[geos-devel] tests\unit\capi\GEOSGeomFromWKBTest.cpp missing
Obe, Regina
robe.dnd at cityofboston.gov
Mon Jun 1 06:48:07 EDT 2009
Mateusz,
Sorry I forgot to mention, I'm not testing trunk. I'm testing the 3.1
branch and its not in there but the solution in 3.1 references it. So
maybe you just need to upload it to 3.1 as well
http://trac.osgeo.org/geos/browser/branches/3.1/tests/unit/capi
Thanks,
Regina
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Monday, June 01, 2009 4:31 AM
To: GEOS Development List
Subject: Re: [geos-devel] tests\unit\capi\GEOSGeomFromWKBTest.cpp
missing
Obe, Regina wrote:
> Was the tests\unit\capi\GEOSGeomFromWKBTest.cpp removed. I'm trying
to
> compile under visual studio 2008 with the msvc9 solution provided and
> this apparently has link to this and says it doesn't exist.
No, it was not removed. I added it 3 months ago and I still can
see it in the trunk.
http://trac.osgeo.org/geos/browser/trunk/tests/unit/capi
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
