[geos-devel] Re: [GEOS] #276: "make check" failed at geos_unit on mingw
GEOS geos-trac at osgeo.org
Sun Oct 11 13:09:39 EDT 2009
 Reporter:  sanak       |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.2.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:  mingw       |
Comment (by strk):
 Sanak, does the crash still occur with r2669 ?
 Can you attach a backtrace ?
 Which version of mingw are you using ? Which version of GCC does it
 contain ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/276#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
