[geos-devel] Questions about linear referencing
    Sean Gillies
    sean.gillies at gmail.com
    Mon Feb  1 11:20:46 EST 2010
On Feb 1, 2010, at 4:31 PM, David Turner wrote:
> On Mon, 2010-02-01 at 11:04 +0100, Sean Gillies wrote:
>> The GEOSProject function returns a numerical value when passed a line
>> string and a point not on the line. If the point is beyond (in some
>> sense) the line's starting point, you get 0.0 (normalized). If the
>> point is past (in some sense) the line's end point, you get 1.0
>> (normalized to the line's length). If the point is otherwise off of
>> the line but not past one of its ends in that sense, you get a value
>> between 0 and 1.
>> Is this intended? The behavior seems like it could get rather
>> unpredictable for anything other than a perfectly straight line.
> This comes from the LengthIndexedLine::project method.  That method
> finds the closest point along the geometry to the input point.  That
> closest point could be one of the end points.  Why is this
> unpredictable?
That does seem predictable. I just couldn't tell from the code or docs
what the intent of the function exactly was. If it's intent is the
same as ST_line_locate_point from PostGIS, I'm clear.
Thanks,
Sean
