98406.028467683703639
> 200540.081755377002992,98401.037026831007097
> 200510.133110260008834,98404.313263080301112 200477.37
> 0747768,98407.278023908293108 200471.441226111986907,98429.795366257400019
> 200426.406541412987281,98480.759572611699696
> 200388.183386647986481,98488.25505414759391
> 200361.949201271985658,98543.145972666199668
> 200334.503742011991562,98591.819421780499397
> 200306.110896695987321,98664.829595452101785
> 200245.269085303007159,98717.55916532590345
> 200200.651756948005641,98758.120372921199305
> 200164.146670112007996,98782.457097478400101
> 200139.809945554996375,98798.68158051649516
> 200103.30485871899873,98806.793822035600897
> 200070.855892643012339,98802.73770127609896
> 200038.406926566996844,98786.513218237902038
> 199989.733477452013176,98770.288735199806979
> 199961.340632136008935,98721.61528608550725
> 199920.779424540000036,98676.997957730694907
> 199916.723303781007417,98652.661233173494111
> 199912.667183020996163,98620.21226709720213
> 199912.667183020996163,98595.875542540103197
> 199920.779424540000036,98567.482697223400464
> 199937.003907578997314,98547.202093425701605 199957.28451137599768
> 1,98518.809248108998872 199981.621235933009302,98486.460399380899617
> 200004.265430042985827,98489.364318489300786
> 200024.592863802012289,98464.802109638505499
> 200078.629723274003481,98464.262699141996563
> 200093.193806678988039,98456.011726631099009
> 200126.197696722985711,98446.110559617896797
> 200146.000030749011785,98427.958420093797031
> 200172.403142783994554,98418.057253080696682
> 200183.954504299006658,98408.156086067494471
> 200197.156060317007359,98396.60472455220588
> 200218.608588845003396,98389.500370249093976
> 200231.29375635299948,98371.598643074597931
> 200238.965925141994376,98333.319407395203598
> 200255.371311861992581,98306.025194557703799
> 200269.018418280989863,98269.112592705001589
> 200287.474719207006274,98204.73896747980325
> 200334.291901188989868,98189.019572151999455
> 200338.221750021009939,98158.245990918396274
> 200357.159338472003583,98089.639685200498207
> 200385.102408289007144,98081.517923983104993
> 200385.283505508996313,97960.390625 200387.984375,97960.53125 200462
> .90625,97952.702348880004138 200468.807172528991941,97874.982343940704595
> 200497.440858559013577,97815.760852863502805
> 200515.508432108006673,97788.264959257794544
> 200516.404931988014141,97628.1640625 200521.625,97545.140625
> 200571.6875,97453.8828125 200663.390625,97432.172966100901249
> 200719.611832947004586,97432.172966100901249
> 200814.149674026994035,97391.632047611507005
> 200906.814630575012416,97310.550210632602102
> 200953.147108848002972,97281.592411711593741
> 201005.271146905986825,97298.967091064201668
> 201080.561424101004377,97393.154077968996717
> 201180.288822000002256,97384.492606533298385
> 201213.852023813000415,97375.972918158804532
> 201247.930777311004931,97371.713073971506674
> 201286.269374997005798,97367.453229784296127
> 201324.607972681988031,97364.349836419205531
> 201353.322511200996814,97357.407588963804301
> 201381.091501023009187,97343.523094052899978
> 201415.802738300000783,97337.572596233905642
> 201434.645981393987313,97336.809815142099978 201461.818765625008382,9734
> 9.513871174698579 201469.943252592987847,97379.341626658599125
> 201485.734417261002818,97407.229792953803553
> 201494.07962061901344,97433.735589097006596
> 201507.332518690993311,97461.359725811693352
> 201478.776649344014004,97475.033982932800427
> 201462.367540798994014,97491.434609434494632
> 201440.47153929900378,97505.10609183460474
> 201432.261041699995985,97516.037888276798185
> 201432.245611541991821,97526.964731954096351
> 201432.220416394993663,97537.883803492994048
> 201437.649572066002293,97548.795392309693852
> 201448.533621701004449,97559.70561598999484
> 201467.6195666519925,97573.361707977295737
> 201486.727366033999715,97589.557681029094965
> 201502.710318421013653,97597.734362054106896
> 201524.53357453100034,97600.60133329690143
> 201535.737971330003347,97606.57535659680434
> 201558.627370881004026,97612.051900806705817
> 201577.785811322013615,97628.556533691604272
> 201594.389318625995656,97647.728598830304691
> 201602.651486807008041,97661.417486119898967
> 201605.419739005010342,97677.844237 103301566
> 201605.461036202003015,97697.004495247500017
> 201605.503469821007457,97713.42738492290664
> 201602.802923312992789,97729.850563829895691
> 201597.364262980991043,97751.750086228101281
> 201583.724703571002465,97762.706400898299762
> 201564.597978879988659,97791.824471388303209
> 201508.831175463012187,97781.584295108594233
> 201488.350822904001689,97775.440189340806683
> 201461.726364575995831,97773.392154084795038
> 201439.197976761002792,97773.392154084795038
> 201420.765659458003938,97773.392154084795038
> 201406.429412666009739,97771.344118828899809
> 201385.949060106009711,97769.296083572902717
> 201344.988354987988714,97767.248048316992936
> 201306.075685124989832,97759.658281083698967
> 201286.342290317988954,97752.91301846850547
> 201282.753545754996594,97759.2005225696048
> 201278.963012697990052,97795.810685377102345
> 201238.285054022999248,97803.946277112103417
> 201181.3359118780063,97799.878481244595605
> 201120.318973865010776,97787.675093642101274
> 201079.641015189990867,97767.33611430460 5871
> 201030.827464780013543,97771.403910172099131
> 200982.013914370007114,97803.946277112103417
> 200953.539343298005406,97840.556439919702825
> 200937.268159828003263,97917.844561402205727
> 200920.99697635800112,97966.658111812299467
> 200900.657997019996401,98011.403866354899947
> 200888.454609417996835,98117.166558910001186
> 200892.522405285009881,98157.844517585006543
> 200912.861384622985497,98194.454680392605951
> 200949.471547430002829,98226.997047332595685
> 200977.946118502994068,98271.742801875196164
> 200998.285097840009257,98312.420760550201521
> 200998.285097840009257,98349.03092335780093
> 200990.149506104993634,98389.708882032806287
> 200977.946118502994068,98430.386840707898955
> 200973.878322634991491,98454.793615912902169
> 200986.081710238009691,98466.9970035153965
> 201006.420689574995777,98466.9970035153965
> 201047.098648249986582,98462.92920764790324
> 201071.505423455004347,98422.25124897279602
> 201136.590157335012918,98393.776677900299546
> 201156.929136672988534,98365.302106827803073 20
> 1173.200320142990677,98288.013985345198307
> 201209.810482950008009,98255.471618405194022
> 201230.149462288012728,98235.741011640697252
> 201247.413743206998333,98215.428414689595229
> 201273.563125437009148,98204.592879323899979
> 201303.360847692005336,98141.827769452604116
> 201339.880363094998756,98126.28200495299825
> 201346.54283359501278,98112.957063953304896
> 201355.426127593993442,98097.41129945369903
> 201362.088598094007466,98075.203064454297419
> 201386.517656593001448,98061.878123454604065
> 201404.284244593000039,98055.215652954793768
> 201419.830009093013359,98052.994829454793944
> 201439.817420592007693,98052.994829454793944
> 201450.921538091992261,98052.994829454793944
> 201468.688126091001322,98068.54059395439981
> 201488.67553759101429,98074.24727909489593
> 201495.095558374014217,98086.3071819540055
> 201508.662949090008624,98108.515416953407112
> 201519.767066589993192,98150.711063452297822
> 201521.987890090007568,98183.821754554504878
> 201497.59053875200334,98192.906709951304947 201490.896
> 361090999562,98206.231650950998301
> 201477.571420091000618,98232.881532950297697
> 201455.363185091991909,98261.479439994101995
> 201460.476110496005276,98320.731431522901403
> 201532.296706288005225,98335.984207369605429
> 201547.643376371008344,98340.592006721301004
> 201552.279540776013164,98364.980947752206703
> 201595.294607529009227,98372.965486600704025
> 201594.230002349009737,98411.086400598898763
> 201592.323956648993772,98449.207314597195364
> 201598.042093749012565,98477.7980000959069
> 201596.136048048996599,98492.59790267610515
> 201594.242418620007811,98504.327968303201487
> 201595.060795291996328,98517.229711620195303 201597.843524243013235))
> POLYGON ((111268.085558616992785
> 201117.678019579994725,111228.315737778000766
> 201168.982642440008931,111216.591625179993571
> 201204.732609305006918,111202.522343101998558
> 201240.535305389988935,111190.852409072002047
> 201288.251953380007762,111181.470461331002298
> 201316.844429777003825,111169.715981179993832
> 201354.88084900699323,111148.467266656007268
> 201404.662459124985617,111137.268502816004911
> 201422.708713806991,111148.926390029999311
> 201499.646909570001299,111153.948041715004365
> 201518.059632416989189,111160.265205866002361
> 201541.222567638003966,111171.604021702994942
> 201586.577830985013861,111205.620469212997705
> 201662.16993656300474,111219.432669955000165
> 201669.843381420010701,111239.636916723000468
> 201681.067962956993142,111269.873758953996003
> 201684.84756823600037,111300.11060118500609
> 201681.067962956993142,111330.347443416001624
> 201665.949541842011968,111364.363890926993918
> 201639.492304888990475,111398.380338436996681
> 201609.255462658009492,111473.97244401399802 9
> 201582.798225706006633,111547.173674204997951
> 201572.503483340988168,111569.1484375 201577.1875,111743.6875
> 201568.625,111837.856439356997726
> 201534.673544504999882,111899.081475886996486
> 201491.537723313987954,111935.259906563005643
> 201458.142248843010748,111938.442736305994913
> 201451.49559855600819,111947.709641395995277
> 201447.151736795000033,111981.467811139998958
> 201401.117868962988723,111993.743509228006587
> 201352.015076607989613,111996.812433750004857
> 201312.119057820993476,111990.674584705993766
> 201278.360888077004347,111953.847490440006368
> 201238.464869288989576,111901.675773563998519
> 201213.913473112013889,111837.228358598993509
> 201207.775624067988247,111694.292244825002854
> 201193.169113206007751,111600.935451490004198
> 201193.169113206007751,111547.075763027998619
> 201196.759759103995748,111489.625428668005043
> 201196.759759103995748,111435.765740204995382
> 201196.759759103995748,111385.496697640002822
> 201193.169113206007751,111338.818300971994177 201168.03459192399
> 1684,111292.139904305004166 201135.718778845999623,111268.085558616992785
> 201117.678019579994725)) POLYGON ((107998.849780966003891
> 201004.462561169988476,107998.849780966003891
> 200987.818225914990762,107973.631091185001424
> 200917.205894527985947,107993.806043010001304
> 200866.768514966010116,108019.024732791003771
> 200826.418611316010356,108049.287160527994274
> 200775.981231754005421,108074.505850308996742
> 200750.762541973002953,108109.812016002993914
> 200725.543852192000486,108128.643901174000348
> 200719.266557135008043,108135.613802649997524
> 200684.417049753013998,108145.975263621003251
> 200656.786487164994469,108156.336724591004895
> 200632.609744901012164,108163.244365238002501
> 200611.886822959990241,108173.605826208993676
> 200587.710080694989301,108170.152005885000108
> 200556.62569778400939,108159.790544914998463
> 200532.44895551900845,108111.437060386000667
> 200466.826369373011403,108080.352677474002121
> 200453.011088078987086,108052.722114885997144
> 200446.10344743198948,108014.730091328005074
> 200442.649627108010463,108000.914810033995309
> 200442.649627108010463,107973.2842474460 04883
> 200446.10344743198948,107959.468966151995119
> 200446.10344743198948,107938.7460442110023
> 200446.10344743198948,107914.093793441003072
> 200439.708612234011525,107886.938739359000465
> 200428.834345813986147,107852.400536123997881
> 200408.111423872993328,107815.544412581002689
> 200394.448896579997381,107776.6953125 200383.328125,107776.5546875
> 200308.40625,107676.578125 200183.65625,107659.8125
> 200108.75,107556.343737217001035
> 200092.166535727999872,107494.47070815799816
> 200074.878483490989311,107439.876858988005552
> 200048.491456391988322,107367.085060095007066
> 199986.618427333014552,107266.384278807003284
> 199915.697205117001431,107241.818919078999897
> 199896.590814216993749,107187.229230793993338
> 199882.943392146000406,107151.74593340899446
> 199885.67287656001281,107113.533151609997731
> 199891.131845388998045,107088.967791881994344
> 199891.131845388998045,107056.213978910993319
> 199882.943392146000406,107034.378103597002337
> 199869.295970075007062,107023.460165940006846 199844.7306
> 10347003676,107020.730681525994441
> 199811.976797376002651,107020.730681525994441
> 199781.95246881901403,107020.730681525994441
> 199743.739687019988196,107015.271712696994655
> 199721.903811705997214,106998.894806212003459
> 199702.797420805989532,106987.976868554993416
> 199686.420514321012888,106957.952539998004795
> 199667.314123421005206,106925.19872702700377
> 199648.207732520997524,106897.903882885002531
> 199626.371857207996072,106849.05252141400706
> 199602.343557815009262,106815.979063035993022
> 199580.294585563009605,106777.393361594993621
> 199569.270099437999306,106716.758687901994563
> 199580.294585563009605,106683.685229524999158
> 199635.417016193008749,106639.587285020999843
> 199751.174120515002869,106479.732236195006408
> 200026.786273664009059,106457.68326394300675
> 200131.51889186000335,106457.68326394300675
> 200175.616836364002666,106457.68326394300675
> 200208.690294742002152,106457.68326394300675
> 200252.788239246001467,106468.707750069006579
> 200302.398426811996615,106507.293451509001 898
> 200368.545343567995587,106573.44036826500087
> 200396.106558883009711,106612.026069706000271
> 200390.594315819995245,106639.587285020999843
> 200374.057586631010054,106678.172986461999244
> 200280.349454560986487,106689.197472586994991
> 200241.763753120001638,106705.734201775994734
> 200192.153565552987857,106711.246444838994648
> 200159.08010717498837,106727.783174027994392
> 200114.982162672007689,106749.832146279994049
> 200087.420947356993565,106793.930090783993364
> 200076.396461230993737,106838.028035288007231
> 200081.908704294008203,106862.951781445997767
> 200094.370577372988919,106905.74124062199553
> 200117.180722666002112,106952.436942861997522
> 200160.863798954989761,106964.487446665996686
> 200180.445867636997718,106964.487446665996686
> 200206.053188219986623,106962.981133691006107
> 200237.685760705004213,106953.943255838006735
> 200276.849898068001494,106952.436942861997522
> 200288.900401872000657,106952.436942861997522
> 200305.469844603008823,106955.449568812997313 200325.051913283998147
> ,106958.462194763997104 200338.608730064006522,106967.500072616996476
> 200355.178172793996055,106976.537950469995849
> 200370.241302548995009,106979.55057642099564
> 200383.798119328013854,106979.55057642099564
> 200403.380188009992708,106975.03163749500527
> 200427.481195617991034,106959.968507740006316
> 200454.594829175999621,106914.779118474994902
> 200487.73371463699732,106887.846888999993098
> 200526.738417268992634,106881.796058495005127
> 200537.831606529012788,106882.566679543000646
> 200577.377907629008405,106891.375725424004486
> 200600.281426920992089,106898.422962128999643
> 200621.423137036996195,106911.991120316000888
> 200653.819044495990966,106956.072870734002208
> 200642.49438741299673,107026.973464235998108
> 200625.613293722009985,107084.369182784997975
> 200615.484637507004663,107131.636245119007071
> 200608.732200030994136,107202.536838621002971
> 200612.1084187689994,107283.56608833700011
> 200639.118168674001936,107364.595338052997249
> 200686.385231008986011,107422.623317044999567 200754.
> 6566359649878,107428.3046875 200758.4375,107519.90625
> 200849.890625,107569.796875 200858.15625,107688.684005250994232
> 200872.639674481004477,107818.615005351995933
> 200923.428230226010783,107998.849780966003891 201004.462561169988476))
> POLYGON ((100820.131850730002043
> 199887.003397961991141,100885.533219525997993
> 199861.30192309000995,100952.217017300004954
> 199863.96805923001375,100994.903952544002095
> 199847.97308000701014,101010.913533093000297
> 199810.635010344994953,100991.947106438004994
> 199758.174590921989875,101056.346296178002376
> 199727.611090463004075,101061.750951698995777
> 199668.159879740007455,101067.137167517998023
> 199608.911505724012386,101045.555424838996259
> 199387.698643256997457,100996.996503809001297
> 199150.299473780003609,100878.296919070999138
> 198902.109432963014115,100856.715176390993292
> 198772.618976883997675,100864.15430682200531
> 198623.836368265998317,100867.506047731003491
> 198556.801550086995121,100851.319740720995469
> 198492.05632204801077,100802.760819691000506
> 198481.26545070798602,100565.361650214006659
> 198492.05632204801077,100424.033609007004998
> 198481.579414164007176,100393.254428033993463
> 198594.244985218014335,100405.424652344998321
> 198653.743859626003541,100409.1328125 198653 .03125,100417.6015625
> 198736.28125,100399.52124121900124
> 198864.749107434996404,100359.435855478994199
> 198909.303347189008491,100327.482004848003271
> 198970.195952045993181,100285.297103409000556
> 199065.815061973989941,100299.358737222006312
> 199169.871152189996792,100333.106658374003018
> 199234.554667730000801,100403.414827437998611
> 199279.55189593200339,100445.599728877001326
> 199332.986104420997435,100454.036709164996864
> 199394.857293198001571,100428.725768301999778
> 199459.54080873800558,100450.787415455997689
> 199495.894313235010486,100464.123712978005642
> 199522.566908278997289,100480.127270003999001
> 199551.90676282599452,100485.461789013002999
> 199589.248395886999788,100477.460010499999044
> 199618.588250434986548,100477.460010499999044
> 199650.595364487002371,100480.127270003999001
> 199685.269738042989047,100485.461789013002999
> 199719.944111599004827,100495.744669520005118
> 199767.420663550001336,100536.869912266993197
> 199775.813570233003702,100588.364197706003324 199792.49996045
> 9012073,100605.580061590997502 199798.238581754005281,100619.926614829004393
> 199818.323756286990829,100651.489031952005462
> 199832.670309525012271,100697.398002311994787
> 199852.755484057008289,100726.134032287998707
> 199872.771992027992383,100763.392147206002846
> 199884.317901180009358,100820.131850730002043 199887.003397961991141))
> POLYGON ((111815.733728721999796
> 198450.488435937004397,111847.268409116004477
> 198440.077184658002807,112084.885448607004946
> 198472.47950822499115,112199.600032269998337
> 198472.47950822499115,112278.088957934000064
> 198472.47950822499115,112338.465054599000723
> 198472.47950822499115,112435.066809262003517
> 198460.404288891993929,112501.480515593997552
> 198436.253850226989016,112610.157489589997567
> 198412.103411560994573,112755.060121585003799
> 198412.103411560994573,112851.661876248996123
> 198412.103411560994573,112960.338850244996138
> 198412.103411560994573,113032.790166242994019
> 198400.028192227997351,113081.091043574997457
> 198400.028192227997351,113171.655188571996405
> 198393.990582561003976,113253.859714706995874
> 198366.124816608993569,113278.053522946996964
> 198324.264782934013056,113272.43771138000011
> 198084.293834609008627,113269.966633602001821
> 198060.096763095993083,113249.640625 197945.03125,113203.786119340002188
> 197774.448594243003754,113171.504507050995016 197706.95067763
> 8000343,113174.439199076994555 197657.060913191002328,113192.047351234999951
> 197627.713992928009247,113224.0703125 197603.71875,113233.959184534003725
> 197596.412214148003841,113506.28125 197395.203125,113688.2109375
> 196903.75,113687.6640625 196612.359375,113704.0234375
> 196470.796875,113603.234644808995654
> 196428.332299083005637,113558.082457198994234
> 196422.688275632011937,113501.642222687005415
> 196371.892064571002265,113473.422105431003729
> 196253.367572096001823,113490.354175785003463
> 195959.878352633008035,113479.066128881997429
> 195615.592922109994106,113512.930269589996897
> 195542.220617245009635,113639.649746049995883
> 195509.367419643996982,113926.4609375 195413.15625,114125.6484375
> 195254.71875,114202.534679037999013
> 195177.470489517989336,114259.77493730399874
> 194831.016294750996167,114207.84375 194763.40625,113833.0859375
> 194380.921875,113566.6953125 194156.46875,113258.7421875
> 193940.4375,113258.6640625 193898.796875,113293.772671322003589
> 193817.82771390301059,113200 .3125 193807.296875,113042.892031096998835
> 193730.442804107005941,112845.513918776006903
> 193707.221849716006545,112518.4765625 193666.65625,112473.654395306002698
> 193726.050691479002126,112366.074928963993443
> 193727.905509864998749,112050.755803481006296
> 193675.97059507900849,111886.7734375 193667.5,111662.4296875
> 193709.421875,111471.2734375 193718.0,111313.3203125
> 193701.5625,110589.859375 193527.6875,109849.8984375
> 193420.421875,109674.428238360997057
> 193364.190407821995905,109643.911935800002539
> 193354.411103561986238,109636.86308698799985
> 193363.628828930988675,109617.980973070996697
> 193387.905832540011033,109604.493748843000503
> 193406.787946458003717,109588.309079771002871
> 193428.367505220987368,109564.032076161995064
> 193447.249619139009155,109545.149962244002381
> 193460.736843366001267,109520.872958635998657
> 193482.316402129014023,109504.688289562996943
> 193506.593405738007277,109493.898510181999882
> 193555.147412955004256,109493.898510181999882 193584.819306254998082,10
> 9501.990844718005974 193636.070758318004664,109518.478663130998029
> 193677.290304349997314,109523.570403481004178
> 193690.019655226002214,109546.937757213992882
> 193719.15719378500944,109595.135984431006364
> 193719.99894074301119,109639.015170486993156
> 193731.965991484990809,109702.839441112999339
> 193755.900092969997786,109730.762559512004373
> 193775.845177540992154,109754.696660996996798
> 193791.801245197013486,109786.608796309999889
> 193811.746329768007854,109818.520931624007062
> 193819.724363596003968,109870.378151507000439
> 193823.713380511006108,109902.29028682099306
> 193815.735346681991359,109946.169472876004875
> 193795.790262111986522,109994.037675846004277
> 193775.845177540992154,110049.883912643999793
> 193747.922059142001672,110085.785064871000941
> 193739.944025314005557,110141.631301668996457
> 193723.987957656994695,110189.499504638995859
> 193704.042873086000327,110209.444589210004779
> 193676.119754687009845,110237.367707608995261
> 193648.196636287990259,110253.323775265002041 19363
> 6.22958554601064,110281.246893664007075
> 193628.251551716995891,110317.148045891997754
> 193628.251551716995891,110353.049198118998902
> 193640.218602459994145,110404.906418002996361
> 193668.141720859013731,110424.851502574005281
> 193696.064839258004213,110448.785604057993623
> 193723.987957656994695,110472.7197055430006
> 193735.955008399003418,110508.620857771005831
> 193743.933042227989063,110540.53299308399437
> 193755.900092969997786,110564.467094569001347
> 193807.757312853995245,110552.500043826003093
> 193883.548634222999681,110524.576925426998059
> 193959.339955592004117,110488.675773199996911
> 194019.17520930399769,110440.807570229997509
> 194043.109310789004667,110404.906418002996361
> 194055.07636153101339,110384.681207326997537
> 194070.24526953799068,110378.690533179993508
> 194121.165999788005138,110382.137831747997552
> 194165.980881169001805,110402.821623155003181
> 194207.348463981994428,110430.400011696998263
> 194231.4795539570041,110464.872997375001432
> 194259.057942498999182,110495.8986844 85000558
> 194300.425525311991805,110516.582475891002105
> 194324.556615287001478,110551.055461569005274
> 194365.924198099994101,110571.739252975996351
> 194393.502586641989183,110588.975745814997936
> 194414.186378048994811,110602.764940085995477
> 194427.975572319992352,110647.579821467006695
> 194452.106662294012494,110699.289299983996898
> 194459.001259429991478,110750.99877849999757
> 194472.790453700989019,110799.260958448998281
> 194503.816140810988145,110902.679915482993238
> 194579.656709302013041,110909.574512617997243
> 194610.682396412012167,110888.890721211995697
> 194655.497277793008834,110850.970436966003035
> 194696.864860606990987,110826.839346991997445
> 194724.443249148986069,110799.260958448998281
> 194755.468936259014299,110775.129868475007243
> 194776.152727665990824,110744.104181364993565
> 194803.731116207985906,110723.420389958002488
> 194817.520310479012551,110706.183897119000903
> 194827.862206182006048,110682.052807144995313
> 194827.862206182006048,110633.790627195994603 194810.62571334
> 3004463,110620.001432924997061 194793.389220504992409,110616.381589349999558
> 194787.506974694988457,110566.667336259997683
> 194679.39820210300968,110558.904200233999291
> 194655.566445323987864,110526.745649167001829
> 194576.406935005012201,110471.086618474000716
> 194478.694414455007063,110356.057955041003879
> 194337.69153670000378,110316.275487902996247
> 194290.693536278005922,110311.222265635995427
> 194285.279369564988883,110293.364211267005885
> 194266.14573988399934,110262.270335833993158
> 194244.870983008004259,110239.359059199006879
> 194239.961423728993395,110221.41163995199895
> 194242.560156496008858,110189.499504638995859
> 194286.439342550991569,110157.587369325992768
> 194310.373444035998546,110121.686217099006171
> 194326.329511693009408,110085.785064871000941
> 194334.307545521005522,110017.971777330996701
> 194330.318528606992913,109990.048658932006219
> 194314.362460950011155,109942.180455962006818
> 194278.461308722995454,109874.367168422002578
> 194218.626055011001881,109794.586830139000 085
> 194182.724902783986181,109718.795508769995649
> 194130.867682899988722,109659.058659543006797
> 194077.035090835997835,109581.251346231001662
> 194208.078986940003233,109515.729398180003045
> 194261.315569731988944,109488.433917642003507
> 194278.722835310007213,109457.575631821004208
> 194313.568754828011151,109438.493298322995543
> 194343.555278894986259,109409.705012545004138
> 194404.24409756399109,109404.997259455994936
> 194460.73713463099557,109404.997259455994936
> 194551.758506092999596,109411.498785988995223
> 194655.782930621993728,109426.144104053993942
> 194721.686861914000474,109437.504892120996374
> 194772.810408215998905,109463.510998252997524
> 194857.330253146006726,109483.015577851998387
> 194993.862310339987744,109528.007431628997438
> 195130.999671480007237,109540.300128699003835
> 195211.383816480985843,109555.880347643993446
> 195235.86701768101193,109568.965980972003308
> 195256.430155767011456,109589.441589737994946
> 195276.905764533003094,109622.202563764003571 195305.571616805013036
> ,109639.265571069001453 195322.634624111000448,109740.961094607002451
> 195358.808199596998747,109786.007433892998961
> 195362.903321351011982,109826.958651424996788
> 195379.283808364009019,109863.814747204000014
> 195391.569173622992821,109884.290355970006203
> 195399.759417130000656,109929.336695256002713
> 195420.235025895992294,109966.192791035005939
> 195436.615512908989331,109998.953765061000013
> 195461.186243428004673,110023.524495580000803
> 195473.471608688007109,110039.90498259299784
> 195502.137460959987948,110048.095226100005675
> 195534.898434986011125,110039.90498259299784
> 195559.469165505986894,110019.429373827006202
> 195575.849652519013034,109982.573278048002976
> 195584.039896025002236,109925.24157350299356
> 195579.944774272007635,109876.10011246400245
> 195551.278921999008162,109806.48304265900515
> 195543.088678492989857,109761.956388874998083
> 195546.269153762987116,109700.009877075004624
> 195543.088678492989857,109671.344024802005151
> 195567.659409012005199,109667.248903048995999 1956
> 33.181357063993346,109679.534268308998435
> 195686.417939856008161,109708.200120581997908
> 195739.654522647993872,109736.865972853993298
> 195776.51061842701165,109753.246459867004887
> 195817.461835958994925,109765.531825126992771
> 195858.413053491007304,109788.978252504995908
> 195983.993203116988298,109793.363455138998688
> 196007.48055127900443,109814.018998974002898
> 196069.447182784002507,109840.752424557998893
> 196095.793264584994176,109871.609375 196126.203125,109904.9453125
> 196176.109375,110063.109375 196300.78125,110096.4136863409949
> 196315.760366280010203,110166.434337608006899
> 196350.770691912999609,110213.114771786000347
> 196403.286180363997119,110242.290043147004326
> 196455.801668814005097,110248.125097419993836
> 196514.152211537002586,110302.127712482993957
> 196632.078633472992806,110331.811021425004583
> 196706.407709127990529,110345.945007510003052
> 196740.329275733005488,110352.81304664099298
> 196750.631334428995615,110394.23280571300711
> 196788.624111677985638,110476.28349814799 7307
> 196628.443511113000568,110600.496684736004681
> 196423.73933556600241,110647.735460003998014
> 196333.198349635000341,110705.820310391005478
> 196265.026085896010045,110714.047213368001394
> 196253.508421728009125,110747.577993718994549
> 196235.218905173009261,110775.012268552003661
> 196241.315410690993303,110799.398290626006201
> 196256.556674486986594,110845.122082015004708
> 196302.280465876014205,110939.617917551004211
> 196387.631543133989908,110998.568331817994476
> 196440.031911371013848,111024.263017856006627
> 196397.819212879985571,111011.4229185449949
> 196295.098418395005865,110985.742719924004632
> 196196.657657013012795,111071.343381995000527
> 196051.136531492986251,111289.62507027600077
> 195760.09428045101231,111413.74603027899866
> 195764.374313553998945,111567.82722200700664
> 195785.774479071988026,111649.147850973997265
> 195909.895439074985916,111661.98795028499444
> 195999.776134249987081,111619.18761925000581
> 196106.77696183900116,111495.066659246003837 196303.65848460199777,111353
> .825566828993033 196440.619543915992836,111285.3450371719955
> 196444.899577019998105,111229.704606825995143
> 196483.4198749520001,111131.263845444002072
> 196624.660967369010905,111024.263017856006627
> 196735.94182806101162,110938.66235578400665
> 196778.742159096989781,110870.181826127998647
> 196744.501894268003525,110811.102891139002168
> 196858.729724492994137,110737.7421875 197032.53125,110756.346164237998892
> 197047.054331568011548,110770.603832997003337
> 197058.18449418299133,110875.113836668999284
> 197083.04959394299658,110896.743602483998984
> 197070.88285067101242,110907.558485392000875
> 197053.308665946999099,110914.317787209001835
> 197031.678900130995316,110916.352216811006656
> 196996.0101448080095,110935.402624857000774
> 196968.795276170014404,110949.010059175998322
> 196960.630815579002956,110965.338980358996196
> 196960.630815579002956,110981.667901541004539
> 196960.630815579002956,111000.718309588002739
> 196960.630815579002956,111022.490204497997183
> 196971.516763033985626,111041.54061 2544995383
> 196982.4027104889974,111057.869533727003727
> 196985.124197352997726,111068.755481183005031
> 196987.845684216998052,111104.134810411997023
> 196987.845684216998052,111123.185218458005693
> 196976.959736760996748,111161.286034550998011
> 196949.744868123991182,111172.171982005995233
> 196925.251486349996412,111183.057929461996537
> 196895.31513084800099,111204.829824372005532
> 196857.21431475499412,111229.323206146000302
> 196829.999446116999025,111256.538074783995398
> 196810.949038071004907,111283.752943422005046
> 196805.506064343004255,111319.132272650997038
> 196808.227551207004581,111349.06862815200293
> 196824.556472389987903,111384.447957381999004
> 196851.771341026993468,111400.776878563992796
> 196873.543235938006546,111400.776878563992796
> 196906.201078303012764,111400.776878563992796
> 196941.580407531990204,111400.776878563992796
> 196971.516763033985626,111400.776878563992796
> 197006.89609226299217,111411.662826019004569
> 197061.325829539011465,111404.164896061993204 197180.90642838599
> 1603,111394.814927754996461 197255.706174841005122,111394.814927754996461
> 197296.22270417099935,111404.164896061993204
> 197346.089201808004873,111454.031393698998727
> 197395.955699445010396,111553.764388972995221
> 197473.872102002991596,111588.04760609799996
> 197505.038663026003633,111594.280918303004
> 197558.021816766005941,111585.837985302001471
> 197630.116584069997771,111564.066090391002945
> 197654.609965843992541,111553.180142936005723
> 197670.938887025986332,111547.737169208994601
> 197681.824834481987637,111545.015682344994275
> 197728.090111166005954,111545.015682344994275
> 197738.976058620988624,111558.623116664006375
> 197755.30497980400105,111583.116498438001145
> 197766.190927259012824,111604.888393347995589
> 197774.355387849995168,111626.660288258004584
> 197787.962822169007268,111651.153670031999354
> 197831.506611989985686,111648.43218316900311
> 197864.164454354991904,111623.938801394993789
> 197885.936349264986347,111558.623116664006375
> 197907.708244175999425,111509.636353116002283 19
> 7918.594191631011199,111460.649589566994109
> 197910.429731039010221,111403.498365427993122
> 197875.050401810003677,111357.233088744003908
> 197839.671072580997134,111310.96781205899606
> 197807.013230215990916,111248.37361419199442
> 197771.633900985994842,111207.551311236005859
> 197749.862006076000398,111169.450495142998989
> 197728.090111166005954,111150.400087096000789
> 197714.482676846993854,111112.299271002993919
> 197689.989295072999084,111090.527376092999475
> 197662.774426435003988,111076.919941774001927
> 197632.838070933008566,111068.755481183005031
> 197575.686846794007579,111068.755481183005031
> 197548.471978156012483,111070.287859814998228
> 197534.68057046001195,111071.476968046001275
> 197523.978596381988609,111091.009771636003279
> 197495.418000695004594,111131.016226243998972
> 197450.966384464001749,111162.132357605994912
> 197408.737349044007715,111222.142039519007085
> 197353.172828754002694,111248.813009257995873
> 197315.388954956986709,111251.035590069994214 197290.940566030010814,11124
> 8.813009257995873 197275.382500348991016,111239.92268601199612
> 197248.711530609987676,111231.032362765006837
> 197233.153464928996982,111219.919458706994192
> 197222.04056087101344,111202.138812214994687
> 197210.927656813000795,111177.690423287000158
> 197195.3695911320101,111142.129130301997066
> 197177.588944638991961,111099.900094882003032
> 197164.253459769999608,111081.749084497001604
> 197166.620982863008976,111058.689361659999122
> 197176.585060632001841,111044.335574593002093
> 197188.701848697004607,111022.083831451003789
> 197215.40350705300807,111006.651303645994631
> 197233.040681687998585,110989.014129011993646
> 197255.087149980012327,110969.172307547996752
> 197270.519677784992382,110951.459831883999868
> 197317.549354549992131,110947.125839255997562
> 197323.431201688013971,110889.656463559003896
> 197432.424845250992803,110868.804761520994361
> 197499.150291770987678,110839.181005088001257
> 197575.45390682699508,110677.534281797998119
> 197866.418008748005377,110655.826585394999711 197982.1923
> 89567004284,110675.482207237000694
> 198021.503633251006249,110680.670410663995426
> 198031.880040106014349,110772.8513928619941
> 198091.299247335002292,110851.195853027995327
> 198126.91036559198983,110995.030376869995962
> 198167.363825422013178,111041.742101244002697
> 198166.257691459992202,111070.88276011099515
> 198157.214038708014414,111103.745107648996054
> 198133.209344020986464,111122.914036103000399
> 198126.819701202999568,111181.542586405994371
> 198084.540848561999155,111243.102022350998595
> 198057.920551936986158,111312.980300990995602
> 198039.619098007999128,111406.509511570999166
> 198061.213427170994692,111456.422567742993124
> 198097.816335029987385,111506.335623913997551
> 198174.349687826004811,111552.921143008003128
> 198267.520726012997329,111586.196513788992888
> 198314.106245105998823,111619.471884569997201
> 198367.346838355995715,111655.156382094006403
> 198401.353503132006153,111711.544425372994738
> 198396.450195020006504,111767.679327235004166
> 198408.479102562007029,111803.76604986 100574
> 198432.536917646008078,111810.021930257993517
> 198441.920738242013613,111815.733728721999796 198450.488435937004397))
> POLYGON ((106749.304256164003164
> 197684.536193120991811,106741.741458434000378
> 197662.928199609013973,106668.909426415993948
> 197584.893879589013522,106598.678538398002274
> 197525.067567574005807,106567.464810389996273
> 197512.06184757000301,106535.402126328001032
> 197512.612798543996178,106474.804943783005001
> 197505.483718244009651,106439.159542285997304
> 197516.177338692999911,106364.304199140999117
> 197541.129119741002796,106318.332917057996383
> 197560.594743246008875,106277.524471840006299
> 197589.149728560005315,106251.011042651996831
> 197617.702652300999034,106246.932053547003306
> 197654.413554252998438,106248.971548098998028
> 197676.847994334995747,106253.050537204995635
> 197697.242939863994252,106257.129526310993242
> 197717.637885392992757,106261.208515417005401
> 197754.348787344992161,106257.129526310993242
> 197774.743732873990666,106251.011042651996831
> 197786.980700190993957,106226.537108018004801
> 197799.217667508986779,106202.063173382994137
> 197805.336151168012293,106175.54974419 4999221
> 197803.296656615013489,106149.036315007004305
> 197795.138678402989171,106130.680864031004603
> 197782.90171108598588,106114.364907608003705
> 197764.546260109986179,106098.048951185002807
> 197748.23030368599575,106073.575016550006694
> 197727.835358156997245,106045.022092808998423
> 197711.519401733996347,105997.350270933995489
> 197688.894099861994619,105937.801392544002738
> 197678.969286798004759,105883.214920686994446
> 197683.931693329999689,105838.553261894994648
> 197713.706132524996065,105828.628448830000707
> 197743.48057171999244,105793.89160310299485
> 197822.879076239012647,105779.004383505001897
> 197877.465548095991835,105779.004383505001897
> 197917.164800355996704,105788.929196569995838
> 197971.751272213004995,105843.51566842700413
> 198056.112183265009662,105903.064546816996881
> 198110.69865512198885,105987.425457869001548
> 198175.209940044005634,106091.635995050004567
> 198195.059566173993517,106205.77134529700561
> 198190.097159641009057,106295.094662881005206 198190.097159641009057
> ,106399.305200062997756 198160.322720447002212,106533.290176440001233
> 198095.811435523995897,106584.974694574004388
> 198069.012055750994477,106660.517901796003571
> 197993.468848529009847,106690.459084197005723
> 197913.62569546099985,106752.188964203000069
> 197790.165935447002994,106757.800771477006492
> 197722.824248166987672,106759.949466438993113
> 197714.95107962199836,106749.304256164003164 197684.536193120991811))
> POLYGON ((109474.175572139007272
> 196095.741031971003395,109473.971052227003383
> 196117.121394882997265,109473.292631463002181
> 196188.043008231994463,109472.84375 196234.96875,109434.859374673993443
> 196490.311728851986118,109429.277305804993375
> 196554.505520853010239,109448.814546848996542
> 196618.699312852986623,109496.262132239993662
> 196668.937932680011727,109573.4453125 196692.71875,109596.231285433997982
> 196700.192961947992444,109636.914383819006616
> 196713.537755294993985,109669.813597719999962
> 196728.491943431989057,109709.945824698006618
> 196757.400673611002276,109722.33592146000592
> 196797.325516682001762,109733.500059199999669
> 196841.982067639008164,109729.722604376001982
> 196877.867888467997545,109828.395229982997989
> 196875.474480856006267,109880.335437027999433
> 196870.366754893009784,109896.92164345200581
> 196860.888922651007306,109911.668508432005183
> 196832.050797928008251,109934.3473797810002
> 196781.266356047010049,109943.480031712999335
> 196729.079773578007007,109944.565 200315002585
> 196647.692128469003364,109935.618600774992956
> 196609.652732562011806,109919.586874130996875
> 196529.494099342991831,109867.48376253900642
> 196421.279944496985991,109803.356855963997077
> 196341.121311277995119,109747.245812709996244
> 196276.994404703000328,109667.087179491005372
> 196184.811976500990568,109598.952341255004285
> 196128.700933246989734,109474.175572139007272 196095.741031971003395))
> POLYGON ((88733.627844440794433 195044.492791647993727,88728.261161760005052
> 194941.949831750011072,88723.559065339301014
> 194677.848749455006327,88734.109462049193098
> 194625.096765905007487,88742.95045656520233
> 194580.891793324990431,88738.529959307197714
> 194532.266323488001944,88720.847970275295665
> 194501.322842682013288,88681.063494953501504
> 194492.481848166004056,88650.120014147702022
> 194492.481848166004056,88610.335538825893309
> 194492.481848166004056,88552.869074472197099
> 194492.481848166004056,88442.356643022794742
> 194510.163837197993416,88384.890178669098532
> 194527.84582623001188,88379.61753736139508
> 194531.946769469010178,88376.049184153103852
> 194567.630301550991135,88384.890178669098532
> 194611.835274131008191,88391.374003449294833
> 194626.964198617992224,88395.297474394596065
> 194636.118964157009032,88398.151670442995965
> 194642.778754936996847,88411.248147234000498
> 194672.421345029986696,88413.920436478394549
> 194709.833394451998174,88408.575857989504584 194739.228576141
> 002122,88400.558990256104153 194763.279179341014242,88392.542122522703721
> 194776.64062556400313,88376.508387056004722
> 194790.002071786002489,88365.819230078093824
> 194798.018939519010019,88344.440916122402996
> 194795.346650274994317,88309.701155944494531
> 194784.65749329701066,88304.356577455502702
> 194768.62375783000607,88296.33970972210227
> 194747.245443874009652,88296.33970972210227
> 194723.194840673997533,88282.978263499797322
> 194704.488815963006346,88240.221635588502977
> 194683.110502007009927,88202.809586165996734
> 194675.093634274002397,88152.036090521200094
> 194648.37074182901415,88122.640908832196146
> 194626.992427874007262,88095.918016387600801
> 194605.614113918010844,88069.195123943005456
> 194584.235799962014426,88039.799942253899644
> 194549.496039783989545,88023.766206787098781
> 194512.083990362007171,88021.09391754270473
> 194453.293626983999275,88026.438496031594696
> 194423.898445294995327,88039.799942253899644
> 194397.17555285000708,88071.867413187399507 194327.696032493986422,
> 88079.884280920799938 194314.334586271987064,88085.228859409704455
> 194295.628561560995877,88093.245727143104887
> 194271.577958359994227,88095.918016387600801
> 194215.459884226991562,88071.867413187399507
> 194159.341810092999367,88058.775516736306599
> 194138.76882995601045,87913.336475660194992
> 194091.940382786997361,87903.998811600104091
> 194088.049689428007696,87877.309961056700558
> 194081.377476792986272,87847.285004195306101
> 194071.369157839013496,87823.932259969806182
> 194061.360838885011617,87803.915622062297189
> 194048.016413612989709,87777.226771518893656
> 194031.335882023995509,87757.210133611297351
> 194017.991456752002705,87733.857389385797433
> 193994.638712526008021,87703.832432524504839
> 193974.622074618993793,87673.807475663197692
> 193961.277649347000988,87640.446412483899621
> 193957.941543029010063,87612.741063866604236
> 193959.146123404003447,87589.661583095206879
> 193995.047537937003653,87584.875727897597244
> 194119.479773074999684,87604.019148688093992 194267.841284200985683,
> 87599.233293490498909 194440.132071314990753,87551.374741514402558
> 194607.637003231007839,87511.111238833604148
> 194768.691013953997754,87503.516189538204344
> 194799.071211136004422,87464.251222154794959
> 194867.784904057014501,87444.716871638593148
> 194926.77800765100983,87491.322852863799199
> 194982.201336675992934,87532.763892224102165
> 195028.822505955991801,87553.48441190419544
> 195068.536835342994891,87603.559001131201512
> 195118.611424570000963,87632.913070677997894
> 195123.791554489987902,87660.540430251494399
> 195127.244974436995108,87689.894499798407196
> 195127.244974436995108,87720.975279318605317
> 195151.418914064008277,87731.33553915869561
> 195189.406533477012999,87736.515669078697101
> 195236.027702758001396,87741.695798998698592
> 195284.375582011009101,87757.236188758804929
> 195348.263851024996256,87772.776578518896713
> 195377.617920571996365,87793.49709819900454
> 195400.065150225011166,87822.851167745902785
> 195415.605539985001087,87857.385367212802521 195429.419219772011274,878
> 97.099696599703748 195436.326059665007051,87919.546926253096899
> 195438.052769639005419,87943.720865879993653
> 195436.326059665007051,87976.528355373506201
> 195425.965799825004069,88012.789264813705813
> 195387.978180411999347,88040.416624387202319
> 195337.903591184993275,88042.143334360604058
> 195294.735841851012083,87974.801645400104462
> 195016.735536143009085,87960.987965613399865
> 194968.387656889011851,87947.174285826695268
> 194939.033587342011742,87935.087316013203235
> 194913.132937741989736,87926.453766146500129
> 194890.685708089004038,87919.546926253096899
> 194868.238478434999706,87923.000346199798514
> 194838.884408887999598,87931.174043854494812
> 194816.406740337988595,87964.942939161293907
> 194797.496158966008807,88013.568408999097301
> 194793.075661707989639,88040.091392546906718
> 194793.075661707989639,88075.455370610696264
> 194801.916656223998871,88101.978354158592992
> 194815.178147997998167,88124.080840448499657
> 194837.280634288006695,88141.762829480401706 194863.803617836005287,88
> 172.706310286201187 194881.485606867994647,88208.070288350005285
> 194890.32660138400388,88239.013769155804766
> 194899.167595900013112,88336.264708831295138
> 194983.157043801009422,88353.946697863197187
> 195000.839032832998782,88384.890178669098532
> 195040.623508154996671,88424.674653990907245
> 195067.146491702995263,88455.618134796706727
> 195075.987486219004495,88508.664101892398321
> 195084.828480735013727,88558.03125 195088.71875,88713.816182668699184
> 195049.482579355011694,88733.627844440794433 195044.492791647993727))
> POLYGON ((109449.010574765998172
> 193768.914184449007735,109404.45622747199377
> 193737.200397662993055,109368.178529091004748
> 193707.220374786003958,109358.566476175998105
> 193701.453143037011614,109337.845195318004698
> 193688.502342499996303,109309.353434139004094
> 193667.781061641988344,109278.271512852006708
> 193641.87946056999499,109265.320712315005949
> 193623.748339818994282,109223.878150599994115
> 193592.666418531996896,109203.156869742000708
> 193579.715617996000219,109187.615909098007251
> 193569.354977567010792,109156.533987810995313
> 193548.633696709002834,109135.812706953001907
> 193535.682896173006156,109117.681586203005281
> 193525.322255743987625,109081.419344701003865
> 193502.010814779001521,109065.878384057999938
> 193489.060014243004844,109027.025982449005824
> 193452.797772741003428,108998.960522673005471
> 193406.905145046999678,108952.598052907997044
> 193352.113135324994801,108943.023332366006798
> 193342.538414782000473,108902.020813163995626
> 193301.535895581007935,108864.087883355 998201
> 193255.173425815999508,108813.510643613000866
> 193221.455265986995073,108778.191253597004106
> 193188.65868954299367,108750.158868283004267
> 193122.081774424004834,108725.385114705000888
> 193068.995159613987198,108679.376715203005006
> 193047.760513688990613,108608.594562122001662
> 193019.447652456990909,108524.041712663994986
> 193032.45578314299928,108545.986519197002053
> 193057.143690492986934,108562.85498497899971
> 193103.531971393007552,108562.85498497899971
> 193141.48601940300432,108545.986519197002053
> 193200.52564964001067,108508.032471187994815
> 193230.045464758004528,108429.048442828003317
> 193280.025843217008514,108395.125 193314.125,108378.6875
> 193414.046875,108397.929890957995667
> 193496.864499229006469,108409.666781563006225
> 193530.990880741010187,108437.004160420998232
> 193572.26216634499724,108463.837081656994997
> 193612.771871450997423,108519.180383240003721
> 193686.831201327993767,108668.439968411999871
> 193692.801584734988865,108766.951294625003356 193701.75715984500129
> 7,108814.714361880003707 193701.757159845001297,108874.418079095004941
> 193700.281722059007734,108915.170585326995933
> 193702.319347370008472,108924.479898598001455
> 193702.784813033998944,109001.863396151005873
> 193707.559861309011467,109028.236861144003342
> 193721.234991306002485,109049.634447357006138
> 193755.349723513005301,109082.174630034001893
> 193750.343541562004248,109087.986418307002168
> 193754.863821329985512,109104.702448811003705
> 193767.865178387990454,109116.191126520992839
> 193795.267833574995166,109146.951103629995487
> 193868.120410939009162,109154.120980092004174
> 193897.600658265990205,109159.885931423006696
> 193940.426011011993978,109179.92941441500443
> 194089.320456096000271,109182.015494973995374
> 194158.161114541988354,109184.024536167999031
> 194224.45947395300027,109200.405023180996068
> 194335.027761289995397,109233.165997207004693
> 194363.693613562994869,109249.318977456001448
> 194366.630519061989617,109282.307458245995804
> 194318.64727427699836,109367.580338654006482 1
> 94196.337246885988861,109433.826963115003309
> 194113.891186616005143,109495.253789413996856
> 194011.513142784999218,109495.253789413996856
> 193941.896072979987366,109487.063545907003572
> 193868.183881422010018,109485.254126450992771
> 193850.089686860010261,109467.813941485001124
> 193801.961186989996349,109449.010574765998172 193768.914184449007735))
> POLYGON ((127270.515072127993335
> 193793.368786050006747,127297.216656082993723
> 193751.091278120002244,127324.36395335799898
> 193687.747584478987847,127333.413052449002862
> 193624.403890838992083,127360.560349723993568
> 193552.011098106013378,127360.560349723993568
> 193536.479532636993099,127372.187163285998395
> 193504.905770293989917,127386.254881483997451
> 193482.799355983006535,127404.341947737993905
> 193450.644571532000555,127414.390317879006034
> 193420.499461108993273,127422.429013991000829
> 193390.354350685985992,127432.477384131998406
> 193340.112499981012661,127438.506406216998585
> 193320.015759698988404,127446.545102329997462
> 193295.899671360995853,127490.757930949999718
> 193275.8029310790007,127517.523841492002248
> 193234.942848137987312,127503.859375 193180.625,127445.625
> 193155.71875,127367.577340528005152
> 193144.655144602991641,127342.174041061996832
> 193128.489408578985604,127323.711934264996671
> 193096.840082642011112,127326.349378093000269
> 193065.190756705007516,127331.6242657 48992912
> 193030.903986939985771,127321.074490436993074
> 193017.716767798992805,127273.600501530992915
> 193012.44188014298561,127239.313731766000274
> 193020.354211627010955,127199.752074343996355
> 193038.816318424011115,127173.377636062999954
> 193057.278425221011275,127110.586727386005805
> 193115.337449382990599,127046.65625 193156.25,126947.0546875
> 193231.296875,126904.824805576005019 193234.889640512992628,126847.328125
> 193239.78125,126797.5234375 193273.125,126747.8203125
> 193364.78125,126690.03125 193573.0,126698.4375
> 193622.9375,126797.70517302499502 193703.478939071006607,126831.625
> 193731.0,126823.4296875 193789.28125,126765.4375
> 193889.28125,126756.615268018998904
> 193961.05448461099877,126768.888486045005266
> 193999.454243955988204,126790.6328125 194030.78125,126853.810800596998888
> 194045.18699859600747,126939.777241966992733
> 194067.809746324986918,126966.924539240993909
> 194067.809746324986918,127012.17003469899646
> 194058.760647232993506,127039.317331974001718 194040.66244904
> 9996212,127063.196899021000718 194026.334708821988897,127084.562827431000187
> 194013.515151775005506,127129.808322889002739
> 193963.745106771995779,127184.102917438998702
> 193909.450512223003898,127242.922061534001841
> 193837.057719489996089,127270.515072127993335 193793.368786050006747))
> POLYGON ((86637.444249916297849 192646.798477270989679,86562.581474134101882
> 192702.945559107989538,86464.324080920006963
> 192735.698023512988584,86318.385077251194161
> 192750.284885831992142,86309.4375 192752.21875,86178.999514080802328
> 192745.856220424000639,86171.350505700102076
> 192775.359538463992067,86166.482065579897608
> 192887.975562600011472,86164.139604099400458
> 192964.043491874996107,86166.653153162696981
> 193032.694274420995498,86178.961326242599171
> 193106.251798713987228,86186.376107407500967
> 193162.658107158000348,86188.444833073503105
> 193203.506878010986838,86190.938072458695387
> 193245.187818528997013,86188.502955115793156
> 193277.036293595010648,86166.485626340901945
> 193296.612268064985983,86129.755741102402681
> 193306.362696952011902,86093.039794973898097
> 193311.255213550990447,86061.327722528207232
> 193312.198343880008906,86060.521100330006448
> 193354.142698186013149,86052.921875 193368.640625,86049.400882200396154
> 193397.301002188993152,86049.400882200396154 193644.
> 486887161998311,86049.400882200396154
> 193770.657075135008199,86021.801153581094695
> 193849.513442619005218,86048.460773519793293
> 193966.387803507997887,86077.12943762660143
> 193998.456021112011513,86123.757165353003074
> 194016.269575098005589,86159.663618478894932
> 194019.832285895012319,86238.779325217896258
> 194019.832285895012319,86292.774306317893206
> 194009.144153503992129,86342.311543267904199
> 193974.082182826998178,86366.719897739400039
> 193908.40810258599231,86386.646231839302345
> 193814.162783253996167,86430.071924297997612
> 193699.437114889995428,86440.987752643995918
> 193641.656629058008548,86459.493697405298008
> 193557.355427244998282,86495.746985053803655
> 193467.203270119003719,86513.883475580296363
> 193401.123147523991065,86531.949216421606252
> 193329.126867915998446,86549.933077051100554
> 193257.236432209989289,86573.823566026898334
> 193179.484884320001584,86609.592253071896266
> 193047.986761290987488,86621.51515766439843
> 193006.151261366991093,86627.467854693997651 192970.27
> 0004782010801,86645.377794589294354
> 192916.459683583991136,86675.281680724394391
> 192868.616463501995895,86687.244127118799952
> 192808.737121146987192,86675.260370462594437
> 192730.867501225991873,86651.30099737670389
> 192664.978199658013182,86637.444249916297849 192646.798477270989679))
> POLYGON ((108076.398786381003447
> 192838.096409596997546,108019.212125617996207
> 192830.774628718994791,107957.767357971999445
> 192811.705562897986965,107934.564431195001816
> 192816.65678388098604,107901.226037094005733
> 192878.888452868995955,107839.259992378996685
> 193001.377147229010006,107819.1906651360041
> 193022.879997846990591,107804.190567523997743
> 193048.594450895005139,107797.761954262998188
> 193072.166032854991499,107797.761954262998188
> 193093.594743727997411,107804.190567523997743
> 193110.737712427013321,107823.476407309994102
> 193125.737810038001044,107840.619376008995459
> 193138.595036562008318,107853.476602533002733
> 193151.452263085986488,107864.190957968996372
> 193164.309489609993761,107874.777746666004532
> 193179.566860115999589,107872.681311277992791
> 193195.988937320013065,107863.626076761996956
> 193220.438070512987906,107843.613631262996932
> 193242.118219803989632,107828.604297137993854
> 193250.456738762994064,107803.588740263992804
> 193252.124442553991685,107778.5731833900 06307
> 193245.453627387993038,107766.899256848002551
> 193238.78281222100486,107743.723733157996321
> 193232.100879030011129,107717.307305098001962
> 193224.896398649987532,107693.292370498995297
> 193220.093411729991203,107676.481916279997677
> 193212.88893134999671,107645.262501300996519
> 193208.085944430000382,107626.050553620996652
> 193208.085944430000382,107546.801269443996716
> 193208.085944430000382,107513.180361004997394
> 193198.479970590997254,107479.559452565998072
> 193198.479970590997254,107455.544517967005959
> 193196.07847713099909,107441.135557207002421
> 193198.479970590997254,107429.128089906997047
> 193208.085944430000382,107424.325102988004801
> 193224.896398649987532,107421.923609528006637
> 193246.509839789010584,107407.722749198001111
> 193276.733595322002657,107393.133160810000845
> 193326.338195840013213,107369.789819390003686
> 193375.942796357994666,107346.446477970006526
> 193402.20405545498943,107317.267301194005995
> 193416.793643843004247,107291.00604209699668 193413.875726164988009
> ,107253.073112288999255 193399.286137777991826,107235.565606224001385
> 193375.942796357994666,107223.893935514002806
> 193320.502360484999372,107220.97601783600112
> 193282.569430676987395,107215.14018248100183
> 193235.882747836993076,107212.222264804004226
> 193183.360229640995385,107217.086611556005664
> 193148.559534021012951,107239.74311168899294
> 193085.121333646995481,107266.930911849995027
> 193035.277033352991566,107278.2591619159939
> 192983.167083045991603,107298.650012037003762
> 192942.385382804990513,107337.692724937005551
> 192891.568461888993625,107425.23025526299898
> 192865.307202791009331,107477.752773458007141
> 192862.389285114011727,107539.029044686001725
> 192853.635532081010751,107626.669173563001095
> 192846.11706779099768,107709.237780729003134
> 192844.902823568001622,107754.16481698199641
> 192841.260090897994814,107776.021212997002294
> 192826.689160222013015,107777.235457219998352
> 192775.690902853995794,107764.449772737993044
> 192755.562930512009189,107739.593886304995976 192741.
> 692064609000226,107655.209902702001273
> 192739.990383755008224,107574.36826989200199
> 192736.75671844300814,107494.287640296999598
> 192736.75671844300814,107435.28086059600173
> 192736.75671844300814,107307.967438220002805
> 192710.340047940990189,107249.228370964003261
> 192741.659112369990908,107210.839717349997954
> 192787.019827574986266,107190.391776114003733
> 192848.363651282008504,107178.187219244005973
> 192892.440332347992808,107165.138844437999069
> 192973.630220027989708,107153.585804536996875
> 193019.078455807000864,107133.040350755007239
> 193052.599985662993276,107106.069760900994879
> 193091.918283687002258,107058.427913334002369
> 193135.863140466011828,107035.719780205006828
> 193144.513857848010957,107014.092986749994452
> 193145.595197521004593,106990.303513948994805
> 193139.107159484003205,106975.164758529994288
> 193134.781800792989088,106954.619304748004652
> 193118.561705700994935,106947.349180453995359
> 193095.778471900004661,106942.43319044499367
> 193081.738185229012743,106914.344569 431996206
> 193006.835195858991938,106833.509261397994123
> 192880.666977691987995,106802.150410886999452
> 192837.413390781992348,106785.930315795994829
> 192829.844013071997324,106765.475504108006135
> 192837.036752326996066,106745.08008326900017
> 192849.274004829989281,106720.605578262999188
> 192951.251109023985919,106683.893820753000909
> 193073.623634056013543,106651.26114741100173
> 193220.470664094988024,106648.159701577998931
> 193240.408530162996612,106703.686023931993986
> 193305.18923957599327,106744.523986015003175
> 193361.341437439987203,106785.361948097997811
> 193402.179399521992309,106826.199910181006999
> 193443.017361604986945,106861.933127003998379
> 193483.855323688010685,106887.456853305004188
> 193509.379049990006024,106912.980579606999527
> 193529.798031031998107,106938.504305908994866
> 193555.321757333003916,106964.028032211004756
> 193570.635993114992743,106994.656503773003351
> 193585.950228895992041,107035.494465855997987
> 193606.369209936994594,107071.227682679003919 193621.683445717
> 993891,107106.96089950100577 193631.892936238989932,107152.903606844003662
> 193647.20717201998923,107214.160549969004933
> 193642.102426759985974,107254.998512051999569
> 193642.102426759985974,107295.836474134994205
> 193616.578700457990635,107326.4649456969928
> 193596.159719415998552,107362.19816251899465
> 193580.845483634999255,107403.036124602003838
> 193565.531247853999957,107443.874086684998474
> 193560.426502593996702,107505.131029809999745
> 193565.531247853999957,107540.864246632001596
> 193580.845483634999255,107597.016444495995529
> 193606.369209936994594,107632.749661319001461
> 193626.788190978986677,107673.587623401996098
> 193647.20717201998923,107719.530330744993989
> 193647.20717201998923,107760.368292828003177
> 193647.20717201998923,107806.311000171001069
> 193626.788190978986677,107847.148962253995705
> 193616.578700457990635,107872.672688556005596
> 193596.159719415998552,107928.82488641999953
> 193580.845483634999255,107969.662848502994166
> 193560.426502593996702,108010.500810586003354 19
> 3529.798031031998107,108036.024536886994611
> 193478.750578428007429,108051.33877266899799
> 193432.807871085009538,108056.443517929001246
> 193376.6556732209865,108061.548263189004501
> 193310.293984835996525,108071.757753710000543
> 193243.93229645100655,108076.862498970003799
> 193218.408570149011211,108092.176734752007178
> 193187.780098587012617,108127.909951573994476
> 193152.046881765010767,108148.328932616001111
> 193131.62790072298958,108153.433677876004367
> 193106.104174420994241,108153.433677876004367
> 193085.685193379991688,108138.11944209500507
> 193049.951976557000307,108107.490970533006475
> 193034.63774077600101,108087.07198949099984
> 193024.428250255004968,108056.443517929001246
> 193009.114014474005671,108036.183897784998408
> 193001.516656919993693,108028.680963424005313
> 192954.831732009013649,108076.398786381003447 192838.096409596997546))
> POLYGON ((89080.121932107504108 193517.099371327989502,88962.2578125
> 193456.375,88696.140625 193390.125,88646.374808174296049
> 193369.756069891009247,88371.7265625 193257.34375,88283.921068780095084
> 193164.521145575010451,88265.319709947201773
> 193071.514351410995005,88246.369395027402788
> 192986.237934272008715,88180.043292808200931
> 192938.862146972998744,88090.029296939304913
> 192863.060887294006534,88090.029296939304913
> 192815.685099994007032,88108.979611859103898
> 192754.09657650499139,88170.568135348396027
> 192697.245631745987339,88232.156658837600844
> 192640.394686985993758,88255.470484046105412
> 192566.567573826003354,88258.204621776094427
> 192528.983106147003127,88236.836910174795776
> 192468.625477933004731,88186.810270191999734
> 192418.598837950994493,88102.061712345195701
> 192352.162936654989608,88033.883669395494508
> 192268.60935029599932,87931.032298502002959
> 192343.12969296600204,87996.071653062099358
> 192405.15796629601391,88007.681665892494493 192453.214374976989347,88004.10
> 8665414794814 192549.685387873993022,87959.864991856695269
> 192639.483235257997876,87924.146170138003072
> 192706.952120726986323,87900.45857388569857
> 192749.249399016000098,87880.069964836497093
> 192790.026617113995599,87823.370845245197415
> 192829.905798974010395,87787.300148790905951
> 192842.391809285007184,87783.110250826895935
> 192911.031184560008114,87781.309451840206748
> 193002.017810321995057,87773.570075112802442
> 193104.177583125012461,87765.830698385296273
> 193149.065968143986538,87764.424820577594801
> 193203.895202646002872,87766.415535847903811
> 193210.449894522986142,87766.415535847903811
> 193252.474012858001515,87752.803955785406288
> 193344.79003234099946,87744.678452219304745
> 193423.637817404989619,87877.736848745698808
> 193455.456129617989063,88097.84375 193474.171875,88164.421875
> 193515.71875,88239.3828125 193598.875,88331.530985453005997
> 193631.971292292990256,88387.96742841489322
> 193647.11975601001177,88433.29501719759719
> 193647.11975601001177,88507.067224146099761 1936
> 10.233652536000591,88553.174853488904773
> 193542.609129499993287,88605.43016674410319
> 193524.166077762987697,88702.540437722302158
> 193566.387934709986439,88741.478569676997722
> 193593.000337436009431,88831.573680249901372
> 193634.751730140007567,88895.782627220905852
> 193634.751730140007567,88962.91016269060492
> 193611.403022151003825,89009.607578669500072
> 193550.112663678009994,89080.121932107504108 193517.099371327989502))
> POLYGON ((98409.539065940101864 192650.929142634995515,98367.014779666104005
> 192581.096320259006461,98333.092519522004295
> 192507.598089946986875,98248.286869161805953
> 192434.099859634006862,98095.63669851339364
> 192405.831309514003806,97875.142007576796459
> 192405.831309514003806,97819.038025279805879
> 192403.094529889989644,97747.027945885201916
> 192381.644719006988453,97703.957204800200998
> 192371.705317218002165,97675.795566398504889
> 192360.109348464000504,97660.88646371520008
> 192351.826513640000485,97642.664227102301084
> 192331.947710061998805,97631.068258348706877
> 192317.038607379014138,97601.250052982097259
> 192278.937567188986577,97578.058115474806982
> 192247.462794857012341,97561.49244582670508
> 192230.897125209012302,97543.270209213893395
> 192217.644589491013903,97516.765137776907068
> 192201.078919843013864,97453.815593114195508
> 192191.139518053998472,97425.653954712499399
> 192186.169817159010563,97407.431718099600403
> 192182.856683229998453,97382.58321362749848 192182.8566832299
> 98453,97354.421575225802371 192187.826384123996831,97334.542771648106282
> 192197.765785913012223,97301.411432351902477
> 192207.705187701998511,97278.219494844597648
> 192209.361754667013884,97236.805320724393823
> 192219.301156455010641,97228.621023155705188
> 192222.503707677999046,97219.076023607005482
> 192226.238707501004683,97217.215517219898175
> 192242.866246040997794,97213.366727344604442
> 192252.488220728992019,97211.442332406993955
> 192273.656565042998409,97213.366727344604442
> 192290.976119480998022,97219.139912157494109
> 192312.144463795004413,97238.383861533598974
> 192335.237203046999639,97257.627810909805703
> 192364.103127111011418,97273.022970410704147
> 192392.969051174994092,97288.828125 192437.96875,97355.3515625
> 192454.53125,97430.2578125 192504.390625,97446.9375
> 192537.671875,97447.328125 192745.8125,97439.456896819800022
> 192772.120041204994777,97432.251541202698718
> 192805.237086104985792,97425.10146339610219
> 192834.75634687001002,97414.219941815303173 192860.527259905007668
> ,97383.710911557704094 192903.834346430987353,97417.775447641295614
> 192938.838340932008578,97458.35516554939386
> 193003.360018420004053,97486.46593546049553
> 192988.211987799004419,97502.224739558500005
> 192985.166370304010343,97535.18082521299948
> 192982.825515401986195,97560.566038941498846
> 192984.561835533007979,97578.209558183894842
> 192995.147947077988647,97600.746119786897907
> 193032.890658726013498,97628.593707064894261
> 193100.3111331879918,97644.715994436395704
> 193110.570770605991129,97670.728629965495202
> 193117.02846113499254,97711.022789868700784
> 193117.02846113499254,97791.611109674995532
> 193113.365355688991258,97809.068412188105867
> 193128.29823231199407,97888.578125 193128.203125,97938.390625
> 193103.15625,97984.721888358297292
> 193037.409002661996055,98330.331883189399377
> 193037.409002661996055,98382.322367742905044
> 193009.050556542002596,98391.775183116304106
> 192923.975218181993114,98387.048775429604575
> 192801.088618328009034,98363.537672238700907 192783.45529093500226
> 7,98394.8515625 192736.21875,98409.539065940101864 192650.929142634995515))
> POLYGON ((111765.625 191120.03125,111724.046875
> 191111.78125,111591.802997200997197 190957.743625238013919,111574.1015625
> 190937.125,111455.56561380000494
> 190685.228879884991329,111388.384281837003073
> 190558.769902072002878,111309.347420703998068
> 190467.877511769009288,111265.877147081002477
> 190369.081435353000415,111230.310559570993064
> 190183.344811690010829,111232.344511115006753
> 190158.170027612010017,111232.344511115006753
> 189992.805112247006036,111258.802897572997608
> 189820.825600267999107,111344.792653562995838
> 189714.992054434987949,111413.502215090993559
> 189625.287904661003267,111460.629155550996074
> 189574.312986565986648,111495.86377150399494
> 189496.796831468003802,111499.387233100002049
> 189436.897984348004684,111485.293386717996327
> 189394.616445202991599,111458.714278232000652
> 189369.192950130003737,111455.003800252001383
> 189374.68445754100685,111423.812499103005393
> 189388.052158033009619,111395.956229365998297
> 189431.10275671700947,111357.970406998007093 189474.153
> 355401009321,111322.516972787998384
> 189507.074401452991879,111294.488429531003931
> 189526.427443226013565,111245.011679795003147
> 189544.568918128992664,111148.559620662999805
> 189540.375350340997102,111035.333290377995581
> 189523.60107918799622,110968.236205765002524
> 189485.858969093009364,110968.236205765002524
> 189368.439071019005496,111071.939291139002307
> 189098.811049048992572,111071.921875 189089.53125,110988.8046875
> 189089.625,110689.421875 189006.78125,110656.057584413007135
> 189022.247075719002169,110606.038960623001913
> 189063.929262210993329,110564.3567741309962
> 189122.284323300002143,110551.85211818300013
> 189168.134728440985782,110556.8359375 189223.40625,110590.3984375
> 189389.875,110582.1640625 189431.53125,110540.6875
> 189473.203125,110518.605119743995601
> 189512.274889733991586,110507.321556437993422
> 189555.152430298010586,110502.808131115001743
> 189591.259832879004534,110502.808131115001743
> 189625.110522798000602,110507.321556437993422
> 189654.447787395009072,110516.348 407083001803
> 189681.528339331009192,110525.375257727995631
> 189701.8387532820052,110536.658821035001893
> 189719.892454571992857,110552.455809663995751
> 189737.946155862999149,110570.50951095399796
> 189753.743144492007559,110588.563212244000169
> 189774.053558443003567,110599.846775551006431
> 189787.593834411003627,110606.616913535006461
> 189803.390823040012037,110611.130338856994058
> 189821.444524330989225,110604.360200872994028
> 189848.525076265999814,110593.076637567006401
> 189875.605628201999934,110570.50951095399796
> 189904.942892797989771,110545.685671679995721
> 189970.38755997599219,110534.402108373004012
> 189999.72482457300066,110516.348407083001803
> 190056.142641104990616,110507.321556437993422
> 190096.763469008001266,110496.037993131001713
> 190128.357446265988983,110439.620176598997205
> 190223.139378040999873,110410.282912002003286
> 190261.503493283002172,110371.918796760000987
> 190299.867608525004471,110344.838244825004949
> 190329.204873120994307,110340.611846382002113 190335.242585181
> 986215,110298.276434516999871 190361.101546213991242,110263.59658901799412
> 190367.568988362996606,110221.634270811002352
> 190367.075854855997022,110170.329679568996653
> 190362.08235214400338,110161.79165450000437
> 190362.858536242012633,110142.259785670001293
> 190364.634160680987407,110109.086274697998306
> 190364.634160680987407,110091.223614943999564
> 190364.634160680987407,110065.7055295809987
> 190374.841394826013129,110037.63563568200334
> 190392.704054580011871,110009.565741782993427
> 190415.670331405999605,109981.495847883998067
> 190433.532991159998346,109958.529571057006251
> 190456.499267987004714,109935.563294229999883
> 190487.120970421994571,109926.993144163003308
> 190541.780133252992528,110081.404700176994083
> 190621.191790632001357,110226.925825697995606
> 190693.952353392989608,110319.530178301996784
> 190753.4837229239929,110392.290741062999587
> 190879.161058600991964,110399.876339402995654
> 190876.102899521996733,110435.746914839997771
> 190890.451129697001306,110478.79160536499694 19
> 0908.386417416011682,110507.488065715006087
> 190922.734647590987151,110532.59746852099488
> 190937.082877765991725,110568.468043957996997
> 190955.01816548401257,110593.577446765004424
> 190998.062856008997187,110604.338619396003196
> 191041.107546534010908,110643.796252376996563
> 191091.326352145988494,110704.776230620002025
> 191137.958100215008017,110740.646806057993672
> 191152.30633039001259,110790.865611670000362
> 191177.415733195986832,110848.258532370004104
> 191188.176905826985603,110894.890280438004993
> 191195.351020914997207,110930.76085587599664
> 191202.525136001990177,110940.497154922995833
> 191204.959210764005547,110959.457316226005787
> 191209.699251090001781,111013.263179382003727
> 191213.286308632988948,111067.069042538001668
> 191238.395711440010928,111117.287848149993806
> 191249.156884071009699,111181.85488393700507
> 191259.918056702008471,111232.073689550001291
> 191270.679229333007243,111296.640725336998003
> 191292.201574595994316,111343.272473406002973 191310.136862313986057,111386.
> 31716392999806 191328.072150032996433,111420.240015814997605
> 191358.911106290994212,111425.774796911995509
> 191363.94272546999855,111432.94891199900303
> 191369.323311785992701,111454.471257261000574
> 191385.465070732985623,111483.167717610995169
> 191396.226243364013499,111529.799465680000139
> 191406.98741599501227,111576.43121374900511
> 191403.400358451995999,111626.650019360997248
> 191396.226243364013499,111648.172364622994792
> 191385.465070732985623,111691.21705514799396
> 191371.116840558010153,111737.848803216998931
> 191367.529783014004352,111802.415839003995643
> 191363.94272546999855,111834.69935689799604
> 191349.594495294993976,111857.716902269006823
> 191326.576949923997745,111847.172214638005244
> 191262.254355376004241,111805.2175931600068
> 191173.409274600009667,111765.625 191120.03125)) POLYGON ((120357.2578125
> 189610.078125,120348.6484375 189451.90625,120169.809714855000493
> 189265.909504684997955,120125.716666948006605
> 189137.304781621001894,120114.267078342003515
> 189114.405604410014348,120091.367901129997335
> 189082.919235743989702,120054.156738160992973
> 189051.43286707700463,120019.807972344002337
> 189019.946498411009088,119991.184000829001889
> 188994.184924047993263,119974.00961792000453
> 188979.87293829099508,119951.11044070799835
> 188968.423349685006542,119925.348866344997077
> 188948.386569624999538,119888.137703376007266
> 188916.900200959003996,119859.513731861996348
> 188914.037803807004821,119833.752157498005545
> 188919.762598110013641,119825.164966044001631
> 188936.936981019011,119816.577774589997716
> 188965.560952533996897,119813.715377437998541
> 189002.77211550300126,119810.852980287003447
> 189031.396087016997626,119799.403391681000357
> 189051.43286707700463,119785.091405924002174
> 189060.020058532012627,119756.467434409001726
> 189060.020058532012627,119730.70586 0046000453
> 189048.570469925994985,119716.393874287998187
> 189034.258484168996802,119696.357094228005735
> 189017.084101259999443,119670.595519865004462
> 188994.184924047993263,119633.384356896000099
> 188968.423349685006542,119607.657095364003908
> 188957.378464517008979,119590.783410686999559
> 189013.62408010699437,119579.53428756899666
> 189086.743380375002744,119596.407972246001009
> 189137.364434405986685,119613.281656923005357
> 189193.61004999600118,119618.906218482006807
> 189283.603034941013902,119613.281656923005357
> 189356.722335208993172,119596.407972246001009
> 189401.718827681004768,119596.407972246001009
> 189446.71532015298726,119607.657095364003908
> 189486.087251066986937,119675.15183407299628
> 189519.834620420995634,119692.15625 189527.703125,119786.937229963994469
> 189564.51891542901285,119933.4296875 189652.28125,120186.036073313996894
> 189763.471598147996701,120215.391035647000535
> 189761.636913002002984,120246.287063997995574
> 189749.278501660999609,120294.088477369004977 189705.47
> 6056054001674,120329.492048568994505 189662.058699207991594,120357.2578125
> 189610.078125)) POLYGON ((117320.848728305005352
> 188474.665314292011317,117299.414537799006212
> 188474.665314292011317,117247.255125309005962
> 188471.597113558003912,117210.436716493000858
> 188468.528912823006976,117170.55010694199882
> 188471.597113558003912,117142.936300329005462
> 188483.869916496012593,117109.186092247997294
> 188517.620124578010291,117096.913289308999083
> 188548.302131925011054,117103.049690778003423
> 188588.188741476013092,117142.936300329005462
> 188628.075351026986027,117164.413705472004949
> 188664.89375984299113,117167.481906207001884
> 188704.780369393993169,117127.595296655999846
> 188726.257774536992656,117067.237074104996282
> 188716.084265159006463,117023.276471675999346
> 188695.575767189991893,116974.185259920996032
> 188664.89375984299113,116928.162248901004205
> 188637.279953230987303,116900.548442289000377
> 188600.461544415011303,116885.207438615005231
> 188572.847737801988842,116839.184427594998851
> 188532.961128250986803,116671.181893300003139
> 188357.399356542009627,116631.2076208710 05929
> 188274.375867650989676,116625.057732804998523
> 188219.026875056995777,116625.057732804998523
> 188175.977658594987588,116655.807173135006451
> 188145.228218264994211,116698.047193798993248
> 188143.299634945986327,116731.797401881005499
> 188143.299634945986327,116818.880198179002036
> 188110.192972162010847,116783.956814371005748
> 188085.003820985992206,116747.138405553996563
> 188048.185412169987103,116691.91079233000346
> 188014.435204089008039,116642.819580575000145
> 187996.025999679986853,116599.864770289001171
> 187992.957798946008552,116535.43255486000271
> 187992.957798946008552,116501.682346778994543
> 188008.298802619014168,116472.089428495994071
> 188086.153516124992166,116492.477744574993267
> 188275.232266537001124,116538.500755594999646
> 188450.119708415004425,116673.501587922000908
> 188606.59794588398654,116787.025015104998602
> 188704.780369393993169,116851.457230533997063
> 188750.803380414989078,116964.980657716994756
> 188796.826391434995458,117017.186030109995045 188813.3532751869934
> 15,117088.085622184997192 188830.787601107003866,117175.25725178400171
> 188848.221927027014317,117408.806614515997353
> 188901.403767279989552,117423.277659433006193
> 188906.340126688010059,117787.8046875 189030.6875,117962.4921875
> 189105.390625,118095.1875 188947.03125,118294.0
> 188588.78125,118272.164739287996781
> 188549.933382593007991,118131.136872842005687
> 188468.592105368006742,117939.039276711002458
> 188351.663133810012368,117646.716847816001973
> 188101.101051900011953,117632.088417018996552
> 188088.564282498002285,117621.208288876994629
> 188112.301234315993497,117560.250241645000642
> 188191.546695717988769,117511.9921875 188223.46875,117503.965618079993874
> 188237.598994586995104,117487.019840303997626
> 188342.793372385000112,117471.233778941998025
> 188394.89209519000724,117443.619972329004668
> 188440.915106211003149,117379.187756900995737
> 188465.460712088010041,117320.848728305005352 188474.665314292011317))
> POLYGON ((121152.5703125 188210.34375,121144.1171875
> 188135.40625,121133.73647602199344
> 188044.429439950996311,121071.909655173993087
> 187986.178403288999107,120986.920819081002264
> 187950.116873722989112,120973.158951521996642
> 187909.230933924001874,120994.940798979005194
> 187868.580411430011736,121047.296211491993745
> 187852.90493226700346,121138.11333848600043
> 187900.785246552986791,121235.85739656300575
> 187922.599168329994427,121275.226609556993935
> 187917.02133486000821,121312.820078655000543
> 187895.71836903798976,121326.561491694999859
> 187881.370034179009963,121340.304536412004381
> 187856.632553689007182,121340.304536412004381
> 187820.900637423997978,121329.310100639006123
> 187807.157592706993455,121310.069838034993154
> 187779.671503273013514,121271.58931282699632
> 187752.185413839004468,121246.851832336004009
> 187741.19097806600621,121202.87408924200281
> 187727.447933349001687,121142.404692487005377
> 187694.464626027998747,121035.140625 187644.34375,120969.279513731002226
> 187600.87 5062444014475,120920.112270240002545
> 187571.95315450799535,120873.836364130998845
> 187543.027544876007596,120847.80665882199537
> 187534.351219589007087,120787.070699432006222
> 187537.243879607995041,120775.502730559994234
> 187545.923437365010614,120743.688631830998929
> 187557.49220054000034,120717.658914687999641
> 187571.95315450799535,120677.168243577994872
> 187606.659444030985469,120671.383861990994774
> 187644.257924347009975,120685.844815959004336
> 187684.748595457989722,120700.305769926999346
> 187713.670503394008847,120708.982342307994259
> 187748.376792916998966,120708.982342307994259
> 187777.298700852988986,120703.19796072000463
> 187797.544036408013199,120688.737006751995068
> 187809.112799583002925,120656.922908022999763
> 187838.034707518003415,120628.001000086995191
> 187864.064424660988152,120616.432236912994995
> 187881.417569421988446,120599.07909215100517
> 187901.662904978002189,120581.725947389000794
> 187921.908240532997297,120532.558703898001113
> 187953.722339261992602,120499.46444164 3998725
> 187984.641075761988759,120474.419448643995565
> 188008.49345004800125,120458.915405356994597
> 188034.731061763013713,120457.361743265006226
> 188063.625589419010794,120470.40114216299844
> 188135.342283359990688,120468.473498817998916
> 188167.590672229998745,120448.307039191000513
> 188198.615994732012041,120418.832982815001742
> 188211.026123732008273,120372.29499906199635
> 188206.372325356991496,120335.06461205999949
> 188184.654599606001284,120304.039289558000746
> 188161.385607728996547,120298.569880139999441
> 188119.13190632199985,120277.598166940995725
> 188105.150764188991161,120214.683027343999129
> 188105.150764188991161,120200.701885211994522
> 188119.13190632199985,120183.225457545995596
> 188157.58004718599841,120172.739600946006249
> 188199.523473584005842,120158.758458814001642
> 188255.448042114003329,120154.215154488003463
> 188341.753818272001809,120151.914013551999233
> 188454.509724173985887,120157.203035614002147
> 188510.439805450994754,120174.377418522999506 188550.513365571008762
> ,120197.276595734001603 188587.724528540013125,120223.038170098006958
> 188619.210897206008667,120243.07495015799941
> 188662.146854477992747,120264.293114532993059
> 188792.290173112996854,120302.06516567300423
> 188863.627724882011535,120340.513306538006873
> 188895.085294680990046,120399.933160600994597
> 188916.05700787898968,120448.867158064997056
> 188919.552293412998552,120483.820013396994909
> 188905.571151279989863,120497.801155528999516
> 188895.085294680990046,120501.296441062004305
> 188867.123010415001772,120494.305869995994726
> 188832.17015508399345,120487.315298929999699
> 188797.217299751995597,120485.588696862992947
> 188788.691870960989036,120480.015625 188585.875,120504.8046875
> 188510.90625,120571.2265625 188469.203125,120687.578125
> 188460.71875,120770.6484375 188435.625,120870.28125
> 188377.21875,120994.7421875 188260.5,121035.58388533499965
> 188253.172124275006354,121061.062801638996461
> 188256.330668432987295,121152.5703125 188210.34375)) POLYGON
> ((119444.544810152001446 188754.89424839100684,119470.227719262999017
> 188702.220414598996285,119495.98929362600029
> 188665.009251629991923,119504.576485080004204
> 188644.972471570014022,119516.026073685992742
> 188584.86213138900348,119507.43888223200338
> 188564.825351328996476,119484.5397050199972
> 188550.513365571008762,119467.365322110999841
> 188539.063776964991121,119430.154159141995478
> 188521.889394057012396,119377.031777661002707
> 188505.813598100008676,119363.956556570003158
> 188466.587934826005949,119359.648108730994863
> 188401.961217236996163,119368.265004408996901
> 188341.642947487998754,119385.49879576600506
> 188307.175364774011541,119471.667752551002195
> 188169.305033918004483,119501.826887425995665
> 188117.60365984699456,119519.060678783003823
> 188083.136077133007348,119549.219813657997292
> 188044.360046579997288,119570.762052853999194
> 188009.892463866010075,119583.687396371999057
> 187971.116433312010486,119592.304292050001095
> 187923.72350708101294,119596.61273988999892 1
> 87884.94747652701335,119587.9958442109928
> 187837.554550295986701,119564.2890625 187829.46875,119514.359375
> 187796.21875,119519.060678783003823
> 187790.161624063999625,119407.041034962996491
> 187738.460249992989702,119351.031213052003295
> 187716.918010797002353,119320.872078177999356
> 187703.99266727900249,119290.712943303005886
> 187682.450428082986036,119269.170704107003985
> 187660.908188886009157,119243.320017071004258
> 187639.365949689992703,119221.777777875002357
> 187622.132158332999097,119200.235538679000456
> 187604.898366976005491,119165.767955964998691
> 187579.047679940995295,119148.534164608005085
> 187561.813888584001688,119131.300373250996927
> 187544.580097227008082,119096.832790536995162
> 187523.037858030002099,119079.598999180001556
> 187514.420962351985509,119058.056759982995572
> 187510.112514512991766,119023.589177268993808
> 187510.112514512991766,118980.504698877004557
> 187510.112514512991766,118941.728668323994498
> 187510.112514512991766,118915.877981287994771 187514.420962351985
> 509,118898.644189931001165 187531.654753709008219,118881.410398573993007
> 187557.505440743989311,118864.1766072169994
> 187574.739232101012021,118829.709024502997636
> 187591.973023458005628,118803.858337468001992
> 187604.898366976005491,118778.007650432002265
> 187604.898366976005491,118756.465411236000364
> 187600.589919137011748,118743.5400677180005
> 187591.973023458005628,118730.614724200000637
> 187587.664575619011885,118713.380932843007031
> 187570.430784261989174,118691.83869364700513
> 187553.196992904995568,118683.221797969003092
> 187544.580097227008082,118665.988006611994933
> 187523.037858030002099,118640.137319575995207
> 187505.804066673008492,118618.595080379993306
> 187497.187170994991902,118584.127497666006093
> 187497.187170994991902,118541.043019272998208
> 187497.187170994991902,118515.192332238002564
> 187505.804066673008492,118502.266988720002701
> 187505.804066673008492,118480.724749524000799
> 187501.495618833985645,118459.182510327998898
> 187497.187170994991902,118433.331823291999171 1
> 87479.953379637998296,118403.172688417005702
> 187462.71958828100469,118380.562757655992755
> 187445.762140209990321,118258.8125 187556.453125,118181.450536599004408
> 187603.087239759013755,118175.7890625 187606.5,118126.303979549003998
> 187642.219018152012723,118101.812529033006285
> 187659.897286296996754,118048.852477167005418
> 187700.146925715001998,117998.010827375997906
> 187759.462183805007953,117936.577167210998596
> 187825.132648119004443,117856.077888375002658
> 187903.513524879992474,117775.087181477007107
> 187954.335479392000707,117860.75 188039.84375,117935.6484375
> 188089.703125,118260.140625 188264.125,118326.6640625
> 188280.6875,118481.923787516003358
> 188401.775550191989169,118674.021383646002505
> 188497.82434825701057,119008.104159526003059
> 188572.992972829990322,119072.832697353005642
> 188583.433059575996595,119193.288837660002173
> 188666.828971632989123,119289.18789743000525
> 188701.701357003999874,119384.575444443995366
> 188730.732349572994281,119399.548317680004402 188732.3960
> 02155001042,119444.544810152001446 188754.89424839100684)) POLYGON
> ((111372.095099996004137 188299.740943785000127,111411.692066871997667
> 188235.77661267798976,111433.797061267003301
> 188195.987622766988352,111447.06005790400377
> 188173.882628372986801,111455.902055661994382
> 188160.619631735986331,111482.428048935995321
> 188138.51463734099525,111517.796039966997341
> 188103.1466463090037,111535.480035482993117
> 188072.199654155992903,111557.58502987799875
> 188041.25266200301121,111601.795018667995464
> 188010.305669850989943,111679.703143274993636
> 187993.903959407005459,111708.089456147004967
> 187965.51764653500868,111723.895309262006776
> 187942.686969812988536,111743.220879954998964
> 187912.629294893995393,111761.432373133997316
> 187885.312055126007181,111779.643866312995669
> 187871.653435242013074,111811.513979376002681
> 187857.994815357989864,111838.831219144005445
> 187839.783322178991511,111870.701332206997904
> 187798.807462527009193,111879.807078797006398
> 187739.620109695009887,111879.807078797006398
> 187698.644250042998465,111879.807078797006398
> 187657.668390389997512,111879.807078797006398
> 187612.139657443010947,111893.465698681000504
> 187566.610924495995278,111925.335811743992963
> 187557.505177907005418,111961.758798102004221
> 187562.058051200991031,111989.076037870006985
> 187571.163797790999524,112052.031989676994272
> 187591.00366297698929,112085.472466195002198
> 187591.00366297698929,112123.690153643998201
> 187600.558084838994546,112150.653343384998152
> 187594.958201267989352,112201.58331453599385
> 187573.88373044700711,112234.95122666899988
> 187545.784436018991983,112247.244667980994564
> 187515.928935689997161,112241.976050276003662
> 187472.023788146005245,112219.234372267004801
> 187414.246858525002608,112190.571106679999502
> 187352.143116421008017,112171.46226295499946
> 187280.484952453989536,112157.130630162006128
> 187237.490054074005457,112123.690153643998201
> 187199.272366624994902,112066.363622471006238
> 187156.277468245010823,112013.814302227998269
> 187113.28256986400811,111951.710560124003678 187036.847194965987001,111923
> .047294536998379 187022.51556217300822,111880.052396156999748
> 187022.51556217300822,111783.055972706002649
> 187077.474906387011288,111725.582987279005465
> 187117.263896298012696,111663.689002972998424
> 187134.94789181399392,111632.742010821006261
> 187157.052886209014105,111597.374019789000158
> 187196.841876119986409,111584.111023151999689
> 187218.946870515006594,111575.269025393994525
> 187245.472863787988899,111553.164030999003444
> 187267.577858183009084,111526.638037725002505
> 187285.261853698990308,111508.95404220900673
> 187289.682852578000166,111478.007050057000015
> 187289.682852578000166,111455.902055661994382
> 187298.524850335990777,111438.218060145998606
> 187307.366848094010493,111428.213724430999719
> 187314.267942543985555,111418.163308361006784
> 187329.343566650000867,111415.291760912004975
> 187353.751719963998767,111413.138100326003041
> 187388.210289348004153,111410.984439738997025
> 187409.746895213000244,111411.692066871997667
> 187439.996814462996554,111413.416494416000205 187461.552
> 158765000058,111406.838643280992983
> 187489.641827040002681,111396.459463025996229
> 187515.589777676999802,111391.269872899007169
> 187520.779367804003414,111352.347946944995783
> 187525.968957931007026,111321.210406180995051
> 187523.374162866995903,111285.886786597999162
> 187522.331255842000246,111267.972245605997159
> 187570.103365152986953,111239.579419033994782
> 187610.009238630009349,111177.2421875 187632.40625,111134.187045387006947
> 187627.085680340998806,111110.993501018994721
> 187582.907500594010344,111109.208495622006012
> 187525.78732786999899,111114.563511814994854
> 187429.397036398004275,111031.539677132997895
> 187399.587120585987577,110980.64536425100232
> 187385.358490571990842,110943.202993643004447
> 187395.481933842995204,110893.772756060003303
> 187391.275105112988967,110857.321210281996173
> 187368.843384634004906,110807.475082920995192
> 187297.397268748987699,110708.680741028001648
> 187228.241229425009806,110623.058978055007174
> 187218.36179523600731,110597.144974506998551 187220.3
> 55180123995524,110551.836900224996498
> 187223.840416607010411,110537.437215081998147
> 187224.948084695002763,110481.453754675996606
> 187238.120663614012301,110441.936017918997095
> 187277.638400371011812,110418.884004810999613
> 187356.673873885010835,110403.8515625 187425.296875,110404.1328125
> 187575.15625,110387.5859375 187616.796875,110304.59375
> 187683.53125,110288.109375 187758.46875,110296.59375
> 187850.03125,110429.7734375 187949.78125,110654.3125
> 188016.078125,110729.28125 188099.21875,110804.3828125
> 188257.3125,110804.5703125 188357.21875,110779.9140625
> 188507.125,110796.6796875 188582.03125,110863.265625
> 188631.90625,111029.5546875 188656.65625,111112.75
> 188698.171875,111128.937048834006418 188687.316194195009302,111137.65625
> 188681.46875,111159.028399375005392
> 188664.044445228995755,111163.733893608994549
> 188640.516974058991764,111163.733893608994549
> 188604.441518265986815,111146.480414751000353
> 188538.564598991011735,111126.46939270599978
> 188497.236989453987917,111128.921 875 188456.71875,111153.7421875
> 188398.40625,111236.6953125 188306.703125,111372.095099996004137
> 188299.740943785000127)) POLYGON ((119426.729107813996961
> 186460.716221442999085,119378.859375 186464.3125,119318.41598816899932
> 186575.773848881013691,119272.728818698000396
> 186625.614397396013374,119241.463003675002255
> 186643.852789492986631,119196.328125 186639.390625,119179.734375
> 186656.0625,119170.16212754699518
> 186702.52358496299712,119145.728563697994105
> 186757.906329688004917,119111.332661302003544
> 186874.323230103997048,119109.412672196005587
> 186900.243083033012226,119087.520113489998039
> 186948.406712188007077,119079.582597551998333
> 187022.490194270998472,119090.165952134993859
> 187062.177773958013859,119124.561854530998971
> 187072.761128542013466,119153.66607963500428
> 187064.823612603999209,119161.008420936996117
> 187051.140158360009082,119168.162090273996
> 187048.119720196002163,119193.353659322994645
> 187011.906839686998865,119227.749561718999757
> 186964.281744061998324,119272.728818698000396
> 186943.115034896007273,119317.708075677001034
> 186953.698389478988247,119360.04149401000177 186966.9275
> 82708012778,119410.312428281002212
> 186966.927582708012778,119436.770814739997149
> 186953.698389478988247,119484.39591036499769
> 186943.115034896007273,119528.891289142993628
> 186936.57159683998907,119620.859375 186971.84375,119670.734375
> 186971.78125,119672.163458017006633
> 186968.617439594003372,119696.063002031005453
> 186969.573421353998128,119743.688097656005993
> 186940.46919624999282,119793.959031927006436
> 186871.677391458011698,119807.188225156001863
> 186813.46894125000108,119801.896547865006141
> 186752.614652396005113,119772.79232275999675
> 186723.510427291999804,119743.688097656005993
> 186694.406202187004965,119677.54213150999567
> 186673.239493021013914,119660.583764127004542
> 186665.531144209991908,119629.91703588499513
> 186636.197751978994347,119590.229456197994296
> 186591.218495000008261,119553.253450278003584
> 186558.350934182002675,119542.604360572993755
> 186525.072528854012489,119510.803252240002621
> 186495.396806019009091,119474.020814053001232
> 186476.480123523011571,119426.729 107813996961 186460.716221442999085))
> POLYGON ((104237.705314263002947
> 187060.860276371007785,104252.40881888900185
> 187042.480895587999839,104285.491704297004617
> 187009.398010180011624,104318.574589704992832
> 186983.666877084993757,104333.278094331006287
> 186972.639248615014367,104359.00922742599505
> 186965.287496301985811,104403.119741304006311
> 186961.611620145995403,104432.526750555000035
> 186954.259867832995951,104458.257883650992881
> 186935.880487051006639,104480.313140589001705
> 186891.76997317300993,104487.664892902001156
> 186843.983583138993708,104483.989016745996196
> 186810.900697731005494,104476.637264432996744
> 186781.493688479007687,104520.747778310993453
> 186711.652041505993111,104553.83066371899622
> 186682.245032255013939,104557.506539875001181
> 186663.865651472005993,104557.506539875001181
> 186641.810394533997169,104553.83066371899622
> 186612.403385281999363,104549.112004732000059
> 186593.528749333985616,104546.478911405996769
> 186582.996376030001557,104535.451282936002826
> 186549.913490622013342,104531.775406779997 866
> 186513.15472905698698,104539.127159092997317
> 186494.775348274997668,104561.182416031995672
> 186487.423595961998217,104597.941177596003399
> 186469.044215180008905,104624.615997777000302
> 186462.375510134996148,104667.523188620005385
> 186408.869372785004089,104530.97891497699311
> 186328.549211817997275,104517.045329708998906
> 186314.615626549988519,104478.727970221007126
> 186297.198644963995321,104395.126458610000554
> 186279.781663378991652,104360.292495439003687
> 186272.814870745001826,104321.975135950997355
> 186265.848078109993367,104287.141172780000488
> 186251.914492842013715,104241.85702065800433
> 186231.014114938996499,104182.639283266995335
> 186192.696755451004719,104162.869312067996361
> 186183.521016568993218,104117.875 186251.375,104068.125
> 186318.046875,103968.6328125 186451.390625,103922.76319694299309
> 186519.206396819994552,103826.490804569999455
> 186706.027917956991587,103680.256358094004099
> 186880.246419192000758,103820.524656642999616
> 186944.122644020011649,103911.087107038 998511
> 186979.700749531999463,103975.774571607005782
> 186992.63824244600255,104056.633902318004402
> 187008.810108587989816,104121.321366887001204
> 187028.216347959008999,104202.180697596995742
> 187050.856960558012361,104237.705314263002947 187060.860276371007785))
> POLYGON ((110956.1328125 184968.53125,110914.5546875
> 184960.25,110706.4453125 184794.03125,110606.609375
> 184744.203125,110515.1953125 184752.65625,110365.78125
> 184861.078125,110307.6484375 184886.125,110174.6484375
> 184877.96875,109966.59375 184745.046875,109875.1875 184753.5,109817.140625
> 184828.5,109842.390625 184994.96875,109900.8203125
> 185128.109375,110004.934234061001916
> 185238.337346401996911,110260.958032437003567
> 185399.876171568001155,110381.456076778005809
> 185449.260615970008075,110474.96875 185460.375,110608.03125
> 185501.828125,110890.8828125 185634.65625,110948.9921875
> 185592.953125,110990.375 185501.3125,110989.828125
> 185209.9375,110972.8359375 185010.140625,110956.1328125 184968.53125))
> POLYGON ((113825.902120293001644
> 185226.589828989992384,113803.237753908993909
> 185233.065362241992261,113777.335620897996705
> 185236.303128869010834,113738.482421382999746
> 185236.303128869010834,113709.342521746002603
> 185239.540895495010773,113696.213571180996951
> 185241.416459861007752,113686.678155361994868
> 185242.778662121010711,113631.352828887000214
> 185235.825756717007607,113606.678959322001901
> 185228.971904059988447,113583.069623319999664
> 185223.352062363002915,113593.144240383000579
> 185179.023747286002617,113611.348809543997049
> 185157.081704987009289,113632.506144469007268
> 185139.450592548993882,113653.663479395007016
> 185113.591627640009392,113660.776022350997664
> 185093.841397310985485,113683.440388735005399
> 185077.652564179006731,113712.580288372002542
> 185051.750431168999057,113732.006888129995787
> 185025.848298158001853,113744.957954634999624
> 185006.421698399994057,113754.671254514003522
> 184983.757332015986321,113757.909021140992991
> 184964.330732258007629,113757.9090211 40992991
> 184931.953065995010547,113757.909021140992991
> 184919.001999489992158,113751.433487888003583
> 184896.337633106013527,113715.818054999006563
> 184851.008900337008527,113696.391455240998766
> 184838.057833831990138,113680.202622109005461
> 184825.106767327000853,113670.489322230001562
> 184795.96686769000371,113670.489322230001562
> 184776.540267931995913,113680.202622109005461
> 184760.35143480100669,113688.635328171993024
> 184749.107826716004638,113695.293887934007216
> 184740.229747033998137,113699.629221866998705
> 184734.449301790009486,113707.627047489004326
> 184728.850823854008922,113736.442318347995752
> 184721.591202053998131,113774.662112915000762
> 184736.454455497005256,113853.152830256003654
> 184761.240997815009905,113927.512457210003049
> 184786.02754013298545,114000.858016993006459
> 184795.195735106011853,114030.045212668002932
> 184794.058198257989716,114044.099999301004573
> 184791.715733819000889,114060.49725037299504
> 184784.688340502994834,114072.209572566993302 184772.97601830799
> 249,114093.291752517005079 184754.236302797013195,114119.058861344004981
> 184740.181516164011555,114156.538292366007227
> 184733.1541228480055,114179.962936754993279
> 184730.811658408987569,114208.07251002099656
> 184728.469193969998742,114228.046552340994822
> 184725.531560294999508,114246.672708440994029
> 184800.545461922010873,114249.887635587001569
> 184801.878484755987301,114290.292349452996859
> 184847.058539382996969,114333.253460143998382
> 184883.530762278998736,114358.959071183999185
> 184932.397475152014522,114365.835555102006765
> 184969.323262338992208,114353.768249485001434
> 185006.707341894012643,114347.734596663998673
> 185050.191630462999456,114335.667291046003811
> 185092.431613182998262,114335.667291031000786
> 185134.667182770994259,114347.734596619004151
> 185170.86909955801093,114383.936513495005784
> 185211.363575224997476,114429.481808873999398
> 185239.369150351005374,114482.456795513004181
> 185269.028753836988471,114634.093614886005525
> 185268.697831288998714,114638.861767624999629
> 185236.910146362002706,114678.549347313004546
> 185098.00361745498958,114784.382893146001152
> 184965.711685163987568,114799.645275047994801
> 184951.143047893012408,114732.552485527005047
> 184841.177063465001993,114722.076519426002051
> 184839.272342356009176,114698.565118230995722
> 184834.997542138997233,114649.128947618999518
> 184797.92041418000008,114608.962058996999986
> 184779.381850200006738,114587.333734354004264
> 184751.574004230991704,114581.154213027999504
> 184717.586636935011484,114581.154213027999504
> 184677.419748312997399,114579.375 184580.78125,114705.910072897997452
> 184498.49317712901393,114736.610282793000806
> 184489.004021344007924,114811.878443843001151
> 184457.642287572991336,114874.601911385005224
> 184426.280553802003851,114937.325378926005214
> 184344.740045998012647,114962.414765943001839
> 184263.199538193992339,114962.414765943001839
> 184181.659030390001135,114962.414765943001839
> 184125.207909602992004,114962.414765943001839
> 184049.939748553006211,114960.53125 183947.53125 ,114960.4375
> 183897.5625,114918.7109375 183806.03125,114910.2265625
> 183714.46875,114943.3671875 183656.15625,115001.453125
> 183606.125,115043.015625 183606.0625,115064.407498846005183
> 183615.55412554499344,115133.263890671005356
> 183609.478561560012167,115200.882691738006542
> 183609.478561560012167,115264.744892746006371
> 183628.261561855993932,115298.554293278997648
> 183669.584162507992005,115283.527893042002688
> 183778.525564226991264,115260.988292686000932
> 183816.091564820002532,115259.6640625 183897.171875,115317.8984375
> 183922.0625,115367.7578125 183913.6875,115409.234375 183872.0,115475.7265625
> 183871.90625,115510.805861531000119 183882.664003095997032,115583.84375
> 183905.0625,115700.1796875 183888.25,115758.296875 183854.875,115808.0625
> 183796.53125,115832.8984375 183746.546875,115832.792941189007252
> 183690.34078480899916,115743.832050748998881
> 183581.762238452007296,115716.311821575000067
> 183483.912534723000135,115674.4140625 183447.03125,115607.859375
> 183413.828125,115541 .3359375 183397.28125,115388.836998101993231
> 183397.464714267989621,115340.921968447000836
> 183315.727310738002416,115300.199966892992961
> 183266.860908873990411,115247.069402168999659
> 183205.234957342996495,115189.968019456006004
> 183172.400677638011985,115149.281687466995209
> 183164.356583123008022,115116.687022487007198
> 183160.238713352999184,115080.302414742996916
> 183152.803045765991556,115044.812092129999655
> 183131.587285251007415,115051.617580518999603
> 183034.227451910992386,115055.464519300003303
> 182960.202997207001317,115051.307476372996462
> 182935.533720634994097,115059.316751773003489
> 182865.915075789002003,115107.818047299995669
> 182849.747977279999759,115158.232971297999029
> 182806.055043149011908,115198.564910496002994
> 182748.918129285011673,115205.286900363003951
> 182664.893255954986671,115201.925905429001432
> 182631.283306622994132,115204.934963720006635
> 182617.241034598991973,115212.008890229000826
> 182584.229377559007844,115201.925905429001432 182523.731468762009172,1
> 15195.203915563004557 182473.316544764005812,115201.925905429001432
> 182429.623610632988857,115053.370701701001963
> 182371.623726808000356,115001.587185441996553
> 182457.929587240010733,114984.391581271993346
> 182486.588927523989696,114964.555282891000388
> 182635.36116538499482,114962.92347872100072
> 182647.59969665700919,114961.412086324999109
> 182723.169316434010398,114958.654253782005981
> 182861.060943615011638,114953.915414389004582
> 182879.226494620001176,114907.423554512002738
> 183057.445290815987391,114843.281216919000144
> 183088.338026384008117,114696.143222158993012
> 183174.213015165994875,114516.609258716998738
> 183260.481820977001917,114340.86959872499574
> 183363.604160721995868,114293.917522496994934
> 183397.198045655997703,114258.022769150993554
> 183461.944390608987305,114256.070118321993505
> 183467.034238201013068,114281.03244877900579
> 183507.900892180012306,114302.792964096996002
> 183554.521283365989802,114337.085747703997185
> 183601.046266001008917,114324.622999607992824 183657
> .049318303004839,114302.832865606003907
> 183672.601917076011887,114271.72273247600242
> 183675.813809434010182,114253.0819437129976
> 183672.755824121995829,114231.338889798003947
> 183666.606124509999063,114209.598386925994419
> 183660.461272551998263,114187.857788071996765
> 183654.316485652001575,114169.220854818006046
> 183651.266066698008217,114147.470927970993216
> 183654.430347421002807,114135.033834806003142
> 183663.774250574992038,114122.586305956006981
> 183676.211911399004748,114122.555219019006472
> 183704.151027462008642,114122.434988259003148
> 183735.005830298003275,114134.928026731999125
> 183778.579661936993944,114135.167685634994996
> 183810.098675941990223,114110.838388869000482
> 183854.733349110989366,114082.970732364992728
> 183864.328397806995781,114058.281749706002302
> 183869.69181637201109,114039.478262121992884
> 183838.352670399006456,113991.085295971002779
> 183841.199315467005363,113927.219248410998262
> 183872.412260295997839,113904.445987326005707
> 183829.971182818990201,113883.743 732312999782
> 183801.185059640003601,113856.162695936000091
> 183776.002374252013396,113809.709566151999752
> 183733.827109656005632,113783.965231092995964
> 183729.007718620006926,113727.760798647999763
> 183734.156421647989191,113674.622880726994481
> 183777.289146674011135,113620.306679325003643
> 183835.311151380010415,113584.354401254997356
> 183936.631207758997334,113570.118708045003586
> 184007.809673812007532,113554.133454576993245
> 184087.735941152001033,113539.5234375 184115.90625,113466.411381477999385
> 184168.854455141990911,113435.768507025000872
> 184202.498409814987099,113328.03638917299395
> 184298.143720335996477,113303.442521485994803
> 184362.661898752994603,113282.119693518005079
> 184417.652421567006968,113223.827879713004222
> 184485.118255784997018,113200.296465420993627
> 184506.741717567987507,113266.0703125 184565.84375,113432.453125
> 184640.546875,113464.738148090997129
> 184636.821743042994058,113492.917391695998958
> 184634.943126803002087,113513.58217033999972 184640.5789755239966
> 33,113539.882797704005498 184646.214824244991178,113562.42619258799823
> 184655.607905446988298,113575.576506269993843
> 184659.365137927001342,113584.969587472005514
> 184670.636835368990432,113590.60543619300006
> 184676.272684090014081,113592.484052433006582
> 184693.180230252997717,113588.726819952004007
> 184704.451927694986807,113583.09097123099491
> 184713.845008897013031,113571.81927378999535
> 184726.995322578994092,113566.183425069000805
> 184742.024252501985757,113560.54757634800626
> 184753.295949943014421,113554.911727626997163
> 184766.446263626014115,113550.691957057002583
> 184794.671173798997188,113550.691957057002583
> 184802.442400942993117,113550.691957057002583
> 184841.295600457990076,113553.929723683002521
> 184863.959966842987342,113553.929723683002521
> 184880.148799974005669,113560.806287220999366
> 184919.649390820995905,113560.54757634800626
> 184974.972666301007848,113551.154495145994588
> 185029.452537270990433,113536.125565223002923
> 185083.932408240012592,113524.368654848993174 185
> 101.837552681012312,113505.363224287997582
> 185122.981296948011732,113489.174391156993806
> 185135.932363453001017,113469.747791399000562
> 185158.596729837008752,113460.034491519996664
> 185178.023329594987445,113458.806390423997073
> 185189.076239460002398,113456.796724893007195
> 185207.163229232013691,113450.321191640992765
> 185236.303128869010834,113447.083425014992827
> 185252.491962000000058,113443.845658388003358
> 185275.156328384007793,113440.607891762003419
> 185301.058461395004997,113434.132358508999459
> 185365.81379392099916,113434.653732513994328
> 185375.198526001011487,113475.084988307004096
> 185377.015121451986488,113490.163464152996312
> 185385.239744640013669,113503.871169467005529
> 185403.059761548007373,113509.354251591998036
> 185420.879778456001077,113512.095792655003606
> 185431.845942707994254,113524.432727438004804
> 185453.778271210001549,113534.028121156996349
> 185470.227517586987233,113540.881973814000958
> 185481.19368183799088,113550.477367533996585 185490.789075557986507,11357
> 1.038925504995859 185493.530616620992078,113587.488171881996095
> 185492.159846088994527,113597.083565602006274
> 185488.047534495010041,113609.42050038400339
> 185475.710599712008843,113615.10125623899512
> 185478.686352390010143,113640.182487359998049
> 185489.659173336985987,113662.139164100997732
> 185492.788052154006436,113680.9704833470023
> 185494.341623607993824,113701.385670374002075
> 185497.45180087100016,113715.528970009007026
> 185498.994428673002403,113728.056761689003906
> 185498.928972760011675,113744.855936508000013
> 185495.405113287997665,113757.380111139995279
> 185492.199826800002484,113765.367214330006391
> 185484.459169739013305,113773.352733467007056
> 185475.134992750012316,113780.564241051994031
> 185461.950063183991006,113789.191544742003316
> 185451.942827463994035,113793.833324142993661
> 185444.106052910006838,113802.677497052995022
> 185433.134568540001055,113809.673914297993178
> 185423.730439084989484,113813.145396548003191
> 185412.758954724005889,113811.627603482993436 185400.220
> 115456002532,113812.605256128998008
> 185382.979211466008564,113812.604017530000419
> 185368.873017292993609,113815.154511704997276
> 185359.468887844996061,113829.260705887005315
> 185336.317731321993051,113843.366900074004661
> 185318.123220968001988,113848.06896480100113
> 185302.585151086997939,113846.50160988800053
> 185275.709072610014118,113837.503797190001933
> 185248.677657032996649,113825.902120293001644 185226.589828989992384))
> POLYGON ((133352.116389208997134 178404.452368089987431,133404.859375
> 178254.375,133411.396453914989252
> 178215.516751251008827,133395.173059001012007
> 178072.210096185008297,133376.245938206004212 177991.76896645501256,133298.0
> 177885.5,133228.561796452995623 177845.18436434600153,133224.234375
> 177842.671875,133121.110402910999255
> 177815.457887321012095,133077.436107073997846
> 177801.666004425002029,133033.761811236996436
> 177801.666004425002029,133022.268575489986688
> 177824.652475918002892,133024.567222640005639
> 177856.833536007994553,133040.657752684986917
> 177872.924066053994466,133061.345577028987464
> 177889.014596099004848,133077.436107073997846
> 177902.80647899498581,133091.227989970007911
> 177916.598361890995875,133102.721225715999026
> 177932.688891936006257,133116.513108612009091
> 177948.779421980987536,133125.707697209989419
> 177962.571304876997601,133128.006344358989736
> 177978.661834922007984,133121.110402910999255
> 178001.648306415998377,133107.31852001498919 178017.738836461
> 008759,133070.540165626007365 178031.530719356989721,133026.865869789005956
> 178031.530719356989721,132990.087515399995027
> 178031.530719356989721,132948.711866711993935
> 178029.232072207989404,132882.023153418005677
> 178024.854571954987478,132867.161927364009898
> 178072.410495327989338,132870.287451821001014
> 178113.042313276993809,132871.923886194999795
> 178134.315960131993052,132846.281531104003079
> 178215.516751251008827,132830.058136190986261
> 178285.818129208986647,132830.058136190986261
> 178353.415608014009194,132866.538762824988225
> 178397.090588388004107,132925.064316036994569
> 178422.997253473993624,133018.74643311399268
> 178458.802372731996002,133128.71950591399218
> 178458.802372731996002,133235.720333503006259
> 178426.107675414008554,133315.970954195014201
> 178411.246449360012775,133352.116389208997134 178404.452368089987431))
> POLYGON ((134453.860572328005219
> 174147.424040960002458,134460.68961902501178
> 174141.623379942990141,134498.803385164006613
> 174128.011320607009111,134512.415444498998113
> 174114.399261271988507,134534.194739436003147
> 174089.897554469003808,134536.917151303001447
> 174057.228612064005574,134534.194739436003147
> 174024.559669659007341,134526.027503833989613
> 173986.445903521002037,134523.305091966991313
> 173961.944196716998704,134517.860268232994713
> 173937.442489914014004,134512.415444498998113
> 173907.495959376014071,134506.970620765001513
> 173877.549428839003667,134506.970620765001513
> 173844.880486434005434,134515.137856365996413
> 173809.4891321620089,134520.582680099993013
> 173776.820189758000197,134534.194739436003147
> 173730.539188018010464,134569.58609370701015
> 173706.03748121400713,134608.088819247001084
> 173705.873708834988065,134651.379542228009086
> 173727.519070325011853,134725.336403741006507
> 173756.147532845992828,134820.764612144994317
> 173811.018752678995952,134904.264294497988 885
> 173844.418625619990053,135002.078208112012362
> 173870.661382930993568,135238.929864914010977
> 173900.341868657997111,135244.077348126011202
> 173902.915610263997223,135313.443875669996487
> 173899.899674284009961,135342.974850420985604
> 173899.957640303007793,135376.747588995000115
> 173892.163931401999434,135384.69528903500759
> 173883.080845641990891,135426.386113643995486
> 173895.554727436014218,135542.256513081985759
> 173908.877531078003813,135654.940151129005244
> 173914.214682729012566,135722.217993825004669
> 173912.342565992992604,135724.316549943003338
> 173931.229571058007423,135735.989749683998525
> 173991.263169721991289,135742.660149534989614
> 174024.615168980992166,135766.006549015990458
> 174057.967168239003513,135781.090208671987057
> 174078.968627847993048,135817.10825454199221
> 174104.981660975987324,135825.7979023999942
> 174120.105620822985657,135823.660389314987697
> 174169.261802377994172,135812.699347977992147
> 174189.707565309014171,135801.02614823699696 174203.048365011985879,1
> 35779.34734871899127 174229.729964419006137,135764.338949052995304
> 174254.743963862012606,135757.668549202004215
> 174274.755163416994037,135756.00094923900906
> 174301.436762824014295,135761.003749127004994
> 174333.121162119001383,135774.344548830995336
> 174363.137961450993316,135786.017748571000993
> 174399.825160634994972,135792.127141122007743
> 174412.043945737998001,135813.913778368994826
> 174408.41283953000675,135826.88428619800834
> 174406.173803762998432,135900.523135488998378
> 174394.000844230991788,136000.0
> 174398.303027741989354,136049.455234038003255
> 174398.850934077985585,136036.558966535987565
> 174263.440125296998303,136022.241598530992633
> 174191.853285277000396,136015.082914528989932
> 174101.176621251011966,136027.014054533006856
> 173955.616713210009038,136053.262562540010549
> 173912.664609197992831,136093.828438552009175
> 173869.712505186005728,136134.394314562989166
> 173795.739437165000709,136149.263172495004255
> 173791.83880285298801,136161.814873613999225 173779.2871017339930
> 4,136182.499387185001979 173758.602588164008921,136224.04465554599301
> 173741.984480818995507,136260.670328615000471
> 173737.207219114003237,136254.933876060007606
> 173618.770579522999469,136255.760650095995516
> 173598.562979453010485,136269.44548228799249
> 173579.404214384005172,136292.709697014011908
> 173573.930281507986365,136329.658743931999197
> 173588.983596918988042,136354.291441878012847
> 173599.931462671986083,136384.398072699987097
> 173602.66842911101412,136432.681081429996993
> 173597.181635974004166,136507.561562426999444
> 173556.139999657985754,136529.45729393401416
> 173536.981234589999076,136551.353025440999772
> 173509.611570206005126,136566.406340852001449
> 173489.084321917995112,136582.828139482007828
> 173474.031006506993435,136596.512971674004802
> 173464.451623973000096,136618.408703180990415
> 173452.135275000007823,136655.357750099006807
> 173445.292858903994784,136679.990448044001823
> 173442.555892466014484,136697.780729894002434
> 173427.502577055012807,136699.149213113007136 17
> 3406.975328767002793,136699.346701347996714
> 173385.946793317008996,136646.874765699991258
> 173364.979644809005549,136635.625 173360.484375,136614.303253522986779
> 173353.604483219009126,136594.422435632994166
> 173318.826754576002713,136588.874396433006041
> 173309.121509910008172,136555.646158068993827
> 173255.12562256801175,136518.26438990898896
> 173167.901496862003114,136514.110860113985837
> 173113.905609520996222,136539.032038887002273
> 173084.830900951987132,136597.181456024001818
> 173072.370311564998701,136634.563224184006685
> 173080.677371155994479,136676.098522138985572
> 173059.9097221789998,136684.405581730010454
> 173034.988543406012468,136676.098522138985572
> 172993.453245449985843,136655.330873161990894
> 172910.382649539998965,136603.125 172842.796875,136583.154760940000415
> 172817.777874750987394,136521.424653827998554
> 172787.577307044994086,136458.330641668988392
> 172782.319472698989557,136440.073915495013352
> 172774.340405744005693,136392.216925726999762 172706.986123848007992,13
> 6367.402190291992156 172701.6686805410136,136344.359935958986171
> 172708.758604950999143,136236.238588706008159
> 172781.430330153991235,136213.196334373002173
> 172783.202811255992856,136188.381598937994568
> 172781.430330153991235,136149.387014682986774
> 172760.160556922986871,136078.487770581996301
> 172673.308982899994589,136057.21799735201057
> 172634.314398644986795,136048.355591839994304
> 172582.912446672009537,136049.633296076004626
> 172554.377052052994259,136060.76016537900432
> 172487.385762113000965,136067.295211635006126
> 172466.404824133001966,136044.529388650000328
> 172481.202609072992345,136023.918878517986741
> 172485.067079722997732,136000.0
> 172488.746907186985482,135921.491797033988405
> 172499.760091345000546,135875.712698671006365
> 172515.564814389013918,135744.069447045010747
> 172562.298307810997358,135697.675105586007703
> 172602.50673707498936,135656.457611518999329
> 172684.755274214985548,135610.243736041011289
> 172729.25752467600978,135568.323927037999965 172789.142966107989196
> ,135546.365931845997693 172863.00167720700847,135548.362113228009548
> 172930.871844162989873,135548.362113228009548
> 172994.749648357013939,135528.400299417000497
> 173028.684731835994171,135510.772644159005722
> 173035.494907010986935,135478.799930137000047
> 173030.113361086987425,135446.810491760988953
> 173003.940184233011678,135380.819360071996925
> 172923.284356613003183,135367.572155061003286
> 172915.592431122990092,135307.662069413985591
> 172915.592431122990092,135269.494842635001987
> 172897.711104410991538,135235.056263723003212
> 172884.318323723011417,135188.629453620989807
> 172867.556312778993743,135178.102080771990586
> 172866.052402372006327,135154.039514259988209
> 172864.548491964989807,135134.488678969006287
> 172866.052402372006327,135117.945664491999196
> 172863.044581558002392,135105.914381236012559
> 172858.532850337011041,135098.39482920098817
> 172848.00547748801182,135098.39482920098817
> 172837.478104639012599,135102.906560422008624
> 172820.935090162005508,135108.922202049987391 172
> 811.911627719993703,135117.945664491999196
> 172798.376434056990547,135137.496499783010222
> 172778.825598766008625,135149.527783038996859
> 172754.763032254006248,135148.023872632009443
> 172729.196555334987352,135145.76098249500501
> 172702.938197128998581,134999.561651129013626
> 172784.968706624989863,134715.205906401999528
> 172917.341208480997011,134359.548829653009307
> 173077.960533464007312,134271.848138819012092
> 173095.98122336101369,134194.811964126012754
> 173092.771382748993346,134127.405311268987134
> 173092.771382748993346,134082.467542697995668
> 173079.932020300009754,134024.690411677991506
> 173079.932020300009754,133990.019010040006833
> 173081.97151451400714,133915.555830861994764
> 173086.351701525010867,133899.91311593199498
> 173091.405501733010169,133831.02559197001392
> 173087.045531860989286,133694.122716993995709
> 173111.936963674990693,133542.650757802999578
> 173107.481906052009435,133359.99339524799143
> 173080.751560311997309,133319.897876639006427
> 173071.84144506600569,133275.347 300405992428
> 173062.931329818995437,133199.611320810014149
> 173036.200984079012414,133141.695571707008639
> 173005.015580715989927,133106.055110721004894
> 172973.830177352996543,133030.319131124997512
> 172920.369485873990925,132950.128093906008871
> 172880.273967263987288,132874.392114310001489
> 172866.908794395014411,132860.593004425987601
> 172863.842325531004462,132866.524410490994342
> 172871.627295990998391,132870.701757064001868
> 172955.174227445008,132805.589791033009533
> 173025.644125190010527,132666.011775001999922
> 173088.84931777100428,132599.016478982986882
> 173109.871265653986484,132540.69137782100006
> 173159.864209507009946,132527.069595518987626
> 173176.51305454300018,132510.699287088995334
> 173196.521209291007835,132398.98658895000699
> 173205.407446642988361,132353.747464768995997
> 173202.74632169099641,132338.289302390010562
> 173198.713757591991453,132338.275217479997082
> 173214.469510599999921,132353.286533509002766
> 173262.472431522008264,132383.280995748005807 173292.46689376101
> 1306,132404.278444711992051 173337.463627041986911,132419.289204078988405
> 173379.507289598986972,132440.298935152997728
> 173403.554583244986134,132464.308637899986934
> 173424.604423593002139,132500.492046342988033
> 173439.288811519014416,132536.550157332007075
> 173427.566937341005541,132566.641479740006616
> 173409.941505533002783,132590.73496684798738
> 173392.34506776399212,132620.901768106996315
> 173380.953587124997284,132642.044581861991901
> 173381.433840606012382,132681.248126793012489
> 173382.289654146006797,132714.270460591011215
> 173379.762193036993267,132729.263344028004212
> 173370.933679684007075,132741.26514830198721
> 173359.07448727398878,132747.273211521009216
> 173347.160826468985761,132747.311373394011753
> 173308.295677018002607,132729.267514682986075
> 173275.127329832990654,132726.203760294010863
> 173242.034253062010976,132735.189944087993354
> 173203.129136784991715,132756.241637719998835
> 173176.396153050998691,132795.268829484994058
> 173155.135714364005253,132830.222844631993212
> 173150.088593777007191,132834.31762487499509
> 173163.21043914501206,132868.514636570005678
> 173209.842727818991989,132908.929286753991619
> 173234.713281778007513,132930.691021467995597
> 173237.822101022989955,132971.105671652010642
> 173247.148558757995488,133008.411502592003671
> 173272.019112718000542,133045.717333531007171
> 173312.433762901986483,133073.696706735005137
> 173331.08667837100802,133117.220176164002623
> 173352.848413086001528,133160.74364559398964
> 173368.392509311001049,133198.04947653299314
> 173396.371882514999015,133229.137668982002651
> 173446.11299043399049,133229.137668982002651
> 173477.201182883,133216.702392001985572
> 173495.854098353011068,133132.764272389002144
> 173533.159929291985463,133070.587887489993591
> 173548.704025517014088,133002.193864102009684
> 173567.356940986996051,132983.540948631998617
> 173623.315687394991983,133002.193864102009684
> 173682.38325304898899,133039.499695041013183
> 173722.797903233004035,133079.914345224999124
> 173738.341999458003556,133104.78489 9185004178
> 173756.994914927985519,133135.87309163401369
> 173775.647830397007056,133160.74364559398964
> 173800.51838435701211,133173.178922572988085
> 173822.280119070986984,133182.505380307993619
> 173859.585950009990484,133188.723018797987606
> 173896.891780950012617,133198.04947653299314
> 173924.871154154010583,133207.375934267998673
> 173955.959346602990991,133234.354553142999066
> 174018.867188704985892,133293.806344200012973
> 173980.648180168005638,133399.940391934011132
> 173953.004053140000906,133458.994440109003335
> 173940.477436860004673,133516.258971672999905
> 173910.055654466996202,133577.658412337012123
> 173868.537594438996166,133630.667184632009594
> 173858.440685429988662,133666.006366162007907
> 173860.964912681985879,133741.612587089010049
> 173754.187501745007467,133792.008175955008483
> 173676.30340986000374,133846.985181991010904
> 173635.070655332994647,133920.287856706010643
> 173607.582152315007988,133952.35777689400129
> 173593.837900805985555,134011.9162001000077 173589.2564836360106
> 71,134030.241868777986383 173603.000735145004001,134053.148954626987688
> 173639.652072502998635,134071.474623304995475
> 173680.884827030007727,134163.102966698992532
> 173708.373330047994386,134199.754304055997636
> 173708.373330047994386,134259.312727262004046
> 173712.954747217998374,134295.96406461900915
> 173731.280415896006161,134314.289733298006468
> 173754.187501745007467,134323.452567636995809
> 173809.164507781009888,134314.289733298006468
> 173877.88576532600564,134282.219813109986717
> 173914.537102683010744,134245.568475753010716
> 173923.699937022989616,134196.670841899001971
> 173928.325685871008318,134154.861543651000829
> 173937.766495152987773,134123.841741723997984
> 173943.16124331401079,134095.519313878001412
> 173952.602052595990244,134073.478043584997067
> 173962.929271269997116,134057.730371796002146
> 173978.676943058992038,134057.730371796002146
> 173994.160543186997529,134057.730371796002146
> 174033.653949094994459,134057.730371796002146
> 174084.049537960992893,134053.148954626987688
> 174129.863709658005973,134062.311788966006134
> 174189.422132864012383,134108.12596066299011
> 174244.399138899985701,134111.830311503988924
> 174250.098140193003928,134152.628760846011573
> 174239.002091341011692,134215.081032465997851
> 174222.016802242986159,134279.007453142985469
> 174175.98977935500443,134355.445470215985551
> 174129.277657809987431,134410.65070476901019
> 174125.031101305998163,134418.422194259997923
> 174131.831154610001249,134453.860572328005219 174147.424040960002458))
> POLYGON ((116040.234997117004241
> 164221.086214440991171,116005.172221333006746
> 164231.848056513990741,115776.856287563001388
> 164282.584930684999563,115530.772246510998229
> 164340.339348482986679,115282.177143816006719
> 164400.604827923991252,115149.233396431998699
> 164421.595945932000177,115139.046630142998765
> 164423.204382714990061,115089.36729698900308
> 164421.293639131996315,115089.433138812004472
> 164439.599353588011581,115089.234375 164461.8125,115077.452773454002454
> 164525.68601485399995,115066.086066994001158
> 164563.798366650997195,115052.75088526699983
> 164561.513623887993162,115009.697589058996527
> 164584.276581367012113,114982.511893393006176
> 164614.898029858013615,115001.919621328997891
> 164647.701165693986695,115014.445834063997609
> 164659.51369633700233,115023.641696488004527
> 164686.843966057000216,115074.045751297002425
> 164748.243322001013439,115089.561454113994841
> 164760.775235815002816,115098.799393705994589
> 164771.218124048988102,115130.219388030003756 164787.90999603
> 3995412,115137.559926048998022 164793.537741848995211,115145.3397239229962
> 164801.60568038400379,115194.144021065003471
> 164828.099441689992091,115202.269460819996311
> 164821.779655213991646,115209.849872532999143
> 164813.07138846500311,115231.652692785995896
> 164793.768727893009782,115236.113046910002595
> 164785.839209450990893,115238.84307041100692
> 164775.427485221996903,115280.123142936005024
> 164735.373990311985835,115370.668675355002051
> 164713.910008456005016,115400.646695078001358
> 164695.923196621995885,115421.848982787007117
> 164683.201823996001622,115462.793228733004071
> 164647.375608794012805,115513.973536164994584
> 164632.021516564011108,115554.91778211100609
> 164626.903485821007052,115600.9800588000071
> 164626.903485821007052,115647.042335488993558
> 164626.903485821007052,115682.868550690996926
> 164616.667424334009411,115718.694765894004377
> 164591.077270617999602,115754.520981095993193
> 164555.251055416010786,115790.347196299000643
> 164514.30680946999928,115821.055380757999956 1
> 64478.480594268010464,115872.235688190005021
> 164452.890440551011125,115933.652057108993176
> 164422.18225609199726,116005.304487514003995
> 164371.001948660006747,116046.248733460000949
> 164309.585579740989488,116056.484794945994508
> 164248.169210822990863,116040.234997117004241 164221.086214440991171))
> POLYGON ((167044.920178000989836 156448.941515787999379,167103.890625
> 156389.8125,167121.125 156347.5625,167120.50019087898545
> 156334.531851175008342,167142.447425732010743
> 156304.746318160992814,167181.638916539988713
> 156270.257806250010617,167193.994136583001819
> 156259.025788028986426,167356.728131673997268
> 156147.345595318998676,167429.798994815995684
> 156122.988640939001925,167534.076945034001255
> 156096.043303962011123,167609.40625 156104.6875,167813.462660891003907
> 156159.57993822300341,167862.380489175004186
> 156166.618474666989641,167886.893464283988578
> 156170.593551711994223,167921.344132005993742
> 156177.218680119985947,167945.857107115007238
> 156178.543705801013857,167963.082440975995269
> 156175.231141597003443,167970.370082225010265
> 156165.955961825995473,167976.995210633001989
> 156148.068115124013275,167977.657723473996157
> 156118.917550129001029,167980.714693004003493
> 156096.743362509994768,167974.230460566002876
> 156067.564316537987906,167981.048614791012369 155997.8676
> 28906009486,168025.043376913003158
> 155935.541715900006238,168043.742137861991068
> 155842.047911155008478,167993.528579501988133
> 155857.111978662986076,167937.608493436011486
> 155864.239048455987358,167917.122147729009157
> 155861.290832647995558,167900.806559688004199
> 155850.208546431007562,167888.422944397985702
> 155830.394761967007071,167885.946221340011107
> 155807.278680093004368,167885.466065674001584
> 155769.826538097986486,167892.963111713004764
> 155732.341307900001993,167923.443172912986483
> 155686.621216100000311,168001.101655837992439
> 155684.815204868995352,168006.25360671299859
> 155682.785648463992402,168018.809487743012141
> 155654.534916147997137,168020.731658331002109
> 155614.16933378300746,168013.042975975986337
> 155575.72592200798681,168001.203091748990119
> 155547.606196968001314,167997.665611266013002
> 155539.204680821014335,167972.631528369995067
> 155522.455528424005024,167950.341020847990876
> 155519.153231013013283,167935.480682499997783
> 155520.804379718989367,167905.1076341 39014408
> 155532.732533581001917,167820.858293138997396
> 155564.621556888014311,167782.046875 155581.546875,167747.049750537000364
> 155610.321038102993043,167636.265625 155701.40625,167615.658181759004947
> 155717.303584354987834,167538.604575511009898
> 155769.339785977004794,167500.578120479010977
> 155794.357190603011986,167467.555146372003946
> 155808.366937193990452,167440.1066432580119
> 155812.028761099005351,167405.511982900003204
> 155809.367633379006293,167379.882081513002049
> 155803.461450700007845,167382.404423155996483
> 155853.908283561991993,167384.962091713008704
> 155905.061654699995415,167372.954149864002829
> 155971.105334872991079,167349.564321562007535
> 156005.502155102993129,167312.709162193990778
> 156038.8795443130075,167274.929469886003062
> 156046.657716257992433,167207.653499278996605
> 156052.424228024989134,167142.29969926000922
> 156052.424228024989134,167076.945899242011365
> 156040.891204492014367,167025.047293345007347
> 156029.358180959010497,166980.837369802989997 156015.902
> 986837987555,166942.186930561991176
> 156008.649706416996196,166879.833361032011453
> 155996.525401229999261,166824.40796589499223
> 155986.999161440995522,166768.116548958001658
> 155969.67872546100989,166719.480755513010081
> 155955.861756700003752,166578.957665013993392
> 155910.693620467995061,166575.015625 155911.53125,166559.405295394011773
> 156013.845837211003527,166584.28125 156036.453125,166616.562734130013268
> 156047.620687373011606,166923.047894221992465
> 156114.744234131008852,166958.2412349130027
> 156174.302195299998857,166963.321245113009354
> 156220.02228710000054,166978.561275713000214
> 156352.102552299998933,167009.041336913011037
> 156413.062674699991476,167044.920178000989836 156448.941515787999379))
> POLYGON ((126158.075436781000462
> 221712.718626752990531,126180.025840464993962
> 221664.427738647995284,126149.295275306998519
> 221497.604670648986939,126138.7109375 221327.171875,126129.34375
> 221189.234375,126106.612250645004679 221108.317915799998445,126112.2109375
> 221058.9375,126080.65625 220989.859375,125887.1953125
> 220747.9375,125781.828125 220630.90625,125664.140625
> 220497.328125,125587.8046875 220382.828125,125510.124775638993015
> 220251.913427255989518,125489.553725217992906
> 220267.913133138994453,125460.109872019995237
> 220275.943274921010016,125427.989304895003443
> 220281.296702774998266,125379.808454208992771
> 220275.943274921010016,125319.139336007996462
> 220261.775002529000631,125324.250564721005503
> 220283.242163123999489,125334.556426376002491
> 220329.618540571013,125347.438753444002941
> 220381.14784884499386,125357.74461509899993
> 220409.488968396006385,125368.050476753996918
> 220437.830087946989806,125378.356338408993906
> 220461.018276671005879,125388.662200064005447 22048
> 9.35939622099977,125396.414742263004882
> 220521.492952252010582,125402.894839758999296
> 220547.639056632993743,125414.07867852099298
> 220610.208100515999831,125420.008905426002457
> 220625.927757525001653,125433.046701357001439
> 220660.487932616000762,125443.041733278994798
> 220735.450672033010051,125450.538007220995496
> 220800.418379526992794,125453.448151068005245
> 220846.249786027008668,125454.788265765993856
> 220867.355045670992695,125458.123645140003646
> 220919.883420886006206,125458.732129900003201
> 220925.859035978006432,125467.224272217994439
> 221009.25598709701444,125483.29907360499783
> 221112.679052077000961,125500.364027478994103
> 221167.280285576009192,125534.683972151993657
> 221251.760149387002457,125670.776474993996089
> 221422.973298122989945,125815.649139308996382
> 221563.455881700996542,125953.381228586993529
> 221684.984195769997314,125964.911884361004923
> 221695.158303806005279,126039.543256887001917
> 221721.498788227007026,126114.174629411994829
> 221725.88886896398617,126158.075 436781000462 221712.718626752990531))
> -------------- next part -------------- A non-text attachment was
> scrubbed... Name: InCircle.cpp Type: application/octet-stream Size: 8091
> bytes Desc: not available Url :
> http://lists.osgeo.org/pipermail/geos-devel/attachments/20090719/86b7314c/InCircle.obj------------------------------
> _______________________________________________ geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel End of geos-devel
> Digest, Vol 81, Issue 11 ******************************************
"#define QUESTION ((bb) || !(bb))" (Shakespeare)
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090719/fee3b5e2/attachment-0001.html
