[geos-devel] 3.2.0 Preparations - Failed under MingW - Compiles
but make check fails
Obe, Regina
robe.dnd at cityofboston.gov
Thu May 28 09:35:46 EDT 2009
Paul,
Doing a fresh checkout of trunk and then repeating the below under MingW
makes things compile fine so I guess it was junk I had left over from
before.
However doing a
make install
followed by:
make check
gives lots of errors. Everything is fine up thru xmltester, then start
getting errors in threadtest.c -- too many to list - hear is a sampling.
I presume its something wrong with my unistd.h or some include is being
included twice (but if someone else can confirm its not just my MingW
install).
In file included from ../../source/headers/geos/io/WKTReader.h:21,
from ../../source/headers/geos/io.h:56,
from
C:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/unistd.h:10,
from capi/threadtest.c:20:
../../source/headers/geos/geom/CoordinateSequence.h:100: error:
conflicting types for 'Coordinate'
../../source/headers/geos/geom/Coordinate.h:85: error: previous
definition of 'Coordinate' was here
../../source/headers/geos/geom/CoordinateSequence.h:100: error: syntax
error before '&' token
../../source/headers/geos/geom/CoordinateSequence.h:154: error: syntax
error before ':' token
../../source/headers/geos/geom/CoordinateSequence.h:171: error: syntax
error before '*' token
../../source/headers/geos/geom/CoordinateSequence.h:172: error:
redefinition of parameter 'add'
../../source/headers/geos/geom/CoordinateSequence.h:154: error: previous
definition of 'add' was here
../../source/headers/geos/geom/CoordinateSequence.h:224: error:
redefinition of parameter 'Coordinate'
../../source/headers/geos/geom/CoordinateSequence.h:100: error: previous
../../source/headers/geos/geom/CoordinateSequence.h:224: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:235: error: storage
class specified for parameter `CoordinateSequence'
../../source/headers/geos/geom/CoordinateSequence.h:235: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:248: error: storage
class specified for parameter `bool'
../../source/headers/geos/geom/CoordinateSequence.h:248: error: syntax
error before "hasRepeatedPoints"
../../source/headers/geos/geom/CoordinateSequence.h:254: error: storage
redefinition of parameter 'CoordinateSequence'
../../source/headers/geos/geom/CoordinateSequence.h:235: error: previous
definition of 'CoordinateSequence' was here
../../source/headers/geos/geom/CoordinateSequence.h:254: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:262: error: storage
class specified for parameter `Coordinate'
../../source/headers/geos/geom/CoordinateSequence.h:224: error: previous
../../source/headers/geos/geom/CoordinateSequence.h:262: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:269: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:270: error: storage
class specified for parameter `indexOf'
../../source/headers/geos/geom/CoordinateSequence.h:277: error: storage
redefinition of parameter 'bool'
../../source/headers/geos/geom/CoordinateSequence.h:248: error: previous
definition of 'bool' was here
../../source/headers/geos/geom/CoordinateSequence.h:277: error: syntax
error before "equals"
../../source/headers/geos/geom/CoordinateSequence.h:281: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:281: error: storage
class specified for parameter `scroll'
../../source/headers/geos/geom/CoordinateSequence.h:300: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:300: error: storage
class specified for parameter `increasingDirection'
../../source/headers/geos/geom/CoordinateSequence.h:303: error: syntax
../../source/headers/geos/geom/CoordinateSequence.h:303: error: storage
class specified for parameter `reverse'
../../source/headers/geos/geom/CoordinateSequence.h:314: error: syntax
error before "virtual"
In file included from ../../source/headers/geos/io.h:56,
capi/threadtest.c:107: error: previous definition of 'GEOSGeometry' was
here
capi/threadtest.c:196: error: syntax error before '*' token
capi/threadtest.c:198: error: storage class specified for parameter
`wkt'
capi/threadtest.c:199: error: syntax error before "FILE"
capi/threadtest.c:202: error: syntax error before "size_t"
capi/threadtest.c:205: error: syntax error before "input"
capi/threadtest.c: At top level:
../../source/headers/geos/io/ByteOrderValues.h:40: warning: 'getInt'
declared `static' but never defined
../../source/headers/geos/io/ByteOrderValues.h:41: warning: 'putInt'
../../source/headers/geos/io/ByteOrderValues.h:43: warning: 'getLong'
../../source/headers/geos/io/ByteOrderValues.h:44: warning: 'putLong'
../../source/headers/geos/io/ByteOrderValues.h:46: warning: 'getDouble'
../../source/headers/geos/io/ByteOrderValues.h:47: warning: 'putDouble'
etc.
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Obe, Regina
Sent: Thursday, May 28, 2009 8:21 AM
To: GEOS Development List
Subject: RE: [geos-devel] 3.2.0 Preparations - Failed under MingW
Paul,
Geos trunk doesn't compile for me under MingW. Haven't tried under VS
2008 yet.
I haven't done a clean checkout so will try that next, but this is what
I get under MingW, after doing an sh autogen.sh (maybe I need to upgrade
my auto conf again)
$ sh autogen.sh
* Running /mingw/bin/libtoolize (2.2.4)
\tOPTIONS = --force --copy
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
libtoolize: copying file `macros/libtool.m4'
libtoolize: copying file `macros/ltoptions.m4'
libtoolize: copying file `macros/ltsugar.m4'
libtoolize: copying file `macros/ltversion.m4'
libtoolize: copying file `macros/lt~obsolete.m4'
* Running /bin/aclocal (1.8.2)
/usr/share/aclocal/autoopts.m4:22: warning: underquoted definition of
AG_PATH_AU
TOOPTS
run info '(automake)Extending aclocal'
or see
http://sources.redhat.com/automake/automake.html#Extending%20aclocal
* Running /bin/autoheader (2.59)
* Running /bin/automake (1.8.2)
\tOPTIONS = --add-missing --copy
configure.in:10: installing `./config.guess'
configure.in:10: installing `./config.sub'
* Running /bin/autoconf (2.59)
Now you are ready to run './configure'
and then ./configure
-- make works for a while and then fails with below
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I. -I../../../source/headers
-I../../../source/headers/geos -I../../../source/headers -g -O2
-DGEOS_INLINE -pedantic -Wall -ansi -Wno-long-long -ffloat-store -MT
SnapIfNeededOverlayOp.lo -MD -MP -MF .deps/SnapIfNeededOverlayOp.Tpo -c
snap/SnapIfNeededOverlayOp.cpp -DDLL_EXPORT -DPIC -o
.libs/SnapIfNeededOverlayOp.o
snap/SnapIfNeededOverlayOp.cpp -o SnapIfNeededOverlayOp.o >/dev/null
2>&1
make[4]: *** No rule to make target `FuzzyPointLocator.cpp', needed by
`FuzzyPointLocator.lo'. Stop.
make[4]: Leaving directory
`/D/SVNProjects/geos/trunk/source/operation/overlay'
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory `/D/SVNProjects/geos/trunk/source/operation'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/D/SVNProjects/geos/trunk/source'
make: *** [install-recursive] Error 1
Thanks,
Regina
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Wednesday, May 27, 2009 3:27 PM
Subject: [geos-devel] 3.2.0 Preparations
I have triaged most of the bugs in the tracker now, and I think we
have a reasonable working set to examine and either fix or defer now
under the 3.2 milestone. Once that list has been worked, we can move
to an RC1 release.
http://trac.osgeo.org/geos/report/3
Paul
Paul Ramsey
OpenGeo - http://opengeo.org
PostGIS topical ointment. Cures slow maps.
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
