[geos-devel] Re: [GEOS] #358: Invalid output from Union
GEOS geos-trac at osgeo.org
Fri Aug 27 10:40:06 EDT 2010
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 For the record, there were other 5 tests, beside the one in
 robustness.xml, returning invalid geometries in output.
 Current trunk have these isolated in their own files (robustness-invalid-
 output.xml and stml-something-invalid-output.xml).
 With the fallback patch all the tests in stml*xml still succeed and give
 valid results,
 while the one in robustness-invalid-output.xml fails with an exception.
 See bug 375 for that one.
Ticket URL: <http://trac.osgeo.org/geos/ticket/358#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
