[geos-devel] Re: [GEOS] #390: Cascade Union Static Methods & More Qualified util
GEOS geos-trac at osgeo.org
Sat Dec 18 08:45:01 EST 2010
 Reporter:  tomatsafe    |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  trivial      |   Milestone:
Component:  Default      |     Version:  3.0.3
 Severity:  Unassigned   |    Keywords:
Comment(by strk):
 the patch contains indent changes too, could you please use the same
 indenting ?
 Also since you're at it please consider splitting the patch in two (the
 BinaryOp and static method)
Ticket URL: <http://trac.osgeo.org/geos/ticket/390#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
