[geos-devel] 3.1.1rc1 and 3.0.4rc1 fail under VS 2008
Obe, Regina robe.dnd at cityofboston.gov
Sat Jun 13 11:41:26 EDT 2009
geos-3.1.1rc1 -- fails under Visual Studio 2008.  well at least for me anyway.
1) capi unit is still referencing GEOSGeomToWKB...  -  I think Mateuz said this should not be in 3.1.1 -- just in 3.2? I took it out, but everything still fails
2)badthreadtest.c, threattest.c, geostest.c -- have a big red mark -- saying they are missing CoordinateSequenceFactor.cpp among other things.
1>LinearComponentExtracter.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\..\..\source\geom\util\LinearComponentExtracter.cpp': No such file or directory
1>PointExtracter.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\..\..\source\geom\util\PointExtracter.cpp': No such file or directory
1>PolygonExtracter.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\..\..\source\geom\util\PolygonExtracter.cpp': No such file or directory
1>AssertionFailedException.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\..\..\source\util\AssertionFailedException.cpp': No such file or directory
1>IllegalArgumentException.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\..\..\source\util\IllegalArgumentException.cpp': No such file or directory
1>UnsupportedOperationException.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\..\..\source\util\UnsupportedOperationException.cpp': No such file or directory
1>geos_c.cpp
1>c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wkbreader.h(151) : warning C4512: 'geos::io::WKBReader' : assignment operator could not be generated
1>        c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wkbreader.h(67) : see declaration of 'geos::io::WKBReader'
1>c:\projects\geos\geos-3.1.1rc1\source\headers\geos\geomgraph\nodemap.h(100) : warning C4512: 'geos::geomgraph::NodeMap' : assignment operator could not be generated
1>        c:\projects\geos\geos-3.1.1rc1\source\headers\geos\geomgraph\nodemap.h(42) : see declaration of 'geos::geomgraph::NodeMap'
1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(710) : warning C4099: 'geos::io::WKTReader' : type name first seen using 'class' now seen using 'struct'
1>        c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wktreader.h(53) : see declaration of 'geos::io::WKTReader'
1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(711) : warning C4099: 'geos::io::WKTWriter' : type name first seen using 'class' now seen using 'struct'
1>        c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wktwriter.h(68) : see declaration of 'geos::io::WKTWriter'
1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(712) : warning C4099: 'geos::io::WKBReader' : type name first seen using 'class' now seen using 'struct'
1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(713) : warning C4099: 'geos::io::WKBWriter' : type name first seen using 'class' now seen using 'struct'
1>        c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wkbwriter.h(67) : see declaration of 'geos::io::WKBWriter'
1>geos_ts_c.cpp
1>c:\projects\geos\geos-3.1.1rc1\source\headers\geos\precision\geometrysnapper.h(96) : warning C4512: 'geos::precision::GeometrySnapper' : assignment operator could not be generated
1>        c:\projects\geos\geos-3.1.1rc1\source\headers\geos\precision\geometrysnapper.h(45) : see declaration of 'geos::precision::GeometrySnapper'
1>c:\projects\geos\geos-3.1.1rc1\capi\geos_ts_c.cpp(156) : warning C4100: 'extHandle' : unreferenced formal parameter
1>Generating Code...
1>Build log was saved at "file://c:\Projects\geos\geos-3.1.1rc1\build\msvc90\geos_lib\Debug\geos_lib\BuildLog.htm"
1>geos_lib - 7 error(s), 15 warning(s)
2>------ Build started: Project: geos_c_dll, Configuration: Debug Win32 ------
2>Linking...
2>LINK : fatal error LNK1104: cannot open file '..\debug\geosd.lib'
2>Build log was saved at "file://c:\Projects\geos\geos-3.1.1rc1\build\msvc90\geos_c_dll\Debug\BuildLog.htm"
2>geos_c_dll - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 2 failed, 0 up-to-date, 0 skipped ==========
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090613/a01d8513/attachment.html
