[geos-devel] Re: [GEOS] #253: Unexpected "Self-intersection at or
near point"
geos-trac at osgeo.org
Wed May 27 12:21:05 EDT 2009
#253: Unexpected "Self-intersection at or near point"
Reporter: wvereeck | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: closed
Priority: minor | Milestone: 3.1.1
Component: Core | Version: 3.1.0
Severity: Unassigned | Resolution: invalid
Keywords: self-intersection |
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
Invalid inputs don't generally produce correct results. A self-
intersecting polygon ring is invalid. When you fix it, you make it valid.
We need a way to automate that fixing. See #254.
Ticket URL: <http://trac.osgeo.org/geos/ticket/253#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
