[geos-devel] 3.0.
Mateusz Loskot mateusz at loskot.net
Sat May 30 10:14:33 EDT 2009
Obe, Regina wrote:
> Mateusz,
> I'm pretty sure I did that before, but tried again followed by
> ./configure
> make clean
> make
> and still same error.
Regina,
I'm afraid I'm out of clue.
> My autogen.sh call produces this
> $ sh autogen.sh
> Running aclocal -I macros
> /usr/share/aclocal/autoopts.m4:22: warning: underquoted definition of
> AG_PATH_AU
> TOOPTS
>   run info '(automake)Extending aclocal'
>   or see
> http://sources.redhat.com/automake/automake.html#Extending%20aclocal
> Running autoheader
> Running libtoolize
> libtoolize: putting auxiliary files in `.'.
> libtoolize: copying file `./ltmain.sh'
> libtoolize: You should add the contents of the following files to
> `aclocal.m4':
> libtoolize:   `/c/mingw/share/aclocal/libtool.m4'
> libtoolize:   `/c/mingw/share/aclocal/ltoptions.m4'
> libtoolize:   `/c/mingw/share/aclocal/ltversion.m4'
> libtoolize:   `/c/mingw/share/aclocal/ltsugar.m4'
> libtoolize:   `/c/mingw/share/aclocal/lt~obsolete.m4'
> libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in
> and
> libtoolize: rerunning libtoolize, to keep the correct libtool macros
> in-tree.
> libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
> Running automake
> configure.in:6: installing `./config.guess'
> configure.in:6: installing `./config.sub'
> Running autoconf
> Now you are ready to run './configure'
Looks good.
> What is puzzling to me is why geos trunk compiles fine (its when I do
> make check that I run into dupe includes with that one).  Which version
> of libtool does 3.0 branch require?
I don't know which version is required.
What I can tell is that I can't remember I've ever had problems with
libtool version when using GEOS on Linux.
Here are tools I use on FreeBSD 7.2 to build GEOS with success:
autoconf 2.62
aclocal 1.9.6
automake 1.9.6
libtool 1.5.26
GCC  4.2.1
As you can see, the libtool here is pretty old.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
