[geos-devel] Re: [GEOS] #262: 3.1.1 unit test build fail under vs
2008
geos-trac at osgeo.org
Mon Jun 15 20:06:39 EDT 2009
#262: 3.1.1 unit test build fail under vs 2008
Reporter: sanak | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 3.1.1
Component: Default | Version:
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
Applied at r2583 in 3.1 branch.
Ticket URL: <http://trac.osgeo.org/geos/ticket/262#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
