[geos-devel] Porting LengthIndexedLine.project?
David Turner
novalis at novalis.org
Thu Jul 23 11:13:34 EDT 2009
JTS has a class called LengthIndexedLine with a method "project", which
lets you figure out the nearest point on a line to a given point. This
is useful, for instance, if you are trying to figure out what street a
person is on from (possibly slightly inaccurate) GPS observations.
http://tsusiatsoftware.net/jts/javadoc/com/vividsolutions/jts/linearref/LengthIndexedLine.html#project(com.vividsolutions.jts.geom.Coordinate)
PostGIS calls this function st_line_locate_point.
GEOS doesn't seem to have it, even though I was under the impression
that GEOS was merely a port of JTS. If I port JTS's project function
and related functions such as extractPoint to GEOS, would that patch be
likely to be accepted? Or am I missing something about the relationship
between JTS and GEOS?
