[geos-devel] Questions about linear referencing
David Turner novalis at novalis.org
Mon Feb 1 10:31:38 EST 2010
On Mon, 2010-02-01 at 11:04 +0100, Sean Gillies wrote:
> The GEOSProject function returns a numerical value when passed a line
> string and a point not on the line. If the point is beyond (in some
> sense) the line's starting point, you get 0.0 (normalized). If the
> point is past (in some sense) the line's end point, you get 1.0
> (normalized to the line's length). If the point is otherwise off of
> the line but not past one of its ends in that sense, you get a value
> between 0 and 1.
> Is this intended? The behavior seems like it could get rather
> unpredictable for anything other than a perfectly straight line.
This comes from the LengthIndexedLine::project method.  That method
finds the closest point along the geometry to the input point.  That
closest point could be one of the end points.  Why is this
unpredictable?
