[geos-devel] GEOS Ruby bindings gem and extensions
Paul Ramsey pramsey at opengeo.org
Wed Dec 1 11:38:33 EST 2010
If there's no integration *required* to make the Ruby stuff work well,
then (a) you should keep them  and (b) we should strip out the old
ones and replace them with a readme.txt pointing to the location of
the maintained ones.
P.
On Wed, Dec 1, 2010 at 8:31 AM, strk <strk at keybit.net> wrote:
> On Wed, Dec 01, 2010 at 11:26:16AM -0500, J Smith wrote:
>> The big question is: do we want to have this code directly in the main
>> GEOS repository? We were planning on using github to facilitate the
>> whole social coding scene thing and 'cause we like the dead-simple
>> release management that jeweler provides.
> I second using a separate repository.
> That way you can keep binding release cycles completely separated
> from the core GEOS library.
> I've been too lazy to do that for the PHP bindings...
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
