[geos-devel] [GEOS] #262: 3.1.1 unit test build fail under vs 2008
GEOS geos-trac at osgeo.org
Mon Jun 15 19:36:50 EDT 2009
 Reporter:  sanak       |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.1.1
Component:  Default     |     Version:
 Severity:  Unassigned  |    Keywords:
 3>c1xx : fatal error C1083: ソース
 ファイルを開けません。'..\..\..\tests\unit\capi\GEOSGeomFromWKBTest.cpp': No such
 file or directory
 I had make patch for this problem.
 Regards,
Ticket URL: <http://trac.osgeo.org/geos/ticket/262>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
