[geos-devel] Re: TopologyException: found non-noded intersection
Martin Davis
mbdavis at refractions.net
Tue Jun 22 13:15:33 EDT 2010
Giovanni,
That's a good point. In both JTS and GEOS CascadedUnion is limited to
operating in main memory. (However, it may be that GEOS running under
PostGIS is more memory-efficient, or is able to utilize a larger memory
space).
There's not really an easy solution for working with JTS CascadedUnion
and very large datasets. (This also applies to using CascadedUnion in
JEQL - although JEQL itself is not memory-bound, it can process data in
a streaming fashion. But the CascadedUnion algorithm is not stream-based).
Some alternatives that come to mind are:
- use 64-bit Java and lots of memory
- implement your own "GriddedUnion" in PostGIS (and maybe involving
JTS). I can provided details if you like.
Martin
G. Allegri wrote:
> Thanks Martin.
> I see that jts 1.11 works fine on a subset of my dataset. I have
> hundreds of thousands od polygons to merge... I have to find the way
> to read them to pass the collection to JTS without receiving
> java.lang.OutOfMemoryError (just happened!).
> What do you suggest to build the collection needed by CascadedUnion
> without havind to create a huge Collection of geometries?
> I will take a look at JEQL. Thanks for the hint, I didn't know it...
> Giovanni
> 2010/6/22 G. Allegri <giohappy at gmail.com>:
>> I'm using Postgis 1.5.1 to compute a Union on a quite large
>> multipolygons dataset (some hundreds of thousands of features), but
>> I'm facing the following error:
>> NOTICE: TopologyException: found non-noded intersection between
>> LINESTRING (1.7318e+006 4.77959e+006, 1.7318e+006 4.77958e+006) and
>> LINESTRING (1.7318e+006 4.77958e+006, 1.73174e+006 4.77954e+006) at
>> ERROR: GEOS union() threw an error!
>> I know it's a known issue, but I haven't been able to find a good,
>> replicable, solution. The input geometries result valid (in simple
>> feature meaning).
>> What is causing this? I have overlapping polygons, but I thought the
>> cascaded union algorithm computed the necessary noding on the
>> linestrings.
>> I've supposed it depends on tolerances/precision model, but I don't if
>> it makes sense and how, eventually, tune it.
>> Thanks a lot,
>> Giovanni
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
