[geos-devel] CascadedPolygonUnion XML testing
G. Allegri giohappy at gmail.com
Fri Jun 25 13:41:48 EDT 2010
Here is a test xml:
http://www.giovanniallegri.it/share/TestUnionMultiPolygon.xml
It's big, but I will reduce it nex time :)
Notes:
1 - this multipolygon comes from an st_collect on 95 rows in a postgis
table. The test on it fails with Topology Expection found non-noded
intersection, because the MP is invalid. I've tested it on jts from
trunk.
2 - I've run a cascadedunion.union operation on a List of the same
geometries (picked with Geotools directly from the DB). It works fine.
In this test I've used jts 1.10 shipped with Geotools. I will try it
agains the trunk version as soon as possible.
Giovanni
2010/6/25 strk <strk at keybit.net>:
> On Fri, Jun 25, 2010 at 04:39:17PM +0200, strk wrote:
>> Martin, is there any support for testing CascadedUnion
>> with the XML format ? Would help comparing GEOS/JTS.
> I've found TestUnaryUnion.xml in JTS repository.
> I guess that's what GEOS should be using
> for testing CascadedPolygonUnion.
> Only need to actually port UnaryUnion ...
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
