[geos-devel] 3.1.1rc1 and 3.0.4rc1
Obe, Regina robe.dnd at cityofboston.gov
Fri Jun 12 09:09:21 EDT 2009
Okay I visually inspected one of the buffer differences between 3.1.0
and 3.1.1 and it appears to be a bug fix.  In the 3.1.0 the buffer is
clearly wrong as it is missing one of the polygons that should have been
formed from the original goemetry.  In the 3.1.1 it includes the missing
polygon.
So its just seems to be the make check that is problematic as far as I
can tell.
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Obe, Regina
Sent: Friday, June 12, 2009 8:54 AM
To: GEOS Development List
Subject: RE: [geos-devel] 3.1.1rc1 and 3.0.4rc1
 Thought geos 3.1.1rc1 tests fail.  Comparing behavior of geos 3.1.1rc1
against geos 3.1.0 stable under PostGIS 1.4SVN under PostgreSQL 8.4 beta
2 with PostGIS torture test, they behave more or less the same.  Except
in 2 cases the buffer answers are different.  I assume that is to be
expected since a lot of work went into buffer.  I haven't checked to see
what these buffer differences are though.  But they are buffers dealing
with geometry collection and multilinestring.
Sent: Friday, June 12, 2009 8:00 AM
Cc: Mark Cave-Ayland
 So in conclusion
make check on MingW -- 3.1.1rc1 -- barely gets in the door (I think it
passed one test before vomitting)
3.0.4rc1  make check -- chugs along for a while ang then geos_unit.exe
crashes with message
creating geos_unit.exe
.libs/lt-geos_unit.exe.c: In function `main':
.libs/lt-geos_unit.exe.c:79: warning: passing arg 2 of `execv' from
incompatible pointer type
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
