[geos-devel] Compiling Problems
yoda2nd
yoda2nd at niacc.org
Sun Oct 11 19:07:47 EDT 2009
Hello all,
I am trying to compile following the instructions on the website,
however I seem to be getting an error that I know nothing about. Below
is the output from ./configure and make. Thanks in advance for any
help.
./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl.exe... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared
libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
appending configuration tag "F77" to libtool
checking whether we are using the GNU C++ compiler... (cached) no
checking whether g++ accepts -g... (cached) no
checking dependency style of g++... (cached) none
checking for library containing strerror... none required
checking whether make sets $(MAKE)... (cached) yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking whether closedir returns void... no
checking for working memcmp... yes
checking for strftime... yes
checking for vprintf... yes
checking for _doprnt... no
checking for working alloca.h... yes
checking for alloca... yes
checking for dirent.h that defines DIR... (cached) yes
checking for library containing opendir... (cached) none required
checking for ANSI C header files... (cached) yes
checking for memory.h... (cached) yes
checking for unistd.h... (cached) yes
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking sys/file.h usability... yes
checking sys/file.h presence... yes
checking for sys/file.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for strchr... yes
checking for memcpy... yes
checking for gettimeofday... yes
checking whether stat file-mode macros are broken... no
checking whether struct tm is in sys/time.h or time.h... time.h
checking for size_t... yes
checking for an ANSI C-conforming const... yes
checking if gcc supports -pedantic... yes
checking if gcc supports -Wall... (cached) yes
checking if gcc supports -ansi... (cached) yes
checking if gcc supports -Wno-long-long... (cached) yes
checking whether int64_t is 64 bits... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating build/Makefile
config.status: creating build/msvc80/Makefile
config.status: creating build/msvc80/geos_c_dll/Makefile
config.status: creating build/msvc80/geos_lib/Makefile
config.status: creating build/msvc80/geos_python/Makefile
config.status: creating build/msvc80/geos_ruby/Makefile
config.status: creating build/msvc80/geos_unit/Makefile
config.status: creating build/msvc90/Makefile
config.status: creating build/msvc90/geos_c_dll/Makefile
config.status: creating build/msvc90/geos_lib/Makefile
config.status: creating build/msvc90/geos_python/Makefile
config.status: creating build/msvc90/geos_ruby/Makefile
config.status: creating build/msvc90/geos_unit/Makefile
config.status: creating capi/Makefile
config.status: creating capi/geos_c.h
config.status: creating doc/Doxyfile
config.status: creating doc/Makefile
config.status: creating macros/Makefile
config.status: creating source/Makefile
config.status: creating source/algorithm/Makefile
config.status: creating source/algorithm/locate/Makefile
config.status: creating source/geom/Makefile
config.status: creating source/geom/prep/Makefile
config.status: creating source/geom/util/Makefile
config.status: creating source/geomgraph/Makefile
config.status: creating source/geomgraph/index/Makefile
config.status: creating source/headers/Makefile
config.status: creating source/headers/geos/Makefile
config.status: creating source/headers/geos/algorithm/Makefile
config.status: creating source/headers/geos/algorithm/locate/Makefile
config.status: creating source/headers/geos/geom/Makefile
config.status: creating source/headers/geos/geom/prep/Makefile
config.status: creating source/headers/geos/geom/util/Makefile
config.status: creating source/headers/geos/geomgraph/Makefile
config.status: creating source/headers/geos/geomgraph/index/Makefile
config.status: creating source/headers/geos/index/Makefile
config.status: creating source/headers/geos/index/bintree/Makefile
config.status: creating source/headers/geos/index/chain/Makefile
config.status: creating source/headers/geos/index/intervalrtree/Makefile
config.status: creating source/headers/geos/index/quadtree/Makefile
config.status: creating source/headers/geos/index/strtree/Makefile
config.status: creating source/headers/geos/index/sweepline/Makefile
config.status: creating source/headers/geos/io/Makefile
config.status: creating source/headers/geos/noding/Makefile
config.status: creating source/headers/geos/noding/snapround/Makefile
config.status: creating source/headers/geos/operation/Makefile
config.status: creating source/headers/geos/operation/buffer/Makefile
config.status: creating source/headers/geos/operation/distance/Makefile
config.status: creating source/headers/geos/operation/linemerge/Makefile
config.status: creating source/headers/geos/operation/overlay/Makefile
source/headers/geos/operation/polygonize/Makefile
config.status: creating source/headers/geos/operation/predicate/Makefile
config.status: creating source/headers/geos/operation/relate/Makefile
config.status: creating source/headers/geos/operation/union/Makefile
config.status: creating source/headers/geos/operation/valid/Makefile
config.status: creating source/headers/geos/planargraph/Makefile
source/headers/geos/planargraph/algorithm/Makefile
config.status: creating source/headers/geos/precision/Makefile
config.status: creating source/headers/geos/simplify/Makefile
config.status: creating source/headers/geos/util/Makefile
config.status: creating source/headers/geos/version.h
config.status: creating source/index/Makefile
config.status: creating source/index/bintree/Makefile
config.status: creating source/index/chain/Makefile
config.status: creating source/index/intervalrtree/Makefile
config.status: creating source/index/quadtree/Makefile
config.status: creating source/index/strtree/Makefile
config.status: creating source/index/sweepline/Makefile
config.status: creating source/io/Makefile
config.status: creating source/noding/Makefile
config.status: creating source/noding/snapround/Makefile
config.status: creating source/operation/Makefile
config.status: creating source/operation/buffer/Makefile
config.status: creating source/operation/distance/Makefile
config.status: creating source/operation/linemerge/Makefile
config.status: creating source/operation/overlay/Makefile
config.status: creating source/operation/polygonize/Makefile
config.status: creating source/operation/predicate/Makefile
config.status: creating source/operation/relate/Makefile
config.status: creating source/operation/union/Makefile
config.status: creating source/operation/valid/Makefile
config.status: creating source/planargraph/Makefile
config.status: creating source/precision/Makefile
config.status: creating source/simplify/Makefile
config.status: creating source/util/Makefile
config.status: creating swig/geos.i
config.status: creating swig/Makefile
config.status: creating swig/python/Makefile
config.status: creating swig/python/tests/Makefile
config.status: creating swig/ruby/Makefile
config.status: creating swig/ruby/test/Makefile
config.status: creating tests/Makefile
config.status: creating tests/bigtest/Makefile
config.status: creating tests/unit/Makefile
config.status: creating tests/tut/Makefile
config.status: creating tests/xmltester/Makefile
config.status: creating tools/Makefile
config.status: creating tools/geos-config
config.status: creating source/headers/config.h
config.status: creating source/headers/geos/platform.h
config.status: executing depfiles commands
Swig: false
Python: false
Ruby: false
make
Making all in build
make[1]: Entering directory `/gis/source_code/geos-3.1.1/build'
Making all in msvc80
make[2]: Entering directory `/gis/source_code/geos-3.1.1/build/msvc80'
Making all in geos_c_dll
make[3]: Entering directory
`/gis/source_code/geos-3.1.1/build/msvc80/geos_c_dll'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory
Making all in geos_lib
`/gis/source_code/geos-3.1.1/build/msvc80/geos_lib'
Making all in geos_python
`/gis/source_code/geos-3.1.1/build/msvc80/geos_python'
Making all in geos_ruby
`/gis/source_code/geos-3.1.1/build/msvc80/geos_ruby'
Making all in geos_unit
`/gis/source_code/geos-3.1.1/build/msvc80/geos_unit'
make[3]: Entering directory `/gis/source_code/geos-3.1.1/build/msvc80'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/gis/source_code/geos-3.1.1/build/msvc80'
make[2]: Leaving directory `/gis/source_code/geos-3.1.1/build/msvc80'
Making all in msvc90
make[2]: Entering directory `/gis/source_code/geos-3.1.1/build/msvc90'
`/gis/source_code/geos-3.1.1/build/msvc90/geos_c_dll'
`/gis/source_code/geos-3.1.1/build/msvc90/geos_lib'
`/gis/source_code/geos-3.1.1/build/msvc90/geos_python'
`/gis/source_code/geos-3.1.1/build/msvc90/geos_ruby'
`/gis/source_code/geos-3.1.1/build/msvc90/geos_unit'
make[3]: Entering directory `/gis/source_code/geos-3.1.1/build/msvc90'
make[3]: Leaving directory `/gis/source_code/geos-3.1.1/build/msvc90'
make[2]: Leaving directory `/gis/source_code/geos-3.1.1/build/msvc90'
make[2]: Entering directory `/gis/source_code/geos-3.1.1/build'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/gis/source_code/geos-3.1.1/build'
make[1]: Leaving directory `/gis/source_code/geos-3.1.1/build'
Making all in source
make[1]: Entering directory `/gis/source_code/geos-3.1.1/source'
Making all in algorithm
`/gis/source_code/geos-3.1.1/source/algorithm'
Making all in locate
`/gis/source_code/geos-3.1.1/source/algorithm/locate'
make[4]: Entering directory
source='IndexedPointInAreaLocator.cpp'
object='IndexedPointInAreaLocator.lo' libtool=yes \
DEPDIR=.deps depmode=none /bin/sh ../../../depcomp \
/bin/sh ../../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H
-I. -I../../../source/headers -I../../../source/headers/geos
-I../../../source/headers -DGEOS_INLINE -pedantic -Wall -ansi
-Wno-long-long -c -o IndexedPointInAreaLocator.lo
libtool: ignoring unknown tag CXX
mkdir .libs
g++ -DHAVE_CONFIG_H -I. -I../../../source/headers
-I../../../source/headers/geos -I../../../source/headers -DGEOS_INLINE
-pedantic -Wall -ansi -Wno-long-long -c IndexedPointInAreaLocator.cpp
-fPIC -DPIC -o .libs/IndexedPointInAreaLocator.o
../../../libtool: line 1281: g++: command not found
make[4]: *** [IndexedPointInAreaLocator.lo] Error 1
make[4]: Leaving directory
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/gis/source_code/geos-3.1.1/source'
make: *** [all-recursive] Error 1
