[geos-devel] TopologyException: found non-noded intersection
strk strk at keybit.net
Fri Jun 25 11:21:07 EDT 2010
On Tue, Jun 22, 2010 at 08:52:30AM -0700, Martin Davis wrote:
> Also, there was a bug uncovered recently in JTS which has the effect of
> not performing some robustness improvement steps during CascadedUnion.
> It's a simple fix, so perhaps someone (strk?) will be able to implement
> it in GEOS.
Martin, could you give more info about this ?
I see nothing about "Cascaded" in the commit log.
The closest I see is:
2010-06-09 04:42  dr_jts
        * [r112] operation/union/UnaryUnionOp.java: Fixed to use
          SnapIfNeededOverlayOp
But maybe SVN logs don'g go back enough ?
First entry is 2010-02-10
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
